Old 12-06-2024, 02:53 AM   #51
Richard
Re: Anyone have experience with a rearview mirror backup camera set up?
Like having the regular rear view for driving. Positioning a camera with the same view as the rear view seems kind of pointless to me. Need front/rear cameras to help with parking for my lifted 4x4. I picked up a display to recess into the back of my drivers sun visor. It has 4 camera inputs with trigger wires for each camera, view can be switched manually as well. Monitor also has recording capability. Two cameras were purchased as well to install front and rear. About $70 for everything.
Richard
Old 12-06-2024, 09:42 AM   #52
Rich69shortfleet
Some success. I tried a smaller nut on the string and got it to go about halfway down the A piller. Not sure why it stopped, perhaps just friction on the string. Metal in there has a lot of patina and are no longer smooth surfaces. I will pop a hole into the kick panel area and then try the compressed air method to help move it along.
Rich69shortfleet is offline   Reply With Quote
Old 12-07-2024, 05:33 PM   #53
Rich69shortfleet
So I got the rear camera mounted and ran the video cable all the way up to the cab. I also gave the string with a nut on it a shot with compressed air and I think it went down to the kick panel. I'll have to drill an access hole tomorrow.
I mounted the camera on the lip of the bumper above the license plate. It fit so snug with the license plate light holding it in place I didn't have to drill any holes or use and bolts or screws. This turned out to be the best place and way to mount the camera since my license plate hinges up to allow access to a hidden hitch receiver behind it.
Old 12-07-2024, 10:09 PM   #54
LockDoc
The Older Generation
LockDoc's Avatar
I did some more checking today. The only thing I can see that would be a problem are the ends of the bolts that fasten the end of the dash to the "A" pillar/cowl area. They would catch the string and/or the nuts fastened to the string. There is nothing else in there.
In the last picture you can see the top bolt. There are 3 more below that. So maybe if a guy would remove those first..... Dunno?
Leon
Old 12-08-2024, 08:10 PM   #55
Rich69shortfleet
So I was determined to get at least get a fish line from the top to the bottom. I already had a line down the A pillar but I found I had a LOT of cable from the rear to work with so I thought I'd instead route the wire down the B pillar which would allow me to avoid drilling a hole in the kick panel. I could never get a fish line to go down the B pillar, it would always get stuck at the top rear corner. My boreoscope view was inconclusive about if there was a clear path that way or not. So I returned to the A pillar. I drilled a 3/4" hole by the mirror mount and another just below the edge of the dash in the A pillar lower plenum. I had a nut on the string so I looked inside with my boreoscope and saw the nut resting on the lower dash mount bolt so I used a magnet tool and fished it out through the new hole.
So I have a solid line from the visor hole to the kick panel. I need to get some grommets for the cable holes and then I can route the cable from the kick panel to the mirror mount area. So far so good.
I did have to take the parking brake pedal loose, I couldn't get it out altogether so I just pushed it toward the center to give me enough room to get my 90-degree power drill in there to drill the hole in the kick panel. To be able to move the parking brake pedal assembly I had to take my trailer brake modulator off the dash too as well as the driver's side courtesy light. So, I have to run the cable, connect the power wires and put things back together. I'm having a fabricator make a mounting bracket like JEM made and when done I can mount the mirror/monitor and get it all set up for use.
I'm not sure how exactly I'm going to wire this into the truck. My truck has the original fuse panel which is pretty basic and over the years I've added air conditioning, trailer braking, LED lighting for the box, DRL and a Custom Autosounds stereo and a powered subwoofer. I've got a lot of new accessories on the appropriate circuits so I'm not sure I can fit on another jumper on them but we will seen. Nothing pulls a lot of power, the AC connections are just controlling relays out in the engine compartment which are wired separate to power, but still. I should probably upgrade the alternator as what I have is the original size 37 amp unit. I've never blown any fuses or fuseable links and all the lighting is now LED so that helps lower the power burden.
Old 12-08-2024, 09:05 PM   #56
dmjlambert
dmjlambert's Avatar
Keep up the good work. It is interesting to hear of your progress and see pictures. It would be fun to see a picture of your 90 degree drill.
Old 12-08-2024, 09:49 PM   #57
dagnabbitt
dagnabbitt's Avatar
Originally Posted by dmjlambert View Post
What does the cab light diagram say about the lower hole? Does it need to be drilled to install the cab lights or is it supposed to already be there?
I would assume it is already there, its a diagram of the truck, and not an installation guide. I should take a look myself I think.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 12-08-2024, 10:51 PM   #58
Rich69shortfleet
There was no pre-existing hole on my truck. Maybe they punched or drilled the holes on the assembly line if it was going to get clearance lights?
Old 12-08-2024, 10:59 PM   #59
Rich69shortfleet
Here is a picture of the 90 degree drill. It was a closeout item at HF when I got it. I've only needed it twice but it has worked out great when I needed it.
Also pictured are the two holes I've made for cable routing purposes.
Old 12-09-2024, 01:31 PM   #60
Rich69shortfleet
I found some grommets, two tiny rubber grommets, +$5.00. Sheesh.
Also, when listing grommet specifications online and on packaging almost everyone lists the overall outside diameter and inside diameter. But the most important measurement is the diameter of the hole into which it will fit. The ones I finally found were listed as 31/32" OD and 1/2" ID. I had to measure the groove diameter to make sure they would fit the 3/4" holes I drilled (and they do). Glad I found them locally since buying some online and shipping them would have been crazy for two small rubber grommets. I got the last two the local store had.
Old 12-09-2024, 10:58 PM   #61
Rich69shortfleet
I had a bit of a challenge getting the video cable up through the top of the A pillar where it enters the roof cavity. It took a while but I finally got it around that corner. The end of the cable is stiff, so it did not easily bend around the corner and the pulling wire was just pulling it to the side of the hole at the top and that's where it was getting snagged.
Anyway, I got it in and routed to the mirror mount, that last stretch was easy. Here are the holes with the cable installed and the grommets in place.
All that's left to do now is to connect the power wires and wait for the mounting bracket to be completed. I'll try to get it wired to power tomorrow and test it out. BTW, at the junctions in the video cable where the camera cable plugs into the long cable up to the cab and where the mirror/monitor cable plugs into the power cable and where the long video cable plugs into the power cable I am using self-sealing shrink tubing to not only seal the joints but to help keep them firmly connected.
Old 12-10-2024, 08:00 PM   #62
Rich69shortfleet
Well, everything is mostly buttoned up and wired in. It works! Just waiting for the mounting bracket to be completed. Then I need to spend some time working on the settings. The screen image is great.
When poking around the fuse panel to wire the mirror/monitor in I saw and was reminded that I had wired the AC into the pre-existing slot in the fuse panel for AC which was not originally wired in as my truck was not built as an air truck. So, the switched and not switched power outputs in the fuse panel are feeding the stereo and the new mirror, not a huge burden on that circuit.
I still might upgrade to a 55 amp alternator. I haven't had any issues with lights or stereo acting like they are power starved, but it would still be a good upgrade for when I might have AC, stereo (including a self-powered subwoofer), mirror and headlights all running at the same time. That all sounds like a lot for a 37 amp alternator to handle.
Old 12-11-2024, 07:08 PM   #63
MikeB
MikeB's Avatar
Originally Posted by Rust_never_sleeps View Post
You could perhaps just use your smartphone as the screen with sum'n like this: https://www.amazon.com/License-Green..._df_B06Y3TSWLK
I thought it looked pretty good, but then I read the buyers' comments.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- sold
1981 C10 Silverado LWB -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 12-14-2024, 02:13 AM   #64
Rust_never_sleeps
Rust_never_sleeps's Avatar
Yeah, that was the typical alphabet soup brand on the River, first thing I found. Could yet be someone reputable making a similar product, or could be that BT just doesn't work well with a lot of metal in the way
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 01-04-2025, 10:13 PM   #65
Rich69shortfleet
I FINALLY got the bracket my fabricator worked up for me. It fit fine. If the weather ever changes back to something approaching tolerable I'll finish the installation.
Old 01-05-2025, 12:42 PM   #66
MikeB
MikeB's Avatar
Originally Posted by JEM Motorworks View Post
Here is my solution to a front/rear facing camera.
That's some incredible work!
Kudos also to Rich69shortfleet.
Mike
Old 01-06-2025, 10:53 AM   #67
Rich69shortfleet
Kudos actually belong to JEM for the suggestion of this AutoVox system and for info on how to make the monitor adapt to the stock mounting system. Can't wait to have my system fully mounted and functional. But it is 7 degrees out today so it is going to be a while yet before I'll be working on it again. I also have a new alternator to install and some wiring upgrades to perform.
Old Yesterday, 10:17 PM   #68
Rich69shortfleet
Finally wrapped up the install.
Old Today, 12:26 AM   #69
'68OrangeSunshine
'68OrangeSunshine's Avatar
Sure looks nifty.
