Old 12-06-2024, 10:12 AM   #76
raggedjim
raggedjim's Avatar
Re: Bought My Uncles '69 Chevy 1/2 Ton Today
If you're ever in western Kentucky I have a stock 4-barrel intake you can have. Or are you keeping the 2-barrel?
Rg
raggedjim is offline   Reply With Quote
Old 12-06-2024, 11:29 AM   #77
LockDoc
The Older Generation
LockDoc's Avatar
Rg
Thanks Jim. I am planning on keeping the stock 2 barrel. I bought a rebuild kit for it but it needs to be soaked in cleaner and I don't have any.
I was just watching this video last night and I think I will try his method unless someone reading this has any negative input about the process.
https://www.youtube.com/watch?v=_Y23cfaH4hE
Leon
Old 12-06-2024, 12:01 PM   #78
sixty8HDC30
Looks like this works great. Just be super careful when using muriatic acid. I use it at work and it is super nasty stuff. Eye protection and a mask even when outside. One whiff of that stuff and you'll know it.
sixty8HDC30 is offline   Reply With Quote
Old 12-06-2024, 12:23 PM   #79
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Did you read his caution note that says for aluminum carbs. I believe most stock carbs as made from Zinc.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 12-06-2024, 12:29 PM   #80
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
I wouldn't use muriatic acid on a carburetor. There might not be much left of it. I didn't want to buy the parts dip last time I rebuilt my carb. I used acetone and denatured alcohol. They both dissolve different things without trashing the metal.
~Steven
Simi Valley, CA
Old 12-06-2024, 12:54 PM   #81
Getter-Done
Getter-Done's Avatar
I would not use Muriatic acid either.
JMHO.
The early bird gets the worm,
85 Chevy K-20
Old 12-06-2024, 03:37 PM   #82
LockDoc
LockDoc's Avatar
I did read that but I didn't know what the GM carbs were made from. I do have a couple more Chevy 2 barrels so I will try one of those first.
Thanks for the heads up.
Leon
Old 12-06-2024, 10:07 PM   #83
CG
BlahBlahBlah
So is this truck going to be a keeper? Its really coming along nicely.
Old 12-06-2024, 11:37 PM   #84
Louisvillekytruck
Great story and nice truck thanks for sharing
Louisvillekytruck is offline   Reply With Quote
Old 12-07-2024, 12:59 AM   #85
LockDoc
LockDoc's Avatar
Yes, I am going to keep it as long as I can, then it will be offered to members of the original owners (my uncle) family.
Thanks!
Leon
Old 12-07-2024, 09:34 AM   #86
raggedjim
raggedjim's Avatar
We used to use muriatic acid to eat aluminum chips from our filter system drums. It was full strength and eats aluminum like crazy! I see he diluted it quite a bit. Only testing will tell how well it works. Good luck! Rg
Old 12-07-2024, 02:58 PM   #87
LockDoc
LockDoc's Avatar
Thanks for the information Jim.
Leon
Old 12-07-2024, 03:34 PM   #88
dmjlambert
dmjlambert's Avatar
Are you talking about using a mix of acetone and denatured alcohol, or putting it in acetone for one cleaning and putting it in denatured alcohol for the second cleaning?
Old 12-07-2024, 06:46 PM   #89
Steeveedee
Steeveedee's Avatar
I mixed them, but it could be done separately, too. The idea was that the acetone gets the petroleum crud and the DNA gets any alcohol crud. McKay makes a parts dip that works very well, but I would only use it maybe once more in my lifetime, so I opted for acetone and DNA.
~Steven
Simi Valley, CA
Old 12-07-2024, 09:52 PM   #90
LockDoc
LockDoc's Avatar
Thanks for the information everyone.
Leon
Old 12-09-2024, 11:25 PM   #91
MikeB
MikeB's Avatar
An ultrasonic cleaner at 150-170 degrees with 3/4 water, 1/4 Simple Green will clean the surfaces, even nooks and crannies. You'll still have to use carb cleaner and a brush on some parts, and probably carb cleaner and compressed air to make sure all the air and fuel passages aren't blocked. Wouldn't hurt to spray some de-greaser on the carb parts and let them sit a while before dropping them in the ultrasonic cleaner. Any kind of acid? No way for this guy.
This is a long one made for rifle cleaning that I borrowed from a guy.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-09-2024, 11:37 PM   #92
Steeveedee
Steeveedee's Avatar
There is an organic acid, called tri-cresyl-phosphate, aka TCP, which was the detergent in SHELL gasoline, as opposed to ethylene chloride or ethylene bromide which other fuel providers used to clean the lead from tetraethyl lead off the valves. It is what left all the crusty yellow deposits on spark plugs, back in the day. All this stuff is a Class B poison. The McKay carb cleaner uses TCP, which is the strongest organic acid.
~Steven
Simi Valley, CA
Old 12-09-2024, 11:49 PM   #93
Getter-Done
I have a 30L USC from Vevor.
I must have one like this.
85 Chevy K-20
Old 12-09-2024, 11:52 PM   #94
Getter-Done
I have been doing experiments.
I will try this stuff you speak of.
Pine-Sol is my Favorite so far.
85 Chevy K-20
Old 12-10-2024, 11:31 AM   #95
LockDoc
LockDoc's Avatar
That is quite the setup. I guess a guy could make something like that out of an old crock pot or roaster. You see those quite a bit at garage sales around here. They wouldn't have the ultrasonic capabilities but would provide the heat. I will keep my eyes out for something.
I have used different acids over the years. I used to use Nitric acid to etch brass and create designs in it. I covered the brass with bees wax and drew the design in the wax with different tools then dipped the brass into the acid and it would etch the design into the brass.
TCP can't be too bad if mixed correctly...
"Tricalcium phosphate (abbreviation TCP) is a tricalcium salt of phosphoric acid with the chemical formula Ca3 (PO4)2. In food, it is used as an anticaking agent in powdered food and a nutritional supplement of calcium and phosphorus in infant formulae and cereals."
What does the Pine-Sol remove? Grease and oil or will it remove the carbon type deposits too.
Leon
Old 12-10-2024, 11:39 AM   #96
Getter-Done
So far the pieces I have run in the USC have had grease oil dirt and light surface rust.
They came out looking great.
If the rust is pitted it will not totally remove that.
85 Chevy K-20
Old 12-10-2024, 11:49 AM   #97
LockDoc
LockDoc's Avatar
OK, thanks.
Leon
Old 12-10-2024, 11:49 AM   #98
68Gold/white
They don't put the good ingredients in the carb soak chenicals, anymore. The last time I used the "dip" cleaner, the throttle shaft wouldn't move after removing from the dip.
What I do now:
Soak the entire carb in a bucket of gasoline. I usually wait at least a couple of days.
Then I use the spray carb cleaner (Berryman's, usually). I use small brushes, where needed. I use the straw to inject the spray into passages, then blow them out with compressed air.
If there's any corrosion (white powder looking like stuff), I use the Lysol toilet bowl cleaner (the type you apply under the toilet rim). GREAT CAUTION needs to be used when using this stuff in a carb. I pour it in the bowl and only let it set for 1-15 minutes, then rinse it out with hot water. The cleaner will eat away the corrosion, but will also start eating into the carb metal!!! If you don't leave it in the carb long enough to do the job, a second application may be needed.
When done, I thoroughly spray the part with spray carb cleaner.....
68Gold/white is offline   Reply With Quote
Old 12-10-2024, 11:51 AM   #99
LockDoc
LockDoc's Avatar
What I do now:
Thanks for the tip.
Leon
Old 12-10-2024, 12:08 PM   #100
Steeveedee
Steeveedee's Avatar
Not tri-calcium phosphate, tri-cresyl phosphate. Two totally different animals.
~Steven
Simi Valley, CA
