12-11-2024, 03:56 PM | #1 |
Upper Radiator hose with ls1 water pump
Plan to run a ls1 water pump (front vs top hose inlet) and was wondering what upper rad hose options I have.
The radiator has passenger side Upper/Lower inlets. The Truck is a '74 I have seen plent of options for a truck style water pump but can't use those. Even seen a few LS3 engine references but no radiator hose options. Don't mind reducers or splicing if I have too, just want a few options to start with versus standing in front of 500 hanging hoses at Napa.... |
12-11-2024, 05:12 PM | #2 |
Re: Upper Radiator hose with ls1 water pump
On my LS projects I make a wire pattern and head on down to Oreillys and they let me poke around the store room and find a hose that is close. Typically I have to do a bit of trimming to get to work. I'm using 2002 Camaro water pumps. I wouldn't do a spliced hose. Just one more place to leak. Pic of my 68 C10.
12-13-2024, 11:08 AM | #3 |
Yeah, was hoping to avoid that but it looks like that is whats gonna happen. It's not a very complicated bend patterns so hopefully it's easy to find something.
12-18-2024, 12:44 PM | #4 |
I used a Gates #22436 hose and a 90-degree elbow off another random hose with a splice it has been working for 5 years with no issues. My LS is out of a 2002 Firebird. I assume the same water pump as you describe..
Sorry didn't see you have a pass side rad. Maybe this will help someone else down the road. |
12-22-2024, 03:21 PM | #5 |
Ever try these at the splice?
Cleans it up a bunch https://www.summitracing.com/search/...di4yqviyv5xfbp Gates makes them too. |
12-22-2024, 05:16 PM | #6 |
On my 73 Camaro LS3 project I used a splice in the upper rad hose. I also welded a NPT "bung" into the bottom of the slice for the coolant cross over line. I used exhaust tubing that I welded a bead on both ends so the hose couldn't slip off. Never had an issue. Aftermarket splices with a bung are also available.
Pic. |
12-23-2024, 07:31 PM | #7 |
used these a couple times in swaps, never leaked. If you are worried double clamp it, like the standard has become on boats where a leak can sink you.
with steam vent https://www.amazon.ca/gp/product/B0BKRS2GPN/ without https://www.amazon.ca/gp/product/B09FJKPZ4X |
12-31-2024, 07:40 PM | #8 | |
I’m a bit late but maybe this info will help someone… I saved a few pics and info years ago when I was finishing my swap, I ended up with a splice in mine with different hose because I needed to reach the driver side, so no first hand knowledge. Anyway take a look at a gates 22271
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
