#26 |
![]() Join Date: Feb 2022
Re: Post engine fire clean up
LizardSkin has a application kit. A spray gun that has a very large ventri to provide enough suction to pull the material out of the cup. It requires a decent size compressor to push out the air needed at about 70lbs. The material is very thick. Application kit is 109 buck. To do the job right you got to have it and big enough compressor or you're screwed.
FYI, material cleans up easy if not past the 1 hour or so flash time. Water based. Smells like acrylic house paint. As long as you have the needed air, the application job is a 2 out of 10 easy. 1 easy, 10 difficult. |
#27 | |
![]() Join Date: Jul 2000
3hp actual 40 gallon tank 12.6cfm @40psi 11.3 cfm @ 90psi Air hose is 3/8", fittings are 1/4" NPT How much splatter is there? My cab is finished. I will pull the carpet & backing, gas tank, but not anything under or in the dash.
Mike 1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress. 1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#28 |
It is way easier than masking for paint. You are using much higher air pressure so make sure masked areas are stuck down really well. You don't get atomized overspray. The spray pattern is tight but you get some edging. The gun comes with a straight and 90 tip to assist with overhead spray like under dash. It works just OK. The material and spray pattern very easy to control but I would still mask cab and doors as if spray painting. I masked exterior but found it not really necessary. The biggest issue would be if you blew past an edge while shooting up.
I have some left over. I think I might pull the head liner and shoot the roof. Sun gets hot in my area. |
#29 | |
The cab stays cool even on 95-100 degree days, so what I'm looking for is insulation from exhaust, engine, and road noise. Wish I could do the inside of the firewall, but that would be a nightmare.
#30 |
If just doing floor the a gallon will do. If back wall I would get the 2 gallon and have plenty.
#31 |
I just shot the roof. It is more stipally because I used the 90 tip and the material has been in a resealed container all week and a bit thicker. Also hanging upside down pulls it some. The 90 degree angled tip splatters more. I didn't cover driver door. No issues. One little splatter dot on white door
panal. Wiped right off with wet paper towel. Easy to control. My gun is splattered on outside, but still clean enough inside to provide good results. You are welcome to use. Just send a mail label and back when done. PM me and I can give box info. |
#32 |
Thanks for the offer. Will let you know what I decide to do.
#33 |
![]() Join Date: Jul 2021
Good job, that looks great! I did the same thing to my 72 C20. I sprayed the Lizardskin heat barrier and sound deadener. Then applied Flatline Barrier, then my carpet with jute. It made a world of difference in both noise and heat reduction. The Flateline Barrier also had material to put between the door panels and door. Luckily a friend of mine did his 67 Camaro with Lizardskin and loaned me his spray gun so I did not have to purchase one.
Darrell ![]() 1972 Cheyenne Super C20 (Heavenly Too) (My Street Truck) 2000 S10 Xtreme (Black Magic) (My Drag Truck) |
#34 |
![]() ![]() Join Date: Jul 2003
Great work on the rehab.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze poly, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Frame off restored 1970 K20, To be a clone of my Grandfather's K20, Dark Blue poly, 350, 4 speed, 16.5" X 8.25" Kelsey Hayes wheel option, tilt, tach, vacuum, AM radio. Latest project truck 1972 Cheyenne Super 20 2WD, Dark Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor... ![]() 2017 Sierra 1500 SLT 4WD, Black, 51k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2... 2019 Canyon SLT 4WD, White, 71k miles, 3.6, 8L45, 3.23 LS, 18" wheels |
#35 |
![]() Join Date: Dec 2023
It look like your efforts are having good results. I tend to be anxious about fire from previous experience and I have so many fire extinguishers lying around my house and garage/all vehicles now... hopefully my anxiety response will at least reduce my risk of bad outcomes in the future. I have firefighters in the family so in my family, the rule is extinguishers in the kitchen, garage, upstairs, and every vehicle. most people don't have a fire extinguisher in their car but it is definitely a good idea. I was driving through the middle of nowhere in north FL after a band gig a few years ago at 2 am and the truck in front of us caught fire . Nothing any of us could do at the time but pull over and watch it burn and commiserate with the driver and give him a ride to the nearest city. Would have been nice to save the day with a fire extinguisher.
#36 | |
What are your recommendations for garage and vehicles?
#37 |
Mike, for passenger vehicles I like the little "auto" model from First Alert just because it doesn't take up much space and it's RED. Some of the little ones sold for car or kitchen use are white, which I think is a bad idea because it doesn't look like a fire extinguisher and makes it easier to overlook when someone is scrambling to find one. https://www.firstalert.com/us/en/pro...xoCILYQAvD_BwE For the garage, any big old fire extinguisher will do, strapped to the wall someplace obvious, unobstructed, and easy to get to! even further off topic... when I lived in Montana I had a big old can of bear spray that I kept in the glove box for general defensive purposes in between hiking trips. It basically looks like a small fire extinguisher and I occasionally thought about a bad imaginary situation where I grabbed the wrong thing at the scene of an accident! But one day in a hot parking lot, the dang thing exploded in the glove box. Suffice to say, I do not recommend keeping bear spray in a vehicle.
#38 |
Thanks. Turns out my local ACE store has it for the same price as Amazon.
#39 | |
Never thought of it that way...indeed, the one I carry in my truck is white. However It's unlikely anyone but myself would ever be hunting for it. The last time I needed it was a few years ago when I built an electrical fire under the hood. Worked a charm and occasionally I still find a bit of the powder deep down in the chassis or in the fender bottoms. Replaced that one with a new one...also white. -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
| Bookmarks |
