Old 10-23-2024, 09:54 PM   #1
Crusty69
Passenger brake light not working
I have LED taillights. The running lights, turn signals, and driver side brake light works. What would be a likely issue causing only the drivers brake light to not work given that everything else is functioning.
Crusty69 is offline   Reply With Quote
Old 10-23-2024, 10:00 PM   #2
SRU1436
Re: Passenger brake light not working
I don’t have LED lights in my truck, but I’d start with the grounds. If I recall correctly, the housing is the ground. Not sure about how an LED grounds.
SRU1436 is offline   Reply With Quote
Old 10-24-2024, 12:09 AM   #3
Rust_never_sleeps
Rust_never_sleeps's Avatar
Do the bulbs only go in one way? Diodes are typically unidirectional, so polarity matters
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is offline   Reply With Quote
Old 10-24-2024, 12:42 AM   #4
RustyPile
RustyPile's Avatar
Ok, wait a minute.. I know your thread title says "Passenger brake light not working". But in second sentence you say the driver's side brake light works, and then in the last sentence you say it doesn't work.. Before I post a detailed description of the test steps, please clarify for me -- which brake light doesn't work...
RustyPile is offline   Reply With Quote
Old 10-24-2024, 03:40 PM   #5
Crusty69
Driver works, passenger doesn’t. Both turn signals work
Old 10-24-2024, 06:39 PM   #6
RustyPile
RustyPile's Avatar
OK, that's better, here we go.. The turn signal switch performs a bit of magic in that it separates the brake light electrical current from the turn signal electrical current.. AND it separates all this current from the front turn signals..
The brake lights and turn signals share the same bulbs and wires from the turn signal switch.. So if the turn signals work properly, the fault is NOT grounds, bulbs, LEDs, nor wires and their associated connections.. Here's the procedure for testing:
Push the brake pedal to activate the brake lights. Locate the turn signal harness where it plugs into the main harness but do not disconnect it. Use a test light that has an incandescent bulb, not an led. Ground the test light lead and probe the dark green wire at the plug.. If you don't have voltage here, the turn signal switch is bad.
Old 10-25-2024, 10:41 AM   #7
PbFut
If the front turn signal works correctly, then doesn't that indicate the switch is ok? Rusty, you know these trucks well. Is there some funky stuff with the switch and blinker that would allow one end to work and not the other? Do the easy stuff first. Swap bulbs to verify if its the bulb and or socket or not. Then very the socket is not corroded. Then verify if you have power at the socket. Then note color of wire. Go to firewall and unplug the connector on the 4 wire ribbon cable. Note the color of the wire matching the turn signal wire at the socket and test the pin for power on the firewall or jump 12v to the pin on the cable and see if the bulb lights.
PbFut is offline   Reply With Quote
Old 10-25-2024, 02:45 PM   #8
RustyPile
RustyPile's Avatar
Re-read my post.. The brake lights and rear turn signals share the same wires from the switch, the same bulbs, bulb sockets, and also the same ground paths.. Because of this "sharing", if the turn signals work as they should, then the problem with brake lights is NOT any of these items.. The problem is before the signal gets to the wires.. That's why I suggested testing at the plug.. I know the results of the test, there will be no voltage there.. I just wanted to "steer" the OP away from fiddling with all that other stuff and possibly creating another problem..
The front turn signals AND the dash turn indicators get their signal from the turn signal switch, but it is a totally different and independent section of the switch. To answer your question, No, that doesn't indicate the switch is functioning properly. It only indicates that section of the switch is functioning.
I realize wiring diagrams are very difficult for some people to read. But this is all laid out in the wiring diagram...
Old 10-27-2024, 11:07 AM   #9
Willshook
Really good advice - I had some wonky light problems recently at it was that plug at the rear that was the whole problem. Someone had decided that was a good place to splice in trailer wiring and screwed it up big time.
Buying one of those big laminated color-coded wiring harness diagrams was a HUGE help for me - well worth the money.
Willshook is offline   Reply With Quote
Old 11-20-2024, 07:30 PM   #10
Crusty69
Since making this thread, I had some down time where I couldn't work on it. Now I have headlights but no dash lights, no dome light, no rear turn signals, no taillighys, and no brake lights. But I do have reverse lights
Edit turn signals work
Old 11-20-2024, 09:37 PM   #11
RustyPile
RustyPile's Avatar
Headlights don't have fuses.. Built into the headlight switch is a circuit breaker. Reverse lights are a totally different circuit and have nothing to do with turn signals, brake lights or dash lights.. Go back to square one -- check fuses and obtain a wiring diagram so you will know where all those wires and circuits get their power.
Old 11-22-2024, 02:46 PM   #12
Crusty69
Fuse was blown. Replaced fuse, taillights still don't work, dash comes on for a minute then fuse blows again.
Old 11-22-2024, 06:15 PM   #13
RustyPile
RustyPile's Avatar
The tail lights and dash lights get their power from the headlight switch. The headlight switch gets its power from the main power distribution wire that feed numerous other items. Refer to the wiring diagram for diagnosing the tail light problem.
Blown fuses indicate a short in that circuit or more current draw than the fuse/circuit can handle. There is no hard set of instructions that point to exactly where the short is located, only guidelines for troubleshooting.. Here is a link to the tool I have used for years to aid me in locating shorts..
https://www.jbtools.com/sg-tool-aid-...e469293b1a538f
