Old 01-26-2025, 04:21 AM   #7
Classic Bowties
Always on the hunt...
Re: Van/RV Tilt column floor shift conversion sleeve
Originally Posted by StingRay View Post
It is not a cast metal part like an original so it is not possible to make it identical. It is worth noting that once the shift lever is gone this is only a cosmetic piece. It had a mechanical purpose with a lever and needed to be very strong. That requirement is gone when the shift lever is gone. An original floor shift non tilt column has just a plastic sleeve like this here as well.
StingRay, regarding that last part of your above quoted info in bold, could it be possible that you are thinking of a later model year or application of steering column? As an fyi, all 1967-72 C/K model four speed manual non-tilt steering columns used the same p/n 3902569 pot metal extension (bell/bowl) housing with no shift lever, see below pics from our old saved folder archives. Mel
***For any return/past customers & friends***
Before sending of any funds, please wait for a confirmed total and instructions for
sending as our payment account info has been changed as of Jan. 2023. Thanks...
Classic Bowties is offline   Reply With Quote
