11-28-2024, 01:00 AM | #26 |
Re: Explorer 8.8
Got the QA1 front installed. Wasn’t impressed by the instructions or fit. Hopefully it aligns well and drives good.
1951 Truck, LS1/4L60 1964 Suburban, current project 2014 Silverado daily driver 1953 Westerner "canned ham" trailer, rebuilt 1974 Prowler trailer, rebuilt |
11-28-2024, 01:02 AM | #27 |
Re: Explorer 8.8
I love the amount of dynamic ackerman that's in there!
Straight impossible to get that with a factory crossmember. Should have a very nice turning radius, and responsive steering.
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS 1977 Silverado: Shortboxed & dropped, potato-potato V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag Lotus Super 7 Replica: Scratch-built street-legal rollerskate |
11-29-2024, 10:35 PM | #28 |
Re: Explorer 8.8
I hope you’re right. I had several issues installing this. I’m a little concerned with the steering setup. The angle on the steering rack seems excessive and the adjustment sleeves are all the way in. I’m hoping it aligns well and drives good. Won’t know for sure until I get an alignment, which will be quite a while.
11-30-2024, 01:11 AM | #29 |
Re: Explorer 8.8
When the steering rack is closer to the centerline of the wheel, dynamic ackerman increases. The angle of the steering arms in an indicator. More ackerman is always good. Put it this way: I am envious.
If the tie rods are adjusted all the way in, and you need more adjustment, cut the tie rods shorter by whatever you need to correct the adjustment. This is often done when installing dropped spindles (grin).
12-02-2024, 11:56 AM | #30 | |
Re: Explorer 8.8
I was also concerned about the rod end at the spindle since it requires 4 custom aluminum pieces per side, while the POL rack uses a stock tie rod. I believe these are in place to correct bump steer. I have a problem with bump steer in my 51 and I really want to avoid it on this build. I will be using drop spindles and setting the Suburban as low as I can, my steep driveway will be the limit. Has to be able to get in the garage.
12-02-2024, 04:11 PM | #31 |
Re: Explorer 8.8
Bumpsteer is 100% determined by the location of all the pivots - ball joints, inner bushings, rack width and height. It's not always easy to change it.
Show me a straight-on front view of everything, and I can pretty much tell you if it's all in the ballpark or not. I am super passionate about steering and suspension (suspect Aspergers here).
12-02-2024, 04:27 PM | #32 | |
Re: Explorer 8.8
12-02-2024, 07:18 PM | #33 | |
Re: Explorer 8.8
12-02-2024, 07:21 PM | #34 |
Re: Explorer 8.8
That’s a good question about the steering arm at the spindle. Unfortunately I don’t have any stock spindles to compare. I do know that QA1 has some different spacers at the spindle depending on your wheel size and spindle type. You can seem them in this page of the instructions.
12-02-2024, 09:09 PM | #35 |
Re: Explorer 8.8
Oh. I did not see that those were heim joints.
It looks like the spacer is "ideal" according to the instructions, with removing the spacer only to fit smaller wheels. Fit the bigger wheels if you can.
12-03-2024, 11:13 AM | #36 |
Re: Explorer 8.8
I have some 15" wheels on while I work on the Suburban. Once I feel it's ready to drive I'll switch to the 22" transport wheels and add the spacers.
01-15-2025, 01:57 PM | #37 |
Re: Explorer 8.8
Well , I haven’t made much progress on the rear suspension. Had multiple issues with the GMSS trailing arm crossmember and some issues with the QA1 parts.
GMSS Crossmember - This really just doesn’t fit. It’s a 3 piece design, which should make it easier to install. I had 3 issues. 1: the main part of the crossmember was wider than my frame rails, so I had to spread them apart. 2: The side brackets were so wide they stuck out of the frame rails 1/2”. These had to be cut down especially with the already tight fitting center section. 3: The anti squat brackets don’t fit, they hit the floor brace. GMSS sent me new brackets, these only have 4 holes for adjustment and they’re spaced unevenly. They’ll work but I’m not impressed. I wouldn’t recommend this for anyone looking to swap their trailing arm crossmember. Tinworks or Porterbilt are better options. First photo shows brackets upside down, second shows the brace they hit, the brackets are about 1” too tall On the QA1 kit I got the Coilover brackets included need to be installed right where I already have a bolt in C notch. I probably could have cut up the 2 and welded them together but I contacted QA1 and I was able to purchase their Cnotch brackets that have the coilover mounts built in. Another $300 but I think it’s a better solution.
01-15-2025, 02:02 PM | #38 |
Re: Explorer 8.8
Been working on the grill since I’m waiting on parts.
Made it much more complicated than I should have I cut all the mounts off the letters and welded a stiffener to the back of the letters, hoping to make it look more like it was floating. Unfortunately it was still too flimsy so I had to make new brackets for the ends. Should have left the stock brackets alone like everyone else. Still unsure if I’ll use this or stock.
01-15-2025, 04:07 PM | #39 |
Re: Explorer 8.8
What if you remove the rest of the mounts off the letters, and add a black mesh behind, so the letters look like they are "floating" on the mesh?
01-15-2025, 05:15 PM | #40 |
Re: Explorer 8.8
I might mock that up and see what it looks like. If I did that, I would cut out the center support also.
01-15-2025, 09:15 PM | #41 |
Re: Explorer 8.8
I was thinking remove the center, but keep the letter bar. It would be easier to mount and secure the letters.
Yesterday, 01:59 PM | #42 |
Re: Explorer 8.8
Sorry for your complications, but the work sure looks great.
