#26 |
Who Changed This?
![]() Join Date: Jan 2013
Re: Sway bar thickness handling differences...
I don't know what the stock bar for my truck is, but it used to be fine, even after putting the taller cabover camper shell on. Handling went south when I had to put Firestone Trans-Force tires on it, because Michelin doesn't make the 16.5" wheel size tires my truck takes. It has an uncomfortable amount of oversteer with the Firestone tires, even with 10 psi more in the rear tires. I guess I could experiment more with tire pressures. That would cost less than a stabilizer from Hellwig.
#27 |
![]() Join Date: Mar 2024
HO455, You bring up a good point about the Suburban (and maybe the G-Van) potentially as another junkyard source for the stabilizer bar. When I get my parts book I will see what it indicates about interchange with the C10 and post that info. What is the outside diameter of your Suburban stabilizer bar, by the way?
Ellensbrother 1970 C10 — Blue Lou 1977 C10 — Copper Kid 1986 GMC Sierra 1500 — Brown Pearl 1999 Chevy Suburban 1500 — Silver Dollar 2011 GMC Yukon XLX 1500 — Black Max Ellensbrother's Albums |
#28 | |
![]() Join Date: Feb 2016
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#29 |
As promised, here is more information on the heavier factory OEM stabilizer bar that should bolt on to a 1967-1972 C10 using all four original mounts. Using the parts manual for 1973-1978 Trucks, the GM part number 334583 is listed as the heavy duty stabilizer shaft for 1973-1978 C20 and C30. For completeness, a few more notes: The stabilizer bar for 4WD has a different shape than 2WD to clear the front differential. Also, I plan to replace the bushings using new ones (1.25") from Energy Suspension, Prothane, or Moog. Am seeing all of these bushing options available on Amazon. Am hoping this reference helps others.
#30 | |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#31 |
At the body shop.
Red urethane- racecar...
AhhaHa
" That didnt make it any newer " " Dont antique the equipment " |
#32 |
When I added a 1 1/16" bar to my 2500 back in the '90s, it did reduce the body roll, but by how much is difficult to recall. In the 2000's, I swapped it for a 1 1/4" bar and it does take corners and off-ramps much flatter than the smaller bar.
I'm reluctant to use the word "handling", when talking about a truck. I guess if you have a short-half lowered to car height with wide, low profile, sticky tires and have the weight under 3000# you could. Oh well, people do what they like to do with their cars
'67 GMC 2500, 292, 4spd, AC |
#33 |
>>Firestone Trans-Force tires...................16.5" wheel size tires my truck takes. It has an uncomfortable amount of oversteer with the Firestone tires, even with 10 psi more in the rear tires.<<
Unless you were starting with under inflated tires, the extra pressure WOULD increase oversteer. I know several that use the Trans-Force truck tire and I have them on my class-C motorhome. It's a high mileage highway truck tire. If you noticed oversteer with the new tire, you should have dropped the pressure. I never go even close to the 80#, unless I expect to be hauling something really heavy.
#34 | |
Who Changed This?
