12-27-2024, 07:49 PM | #1 |
Junior Member
Wheel studs
Does anyone know where I can get longer wheel studs for 72 3/4 ton 4x4 I need longer ones because the wheel I have lugs counter sink into the wheel .stock studs are too short and are flush with wheel.i need to have studs to stick out 5 or so threads
12-27-2024, 08:36 PM | #2 |
Re: Wheel studs
I’ve used these guys before . Should have what you need
https://lugnutguys.com/ Edit: Sorry looks like they only sell lug nuts
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
12-27-2024, 08:53 PM | #3 |
Re: Wheel studs
lugnut4x4.com
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
12-27-2024, 10:08 PM | #4 |
Re: Wheel studs
610-227 dorman stock is 610-180
12-27-2024, 10:51 PM | #5 | |
Re: Wheel studs
https://lugnutguys.com/pages/search-...tud-conversion
1970 C10 Custom longbed 350/350 Code:
__ ______|__]\____ ....|___(o)_____(o)_] |
12-28-2024, 01:21 AM | #6 |
Re: Wheel studs
https://www.google.com/search?q=lug+studs+nearby
I'd probably be looking for the correct lug nuts for the wheels. |
12-28-2024, 01:55 AM | #7 |
Re: Wheel studs
Possibly (probably) what franken said. The lug holes look pretty large and not sure if I see a taper for the nut. Sure you don't need a mag wheel lug nut that sleeves into the wheel? Like this https://lugnutguys.com/collections/l...nk-zinc-washer Not sure the exact ones you would need without more info.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 Last edited by Richard; 12-28-2024 at 02:02 AM. |
12-28-2024, 01:28 PM | #8 |
Junior Member
Re: Wheel studs
I have the correct lug nuts .problem is if the studs aren’t 100% straight they won’t go on .stock studs are flush with rim I need a studs that will stick beyond the rim so I can get the studs started.
12-28-2024, 01:38 PM | #9 | |
Junior Member
Re: Wheel studs
12-28-2024, 01:41 PM | #10 |
Junior Member
Re: Wheel studs
Thanks I’ll check them out I can’t afford to get the wrong studs @ 20$ a pop.
12-28-2024, 01:47 PM | #11 | |
Junior Member
Re: Wheel studs
12-28-2024, 01:52 PM | #12 |
Junior Member
Re: Wheel studs
No taper on the rim if studs where a1/4 to 3/8 longer the taper on the nut would Guide the nut into the wheel .
12-28-2024, 04:52 PM | #13 |
Re: Wheel studs
Just reread your post about the nuts you have. You should be able to get longer studs at NAPA or even Autozone .
Just don’t go too long or the cap could bottom out before the wheel is correctly torqued.
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; 12-28-2024 at 04:59 PM. |
12-28-2024, 05:09 PM | #14 |
Junior Member
Re: Wheel studs
Yep that’s what I have they are a tight fit with a 9/16 stud .right now I’m cleaning up the studs and sanding the polish off the rim of wheel.I want to change out the studs because the truck has been in a house fire so might as well put a little longer.
12-28-2024, 05:29 PM | #15 |
Re: Wheel studs
Okay, understand why you want the longer studs now. But, looking at the lug nuts you have- would think the wheel should have a taper at the face of holes. Your lug nuts have a taper under the hex where they seat on the wheel. Unlike the type I linked to.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
12-28-2024, 07:55 PM | #16 |
Junior Member
Re: Wheel studs
They came with washers.
12-28-2024, 11:53 PM | #17 |
Re: Wheel studs
Those lug nuts look very wrong to me.
Yesterday, 11:40 AM | #18 |
Junior Member
Re: Wheel studs
Why is that I have no problem replacing them.
Yesterday, 02:57 PM | #19 |
Re: Wheel studs
Interesting. I thought they were all tapered to locate/center themselves in the hole
