Re: NP205/Transmission Adapter Measurements Request
Originally Posted by pjmoreland
I will be installing an NV4500 transmission in my K10, and my plan is to fabricate an adapter bracket for it to allow it to bolt to the stock transmission crossmember mounts. Do any of you by chance have a stock SM465 or TH350 NP205-to-transmission adapter available for taking a couple of measurements for me, please? I'm looking for the following two dimensions:
A) The vertical distance from the crossmember mounting surface to the centerline of the transmission output shaft
B) The horizontal distance from the transfer case attachment surface to the centerline of the crossmember mount bolts
Thank you.
The first dimension is 7.85"
The second is 3.36" but the two surfaces are not perpendicular (see pic). The straight edge is hard to see in the pic, it is laying flat on the bottom transmission mount surface and then the square is resting on that. When the whole thing is assembled, transmission, adapter and transfer case, it gives a slight upward slant towards the engine BUT leaves the trans mount point parallel to the frame rails. I have the adapter because.....I installed an NV4500 earlier this year. Round NP205 TO NV4500.
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks, a 5 speed AND a front hitch!
