![]() Join Date: Feb 2022
72 GMC Hump
Am I misidentifying the hump in my 1972 GMC C25?
I was going to take advantage of the Black Friday sales and order up some parts needed to finish up the fire damage. I started looking for carpet and ACC is not showing an option for a low hump on a 72 GMC. I am 99% sure it's their data base but Rock auto also did not have the low hump option for a 72 GMC. Stock Interiors does show the option on their site for their carpet. A search seems to show a strong lean to ACC product so I think I will go that direction and order using the Chevy selection. Can someone confirm this is low hump before I drop a few hundred on the wrong cut? |
Re: 72 GMC Hump
Pic of my 68 C10 with a high hump.
Re: 72 GMC Hump
Aren’t all high humps bolted in as apposed to welded . So I would say low hump
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
Re: 72 GMC Hump
Rockauto has a low hump listed for your truck . They just don’t list the turbo 350 .
https://www.rockauto.com/en/catalog/...,flooring,1264
#5 | |
![]() ![]() Join Date: Apr 2022
Re: 72 GMC Hump
OP has a low hump floor. On ACC select either 3spd manual trans or Auto trans and that is a 2WD, that would be a low hump carpet set.
The Twins: 1968 C10 SWB - Blue 327/5 Speed 1968 Camaro SS/RS - Blue 327/4speed C10 Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=833278 The "Others" 1933 Ford Pickup (Camaro in disguise) 2017 Camaro SS Life long Chevy guy |
Re: 72 GMC Hump
Manual trans will have hole in carpet for shifter. Auto 400 is high hump. On the ACC site there is a third option for Chevy and other years, simply Auto for a low hump and no hole as far as I can tell.
![]() ![]() Join Date: Jan 2005
Re: 72 GMC Hump
I don't think a manual carpet would come with the shifter hole pre-cut in it. They leave that for you to do.
Re: 72 GMC Hump
Nope . I had to cut the hole for the shifter on my 68its just a high hump carpet for either 4 spd or auto . ACC does not have a 350 listed only the 400 with either high or low hump . OP just needs to order the low hump like I posted
| Bookmarks |
