Old 03-11-2025, 11:11 AM   #6
pjmoreland
pjmoreland's Avatar
Re: NP205/Transmission Adapter Measurements Request
Originally Posted by Orange Crate View Post
The first dimension is 7.85"
The second is 3.36" but the two surfaces are not perpendicular (see pic). The straight edge is hard to see in the pic, it is laying flat on the bottom transmission mount surface and then the square is resting on that. When the whole thing is assembled, transmission, adapter and transfer case, it gives a slight upward slant towards the engine BUT leaves the trans mount point parallel to the frame rails. I have the adapter because.....I installed an NV4500 earlier this year. Round NP205 TO NV4500.
Would you be able to take another measurement for me, please? I'm looking for the distance from the transfer case mounting surface to the center of the shifter lever mount. I've labeled it "C" in the image below.
pjmoreland is offline   Reply With Quote
