Old 12-22-2024, 01:16 AM   #2426
Gregski
Gregski's Avatar
Re: My Dusty 71 GMCe Electruck
after one too many sleepless nights The Greg made some significant progress on Rev. 2.0 of our input shaft mechanism, using this handy LDR 311 F-112 Galvanized Floor Flange, 1-1/2-Inch, complements of our friends in Vietnam, or as I like to call it the Lexus GS450h transmission plate two big of a hole reducer thingie
here it is as found in our local Ace Hardware store plumbing section
Gregski is offline   Reply With Quote
Old 12-22-2024, 01:18 AM   #2427
Gregski
Gregski's Avatar
just think clutch pressure plate alignment tool
this gets us in the ballpark but it's not a snug fit, we can do better...
Old 12-22-2024, 05:06 PM   #2428
Gregski
Gregski's Avatar
alright, I aint gonna lie to you, it's not a snug fit... yet ! but we got a solution for that
Old 12-22-2024, 09:01 PM   #2429
yuccales
yuccales's Avatar
Is the "Lexus GS450h transmission plate two big of a hole reducer thingie" being used as an alignment tool so you can re-drill those mounting holes?
yuccales is offline   Reply With Quote
Old 12-23-2024, 03:11 AM   #2430
Gregski
Gregski's Avatar
that is correct, but it also required this additional mini adapter aka "rubber band set"
Old 12-23-2024, 08:37 AM   #2431
yuccales
yuccales's Avatar
Gotcha.
Old 12-23-2024, 12:26 PM   #2432
Gregski
Gregski's Avatar
did I mention I was tickled pink when I discovered OUR custom transmission crossmember was going to clear all North, South, East, and West boltuators
Old 12-24-2024, 04:24 PM   #2433
Gregski
Gregski's Avatar
and then it was S&K Steel Time aka SKST
so this is the kind of remnants they have, and at first I thought this frisbie disc would work but turns out it was not sliced straight
Old 12-24-2024, 04:25 PM   #2434
Gregski
Gregski's Avatar
so then I spied this 1/2" thick by 10" wide and about 30" long plate which I had cut into two squares for a crisp Ulysses S. Grant !
Old 12-28-2024, 04:14 PM   #2435
Gregski
Gregski's Avatar
so here's some pics for you to gnaw on whilst I editing the 3rd half of the Input Shaft Lock Out video series, ISLO
the two 1/2" plate cake
final, final assembly will be held down with ocho M10 bolts for super strengthability, making it burn out certified
Old 12-29-2024, 08:15 AM   #2436
72 tigger
72 tigger's Avatar
Very nice and strong machining work!
71 C10
72 K20
72 K10 Super
Kirk
72 tigger is offline   Reply With Quote
Old 12-29-2024, 11:48 AM   #2437
Gregski
Gregski's Avatar
thank you I appreciate that, and on this episode we make sure: "That aint going anywhere!"
GMC Electric Truck Lexus Transmission Plate Success
Old 01-04-2025, 02:42 PM   #2438
Gregski
Gregski's Avatar
so lets level set and regroup a bit, so up to this point for the last year or so I have been driving this truck only on one electric motor inside of that Lexus transmission, this one, commonly referred to as MG2 for Motor Generator 2, and I have put on over 2,200 miles on the truck that way (yeah, I know whooptie do!)
Old 01-04-2025, 02:47 PM   #2439
Gregski
Gregski's Avatar
and what I have done just now is that I have enabled the second electric motor inside of that Lexus transmission called MG1 for Motor Generator 1, so now both electric motors will power the truck
in this latest video we test spinning each motor at a time and then both simultaneously
GMC Electric Truck Lexus Input Shaft Locked Testing
Old 01-04-2025, 05:44 PM   #2440
zicc1835
zicc1835's Avatar
nice..... thanks for clarifying it all "Im level set now" Im sure this is very rewarding when it comes together and you see those wheels spin
zicc1835 is offline   Reply With Quote
Old 01-04-2025, 05:59 PM   #2441
pjmoreland
pjmoreland's Avatar
Exciting progress!
pjmoreland is offline   Reply With Quote
Old 01-04-2025, 06:44 PM   #2442
Gregski
Gregski's Avatar
Originally Posted by pjmoreland View Post
Exciting progress!
thanks, but will my truck be done(ish) before yours?
Old 01-04-2025, 07:14 PM   #2443
LT7A
I really like this truck and it was great to see it (and you) in person, after Christmas. Was hoping to get a ride in the electrons-only pickup but I caught you in the middle of the phase 2 battery replacement. I thought this would be a good time to reread the thread AND get caught up. That's also why you might see me comment on ancient posts. Like this picture. I completely forgot that the cab was originally customized by the Dukes of Hack-ard and the bed painted batmobile style.
Old 01-04-2025, 07:36 PM   #2444
LT7A
Is this who I think it is?
Old 01-04-2025, 07:38 PM   #2445
pjmoreland
pjmoreland's Avatar
Highly likely, as long as the weather is nice
