Old 01-11-2025, 06:57 PM   #5176
zicc1835
zicc1835's Avatar
Re: What did you do to your truck today.The 3rd chapter
finally got him inside today
zicc1835 is offline   Reply With Quote
Old 01-12-2025, 11:44 PM   #5177
Sheepdip
Sheepdip's Avatar
Well; it wasn't today but a couple of days ago I got my freshly painted hood and cowl cover back on Otis and all adjusted up... so back to normal again.
Sheepdip is offline   Reply With Quote
Old 01-19-2025, 05:01 PM   #5178
Casper42
Casper42's Avatar
static drop: 2" front/3" back
'72 C10 Cheyenne SWB North Carolina truck for 50 years, 72k original miles, Medium/Hawaiian Blue, 3 owners - one for 40 years, garaged kept, original: sheetmetal, undercarriage, moldings, glass
New - engine rebuild at 65k in 2015, one repaint in 2010, new front bumper, houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-19-2025, 11:59 PM   #5179
3757chevy
3757chevy's Avatar
Perfect
'67 Stepside (bought 1997-sold 2021) '96 Bronco Eddie Bauer (inherited 2010)
MIKE
3757chevy is offline   Reply With Quote
Old 01-20-2025, 04:08 AM   #5180
'68OrangeSunshine
'68OrangeSunshine's Avatar
No pix, but today, a friend and I attacked my Starter problem on a '71 GMC Jimmy: 350 SBC/SM465/NP205/D44 Front, 12-Bolt rear, 3.73 w/Auburn posi.
[No-Start Gripe.]
We had to pull the Header on the passenger side to get to the Starter. Since I want to paint the Hedders white, anyway, we'll have to pull both. We got the passenger side off. Took the Starter into O'Reilly's for test and check. Flunked the Solenoid test. No surprize since it was installed 4/2008. [Lifetime Checker Auto warranty.] I had used an aftermarket Accel solenoid. That was shot -- the cap was loose, Solenoid is trapped behind the header so it got a lot of vibration and heat cycles in 16 years. I have a NIB bendix-type solenoid on the shelf. Gonna hook that on and go back for another test tomorrow or Tuesday.
Meanwhile to get the drivers side header free, I'll have to disassemble the whole Z-Bar and Clutch Pushrods and Clutch Fork business.
We ran out of daylight today.
Old 01-20-2025, 06:53 PM   #5181
brandnew72
The only thing I completed today was achieving excessive levels of frustration, lol. Craftec Tonneau is nigh impossible to get into the groove once any two sections are in. Gave up for the evening. Can't use any screwdrivers or tools because if you slip, cover gasket will be toast. Heat only makes it worse. Heckuva way to close out another wise successful day in regards to rust repair and stake pocket filling.
brandnew72 is offline   Reply With Quote
Old 01-22-2025, 11:53 PM   #5182
Sheepdip
Sheepdip's Avatar
It was a nice day today, so I took Otis and got the oil changed, then took him to the handwash and got all the barnacles off.
Old 01-23-2025, 12:39 AM   #5183
'68OrangeSunshine
Got a rebuilt Starter from O'Reilly's today. Rolled over to Harbor Freight to get a new creeper. If I like the weather, I could reinstall the Starter tomorrow.
Old 01-23-2025, 10:13 AM   #5184
1970cstblazer
1970cstblazer's Avatar
Red face Re: What did you do to your truck today.The 3rd chapter
Installed the rechromed/restored T handle and nice original control assembly on the Blazer's liftgate. With all new correct bolts and screws, new strikers, NOS latches, and misc parts the total was around a grand to make it like OEM new.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD Kelsey Hayes wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 01-25-2025, 06:17 AM   #5185
'68OrangeSunshine
I got the front end of my K/1500 '71 Jimmy up on jackstands, so I'd have more ''noseroom'' when pulling the underworld from my rig.
Got the replacement Srarter from O'RAP. Pure China Black. Swapped out a shelf goodie, a Mexican bendix-type solenoid for the Asiatic one that came with the device. Better quality.
The USA-made Accel solenoid was burned out after 16 years.
The ''spare'' Hedder gaskets I thought I had were also used. So, tomorrow, I'm picking up a fresh set of Hedman Hedder gaskets from Don's Hotrod Shop, which, sadly, may be folding.
Old 01-25-2025, 12:16 PM   #5186
jaros44sr
jaros44sr's Avatar
Sweet do you have build thread ?
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 01-25-2025, 12:19 PM   #5187
1970cstblazer
Unfortunately, no.
Old 01-26-2025, 05:00 PM   #5188
brandnew72
3 out of 4 cab supports repaired! Luckily there was enough good metal on them to patch by cutting up new sets.
Old 01-26-2025, 07:05 PM   #5189
KQQL IT
At the body shop.
KQQL IT's Avatar
Replace bearings and brake pads in the oriellys parking lot on my kids C10 count.
About welded them together, had to use a puller to get the rotor off.
Moments from disaster i think.
Old 01-26-2025, 08:21 PM   #5190
Steeveedee
Who Changed This?
Steeveedee's Avatar
^ I bet there's another 30 feet in that bearing...
~Steven
Simi Valley, CA
Old 01-26-2025, 09:07 PM   #5191
KQQL IT
At the body shop.
KQQL IT's Avatar
At least 30ft, about killed the spindle if it went anymore. 2 new bearings seals and a bit of grease. Looked like it was packed with Vaseline from the PO- only talked about repacking these since we got it in November
Old 01-26-2025, 09:45 PM   #5192
Steeveedee
Who Changed This?
Steeveedee's Avatar
Good catch, in any event. One of my sons had a '70 Dodge Dart that got sideswiped and totaled due to its age. We bought the salvage ($89, ) and fixed it ourselves. He had to have the brakes and lamps inspected to relicense it for the road. The shop that inspected the brakes didn't point out that the right front wheel cylinder was leaking, and improperly adjusted the front wheel bearings on the driver's side (left hand threads). He drove a long canyon road coming back from his university, and complained that it was all over the road. Those bearings were toast. I replaced all the front wheel bearings and wheel cylinders just before he went back north to school. I'd've had the "mechanic" roasting on a spit if my son had suffered any injuries from such shabby "repairs". This was at a state-licensed repair facility.
~Steven
Simi Valley, CA
Old 01-27-2025, 07:28 PM   #5193
zicc1835
zicc1835's Avatar
10-4 on roasting on a spit
Old 01-27-2025, 08:15 PM   #5194
LNP
Thats a new one on me I worked as a diagnostic tech in garages for over 30yrs and my 70 Chllenger is my baby for 47yrs. I have never run across a left hand thread spindle nut. Lug nuts on mopars yes just not spindle nuts. I am glad to hear your son was unharmed. I'm afraid if it was my son he wouldnt have made it to the spit roaster.
Harley
1969 Chevy C-10 Long Bed, 350cid, 700R4
LNP is offline   Reply With Quote
Old 01-27-2025, 10:12 PM   #5195
Steeveedee
Who Changed This?
Steeveedee's Avatar
'70 was the changeover year, if I understand correctly. Spindles were left hand thread since the Dodge bros days.
~Steven
Simi Valley, CA
Old 01-28-2025, 10:30 AM   #5196
LNP
I had heard of lefthand spindle nuts on 20's and 30's vehicles just never ran across one. Learn something new everyday. Not sure what you meand by the Dodge Bro days they died in 1920 so they wouldnt have been here for the 60's and 70's.
To the OP I apologize for hijacking your thread
Harley
Old 01-28-2025, 02:41 PM   #5197
scf100
scf100's Avatar
went to a local brewery
1970 2WD Blazer 454
1972 C-10 Extended Cab 350 SBC
scf100 is offline   Reply With Quote
Old 01-30-2025, 01:44 PM   #5198
Orange Crate
Orange Crate's Avatar
I didn't even know I had this. It was in a junk hardware can, pulled it out and thought wow that's kool! A few minutes with some silver and now I'm ready for a knap.....matches up pretty nice with the newly made switch bezel .....
72 K20 Custom Camper, D60, 14BFF, full roller 406 TPI w custom built ECU and yes..it has tow hooks...and a 5 speed
Orange Crate is offline   Reply With Quote
Old 01-31-2025, 09:54 PM   #5199
SRU1436
New tires and new powered coated rims. I have hubcaps for them, I’m driving it a little before I double check lug nut torque. Once I double check lug nut torque I’ll put on the hubcaps. I’ll post another picture once hub caps on are. I went with 15x8 instead of my OEM 15x6.
SRU1436 is online now   Reply With Quote
Old Yesterday, 05:16 PM   #5200
brandnew72
Rear suspension torn apart for adding 2" angled blocks, new adjustable panhard bar that kounts to the passenger trailing arm and half of the shock mount relocation kit installed. Didn't have the "want to" to drill out the rivets to move the top mount today. NO vibration noticed so that's nice. 53 year old suspension eventually gave up the u bolts lol. But great day they fought.
Also got my bolt in c-notch installed and welded as an added means of support. I had no clue that so many rivets had to be drilled out on the drivers side. Got it done though.
