Old 12-08-2024, 03:17 PM   #276
pjmoreland
pjmoreland's Avatar
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Smoothed the welds on the PS Rocker panel and applied seam sealer around the edges.
The cab corner was bent up and dangling loose, so I reshaped it and tacked it to the floor in back.
pjmoreland is offline   Reply With Quote
Old 12-08-2024, 04:57 PM   #277
'68OrangeSunshine
'68OrangeSunshine's Avatar
Originally Posted by pjmoreland View Post
This truck was built in St. Louis.
I will be installing these stock mirrors. Thankfully, the stock holes are still there.
I really like my West Coast Jr mirrors. Any argument about streamlining is irrelevant, as it's a windtunnel brick anyway. The very stable and large images of what's coming up on your six is invaluable. At the speed I run on the interstate, who's approaching from the rear is pertinent.
I guess all the plants built Stepsides. St Louis was the only plant building K/5s -- Blazers and Jimmys -- until MY 1972, when the Flint Plant also contributed.
Old 12-08-2024, 09:27 PM   #278
pjmoreland
pjmoreland's Avatar
I agree that bigger mirrors are better. The little mirrors I'm going with are borderline worthless.
Old 12-08-2024, 09:37 PM   #279
pjmoreland
pjmoreland's Avatar
Primed and painted the passenger side rocker panel.
Old 12-09-2024, 01:35 AM   #280
loudchevy
loudchevy's Avatar
Dude, I love your daily progress. Keep up the good work.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 12-09-2024, 01:38 AM   #281
pjmoreland
pjmoreland's Avatar
Thanks. Some days I don't get much done, but I try to at least get a little bit of work in.
Old 12-09-2024, 01:53 AM   #282
loudchevy
loudchevy's Avatar
The truck doesn't build itself. A little work here and there adds up more than no work at all.
Glad you got lucky with only having to do the outer rocker on that side.
Scott
2003 Tahoe Stock
Old 12-09-2024, 01:57 AM   #283
pjmoreland
pjmoreland's Avatar
Agreed. We will see what the other side looks like. The floor has less rust on the driver side for some reason, so hopefully that means less rust in the rocker, too.
Old 12-09-2024, 08:37 PM   #284
pjmoreland
pjmoreland's Avatar
Reinstalled the door. There's some rain in the forecast, so I'm glad to have the cab closed back up.
Old 12-10-2024, 02:08 AM   #285
pjmoreland
pjmoreland's Avatar
Installed a push-on door seal.
Old 12-10-2024, 11:33 PM   #286
pjmoreland
pjmoreland's Avatar
Removed the driver side rocker panel. The inner rocker looks pretty good on this side.
Old 12-10-2024, 11:36 PM   #287
pjmoreland
pjmoreland's Avatar
Also removed the gauge cluster and took it apart. Most of it went in the trash.
Reinstalled the passenger side fender.
Old 12-14-2024, 01:04 AM   #288
pjmoreland
pjmoreland's Avatar
I had more epoxy paint left over from making another batch of dummy filler necks, so I painted a few parts.
Old 12-14-2024, 07:59 AM   #289
CUSTOM/10
CUSTOM/10's Avatar
I hope the replacement hub & spindle works out for you !!!
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 12-14-2024, 10:27 AM   #290
jaros44sr
jaros44sr's Avatar
Nice work so far, that is the truck I wanted to buy, couldn’t find one , ended up with a jimmy
Been following along great thread
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 12-14-2024, 11:02 AM   #291
pjmoreland
pjmoreland's Avatar
They look really nice. Thanks so much for helping me out
Old 12-14-2024, 11:06 AM   #292
pjmoreland
pjmoreland's Avatar
I'd love to have a Jimmy
Old 12-14-2024, 10:31 PM   #293
pjmoreland
pjmoreland's Avatar
Finally got the other front hub installed. All of the parts went together nicely. Hardly any of the components on this side were original to the truck.
Old 12-14-2024, 10:35 PM   #294
pjmoreland
pjmoreland's Avatar
I also spent some time prepping a dash patch panel for installation. This was something I could work on inside since it was raining for most of the day.
Old 12-14-2024, 10:39 PM   #295
pjmoreland
pjmoreland's Avatar
The rain stopped mid-afternoon, so I went out and removed the heater box and electrical harness from under the dash. I also removed the crusty old dash pad and uncovered a bunch of rust holes in the dash. I'm on the fence about patching the rust or getting a complete replacement dash. I will probably just patch the rust since it will be hidden under the dash pad. Every time I take something apart on this truck I find something new and exciting! Fortunately, I'm running out of things to take apart.
Old 12-15-2024, 08:25 AM   #296
CUSTOM/10
CUSTOM/10's Avatar
Glad the hub & spindle worked out for you...
Man that dash is a bummer. I've got a complete dash for you but the shipping would be outrageous $$$$.
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-15-2024, 11:03 AM   #297
pjmoreland
pjmoreland's Avatar
That would be one crazy big box
Old 12-15-2024, 12:11 PM   #298
CUSTOM/10
CUSTOM/10's Avatar
Look for one locally, I know you have good welding skills but a whole replacement would be so much easier .
Gary
72 SWB 4x4
My 72 SWB Build
Old 12-15-2024, 12:13 PM   #299
pjmoreland
pjmoreland's Avatar
A local friend has an A/C dash in a cab. He will be checking the condition today. I do plan on putting a Vintage Air kit in this truck eventually.
Old 12-15-2024, 12:45 PM   #300
CUSTOM/10
CUSTOM/10's Avatar
That sounds like a better option if it's in good shape and you can utilize the a/c holes in the dash !
Gary
72 SWB 4x4
My 72 SWB Build
