Old 01-28-2025, 04:33 PM   #1
Classics Fan
Cigarette Lighter and Blower Relay Wiring Questions
I have a 1971 Jimmy that I discovered the cigarette lighter had stopped working. Related to that I believe after investigating and doing some research, recently I noticed a burning smell when the heater blower speed was set on high. It goes away on lower settings. Anyway when I looked at the cigarette connection on the fuse panel I found that connector (orange wire) had some melting. I replaced the connector but the red wire at the back of the lighter still doesn’t have power.
That led me to doing some research and I found the first photo below on a different forum post. It shows both an orange wire and red wire at the CIG fuse panel connection. The second photo is my panel. You can see it has only the orange wire (blue arrow) however, there is also a separate red wire (yellow arrow) I found disconnected that I thought might be the power to the lighter. I connected it to the fuse panel at the post that is directly below the cluster connector (red arrow, it has unswitched power) but still nothing at the lighter.
Anyone have any ideas on what could be going on here? The lighter worked until it didn’t. I hadn’t removed or disconnected any wires at the fuse panel. One thing I found strange is the CIG connection is unfused. Is there a fuse or fusible link somewhere else? I tried to trace the red wire back from the lighter but it disappears behind the dash panel and I didn’t want to pull the panel until I had some answers to my questions.
Thanks in advance for any insight.
Classics Fan is offline   Reply With Quote
Old 01-28-2025, 10:20 PM   #2
HO455
HO455's Avatar
Re: Cigarette Lighter and Blower Relay Wiring Questions
Its my experience that GM typically doesn't fuse the cigarette lighter which can be problematic. I had a lighter short out internally while driving down the freeway in my old S10.
I don't smoke and never used the lighter but out of the blue one day smoke starts billowing out from the dash area where the lighter is. Needless to say I made a sharp right to the side of the road and started tearing wires out of the dash.
I believe that the cigarette lighter and the high speed fan power can share the same connector at the fuse panel. The link explains the circuit as well as has the wiring diagram.
http://67-72chevytrucks.com/vboard/s...d.php?t=705082
RIP Bob Parks.
Old Yesterday, 04:00 PM   #3
Classics Fan
So to follow-up and close this post: today I looked closer at the disconnected red wire near the fuse panel and to me it just had to be the lighter wire. I reconnected it to the same blade as yesterday that I thought was constant 12 volts, turned the ignition to Run and was happy to find power to the lighter. I then connected the red wire to the piggyback connector on the orange wire (high blower relay), installed an inline 20 amp fuse to protect them and called it good. I feel much better having this relatively high-amp wire protected. No more melting!
Old Yesterday, 06:15 PM   #4
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Cigarette Lighter and Blower Relay Wiring Questions
The lighter circuit is protected by the large fusible link in the main harness by the battery.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old Yesterday, 06:27 PM   #5
HO455
HO455's Avatar
No melting is good! Best to keep the smoke inside the wires so everything works.
RIP Bob Parks.
Old Yesterday, 07:57 PM   #6
Classics Fan
If that’s the case wouldn’t the blower relay circuit also be protected since they get power from the same blade on the fuse panel? If so why did I experience melting on the relay fuse panel connector?
Old Today, 11:22 AM   #7
HO455
HO455's Avatar
The nature of fuseable links is that they are a slow blow type of fuse. Meaning that if it is rated for 30 amps once exposed to 35 amps it may take as long as a minute to blow where a fuse would blow in a matter of seconds.
In your case both the fuseable link and the wiring at the fuse block were heating up simultaneously. You were only able to smell the wires in the cab.
I would recommend doing a physical inspection of the fuseable link by bending or flexing the fuseable link looking for stiff or ridged areas. When a fuseable link fails it shouldn't show any signs of overheating. So flexing and stretching the link should allow you to detect any melting of the conductors inside.
Another possibility is that someone in the past replaced the factory fuseable link with an incorrect wire that doesn't protect the harness.
I posted some information on fuseable links in post 469 in the link
http://67-72chevytrucks.com/vboard/s...or#post8564169
RIP Bob Parks.
Old Today, 02:14 PM   #8
Classics Fan
Good information, thanks for sharing. I have just enough electrical aptitude to scrape by with help from others like yourself.
I inspected the fusible link and it seems to be in satisfactory condition. Supple without any outward signs of damage and it’s smaller than the wire it’s connected to, though I don’t know the gauge of either. Nonetheless at least the blower relay and lighter circuits are protected now with the fuse installed.
Old Today, 03:24 PM   #9
Rust_never_sleeps
Rust_never_sleeps's Avatar
Isn't the blower circuit supposed to run through the fuse labeled "HEAT" below the radio terminal?
A 14Ga wire to the heater switch (allegedly brown) on my diagram
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old Today, 03:45 PM   #10
HO455
HO455's Avatar
On non-AC trucks the Heat fuse supplies 12dc positive to the blower fan in all speeds. As shown by the brown wire the drawing. See link for drawing
On AC trucks the heat fuse only supplies 12dc positive to low and medium speeds. (The brown wire again) High speed comes from the fuse box (Orange wire) like shown in the photos above. Link also shows AC addendum to main harness drawing.
RIP Bob Parks.
