12-28-2024, 09:22 PM | #1 |
Help Identifying Rear Axle and transmission
Hi guys,
Could you please help with identifying the rear axle in my truck? It's a 69 C-20. I grabbed the best pic I could without it being on the lift. If this is not enough, just tell me what to look for and I'm happy to get whatever's needed. I'm trying to figure out how much lubricant is needed for a change, and it would be good to know this anyway. I also need a little help identifying the transmission that's installed. From the service manual, it looks like there were three different 3-speeds - Warner, Muncie and Saginaw. Is there an easy way to tell one from the other? Thanks! Wes
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" Last edited by BanjoDude; 12-28-2024 at 09:36 PM. |
12-28-2024, 11:10 PM | #2 |
The Older Generation
Re: Help Identifying Rear Axle and transmission
Rear is an Eaton HO52. Is the transmission a three on the tree? .
12-28-2024, 11:20 PM | #3 |
Thank you. Yes sir, it is a 3 on the tree. Am I correct in seeing that it's rated for 5,200 lb?
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" |
12-28-2024, 11:28 PM | #4 | |
Look at the side cover and compare it to the chart. Not sure on the rating.... .
12-28-2024, 11:29 PM | #5 |
This is fantastic. Thank you.
12-28-2024, 11:33 PM | #6 |
No problem. Let us know if you have any other questions.....
12-28-2024, 11:36 PM | #7 |
I did just post one unrelated question here: https://67-72chevytrucks.com/vboard/...58#post9360458 if you happen to know the answer to that also. Thanks so much.
Yesterday, 08:02 PM | #8 |
Okay - so it looks like I have a Saginaw 3 speed. The capacity chart shows that the 3-speeds take 1.75 pints unless they are "HD", in which case they take 3. pints. Does anyone know which transmissions are considered HD?
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again. "For just a little more, you can do it yourself!" Last edited by BanjoDude; Yesterday at 09:36 PM. |
Yesterday, 09:37 PM | #9 |
Also, the bushings on the linkage going into the transmission are 100% shot. Is there a recommended source for those? Anything else I should refresh in the linkage while I'm at it? It is super sloppy, but shifts smoothly still.
Yesterday, 09:39 PM | #10 |
And one additional thing - there is what appears to be a leak at the speedo connection. Is this easily remedied? Not sure how exactly that would seal - perhaps I need a new cable?
Yesterday, 10:56 PM | #11 |
I believe that the HD three on the tree is the Muncie. For my '70 C10 with a 350, the HD Muncie three was standard.
The Muncie also has a drain bolt at the front driver side near the bellhousing (at least mine does). The Saginaw does not, supposedly one can remove the lowest tailhousing bolt as the drain for it.
1970 C10 LWB 350SBC, SM330 Muncie (not saginaw SM326) (on tree), 3.07 open (assumed), PS, PB, Idiot lights |
Yesterday, 11:03 PM | #12 | |
https://67-72chevytrucks.com/vboard/...d.php?t=798067 .
Yesterday, 11:07 PM | #13 | |
There is an "O" ring on the body of the "bullet". Just unscrew the bolt, pull the bullet out and replace the "O" ring. I can't remember if ther is an "O" ring inside were the shaft of the gear fits in or not maybe someone else will chime in on that. You don't have to unscrew the cable. When you screw the bolt back in go easy with it or you might twist it off.... .
Yesterday, 11:18 PM | #14 | |
Yesterday, 11:20 PM | #15 | |
Today, 12:13 AM | #16 | |
