#26 |
Re: Clutch Fan Install getting mucho frustrated
Mucho!
Hey man 67 GMC Short Stepside 400 small block, turbo 350. Build thread:http://67-72chevytrucks.com/vboard/s...d.php?t=650603 |
#27 |
This bad boy is going in. I'll take another pic once I get radiator and shroud in.
#28 |
20' Daredevil (Ret)
![]() Join Date: May 2003
I see you have a severe-duty clutch -- once you get the shroud adapted to fit, it should be impossible for that truck to overheat. Looking good!
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
#29 |
Got it done. Doesn't look too bad
#30 |
![]() Join Date: Jun 2002
Way to hang in there! Nice work, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
#31 |
I'll probably paint it semi gloss like the shroud but just sprayed what I had
#32 |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
Yes, nice work. I did about the same, but there's no plastic at all. The fan clutch fins are about 1/2" from the radiator.
#33 |
Idk what the optimum distance is but a half-inch should work. I'm about 5" from radiator but I guess with that "Tunnel Effect" it'll work.
#34 |
All done. 3 and a half inch wide metal strip secured with little piercing screws with loctite. Merry Christmas.
| Bookmarks |
