Old 02-09-2025, 10:44 AM   #26
dmjlambert
dmjlambert's Avatar
Re: Comp Cams
Originally Posted by BAD1916 View Post
After my boss had a comp cam go flat in a 66 Shelby with less than 50 miles I found this while looking at cams. The new cam from Holman and moody was sent here and broken in. Way less stress on startup without the worry of the break in on the cam. Worth the money in my opinion.
https://www.camresearchcorp.com/cam-...haft-break-in/
That is interesting, good find.
Old 02-09-2025, 03:02 PM   #27
MikeB
MikeB's Avatar
Re: Comp Cams
Jones Cam Designs uses only the best of the best cores, and sells American made lifters. I can't think of anyone else I would trust. A flat tappet cam I bought from Mike Jones many years ago was a work of art compared to the mass market one-size-fits-all guys. Everything from lobe lift to event timing measured spot-on, not +/- a few thousands or a few degrees like a Comp cam I had in the shop. http://jonescams.com/
And these days even roller cams may not be the answer. Did you guys see the Roadkill Garage episode where a brand new Comp roller lifter essentially fell apart after the engine had been run for only a few minutes? Comp apologized, said it was a known problem(!), and sent them a higher quality set. Nice to know they sell some roller lifters that work and some that fall apart, huh?
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is online now   Reply With Quote
Old 02-09-2025, 03:17 PM   #28
geezer#99
geezer#99's Avatar
Re: Comp Cams
That break in only works if your block has the exact same lifter bore spacing and no cam walk.
Old 02-09-2025, 03:35 PM   #29
realsteelGM
realsteelGM's Avatar
Re: Comp Cams
Thanks for the option.
"gotta love something that works without a computer"
realsteelGM is offline   Reply With Quote
Old 02-09-2025, 03:41 PM   #30
geezer#99
geezer#99's Avatar
Re: Comp Cams
You could try these for cams.
https://egge.com/
https://www.kanter.com/
Old 02-09-2025, 03:42 PM   #31
realsteelGM
Re: Comp Cams
I live next door to Alaska in the Yukon, it's a real challenge to get quality machined parts here. On top of it we pay twice the price, not America's fault, our greedy government. So it's a one shot deal after replacing crank, bearings and a full rebuild.
Old 02-09-2025, 03:44 PM   #32
realsteelGM
Re: Comp Cams
Old 02-09-2025, 03:48 PM   #33
realsteelGM
Re: Comp Cams
Cam walk is a new term for me, could you explain that?
Old 02-09-2025, 03:51 PM   #34
MySons68C20
MySons68C20's Avatar
Re: Comp Cams
Moving back and forth on the horizontal plane....
MySons68C20 is online now   Reply With Quote
Old 02-09-2025, 04:01 PM   #35
realsteelGM
Re: Comp Cams
That's exactly what I'm looking to avoid. No second chance with an inferior cam set-up as it's the most crucial element of break in. I'll look into the "Jones" company.
Old 02-09-2025, 04:20 PM   #36
geezer#99
geezer#99's Avatar
Re: Comp Cams
Another highly recommended.
https://straubtechnologies.com/categ...emi-custom-bbc
Old 02-09-2025, 04:23 PM   #37
realsteelGM
Re: Comp Cams
In a flat tappet cam there needs to be cam walk, unless your referring to a roller cam.
Old 02-09-2025, 04:31 PM   #38
realsteelGM
Re: Comp Cams
How long ago did you install the the comp cam that cratered at break in? At this point I've got about 3 grand into the rebuild and need a good cam to put into this, what would you recommend?
Originally Posted by Willshook View Post
I’ve used hundreds of CompCams with never an issue. Of course, any company can have a bad part, and for flat-tappet cams having the valves adjusted correctly, the right assembly lube, the right oil, and the right break-in technique is crucial.
Lobe width outside of the contact point of the lifter doesn’t do anything but increase rotating mass; it doesn’t make it more “beefy”.
Originally Posted by Joyridin View Post
Before you install the next cam, you probably want to watch this video. They actually take a flat tappet lifter on a grinder after the blue it up and you can see the problems. He shows they were Crower lifters.
At this point, I would spend the dollars and put a roller in it.
https://www.youtube.com/watch?v=MbRjAMhCEJk
What cam set-up is in your rig? How long?
Old 02-09-2025, 05:13 PM   #39
weq92f
weq92f's Avatar
Re: Comp Cams
I'm in the roller camp. I didn't want to have issues so I went retro fit with all COMP. This was back in 2018/19. The lifters I purchased with the roller setup were absolute trash. I ran them until early 2020 before swapping them out with Howards. No problems since and I run it around quite a bit.
COMP 11-422-8
COMP 854-16 (replaced)$$
Howards 61161
Hth,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-09-2025, 06:03 PM   #40
HalfBrit
Re: Comp Cams
Is your motor still running with the cam set-up? I priced one here in Yukon, Canada $2100 plus springs and timing assembly.
I wish I could tell you yes. My initial engine rebuild turned into a multi year frame off project, which has yet to be finished.
HalfBrit is offline   Reply With Quote
Old 02-09-2025, 06:04 PM   #41
Willshook
Re: Comp Cams
wrong thread...
Willshook is offline   Reply With Quote
Old 02-09-2025, 07:01 PM   #42
twoskies
twoskies's Avatar
Re: Comp Cams
Started with i believe with a precision power flat tappet cam, stock cam, lost oil pressure after 100 miles, tore down, went with a Howards cam Slight upgrade from stock, well that one didnt make it through break in, collapsed lifter, Howards cam,s come with warranty, called them right away with motor still cooling down, They're were Great , Customer service was very good, they warrantied the cam and set me up with a roller cam and lifters, never looked back, almost 4000 miles on build and still Great, i also have a Very Good Machine Shop where im at, the Shop covered the Difference in Price and sent the cam back both times, so i wouldnt have to wait on the refund, I agree with Most Here, if you go Flat Tappet, look for something old stock, Ebay, Facebook, but i wouldnt hesitate to go with another roller cam in any build
Good Luck with your Build
A Little Better Every Day
Cancer Survivor, most dont know what they have until its gone, appreciate everything
twoskies is offline   Reply With Quote
Old 02-09-2025, 08:26 PM   #43
Myself
Re: Comp Cams
Re-read that........it DID NOT wipeout during break-in. Break-in went fine and we drove the truck. Then right at about 5000 miles I started getting an odd backfire upon heavy acceleration. From that point to completely undriveable was maybe 50 miles of driving while I tried to figure out the issue.
As somebody else posted I never had any issues with Crane Cams. It would be tough to find a new old stock cam but I bet they're out there. This was probably 15 years ago. With all the flat tappet issues I will only be going with roller cams from now on. The last flat tappet build I did was a mild 350 and I found a barely used Manley cam and lifters on Ebay.......that one is still running strong! I also have my son's Lincoln 462 sitting in my shop. We bought brand new Rhoades lifters and sent the original cam to Schneider in Cali for a regrind........we felt that was a safer bet than new garbage.
Myself is offline   Reply With Quote
Old 02-10-2025, 12:35 PM   #44
realsteelGM
Re: Comp Cams
COMP 11-422-8
Howards 61161
Hth,
-Kevin
The majority is telling me comp cam set-ups are not worth buying.
Old 02-10-2025, 12:44 PM   #45
realsteelGM
Re: Comp Cams
COMP 11-422-8
Howards 61161
Hth,
-Kevin
Thanks for the feedback, I'll look into Howards.
Old 02-10-2025, 12:59 PM   #46
MikeB
MikeB's Avatar
Re: Comp Cams
Originally Posted by geezer#99 View Post
Forgot about him. Good advice!
Had a buddy order a custom grind from Straub. Before he even installed the cam, he decided he wanted one with less duration. Straub ground him a new one and let him return the old one for a full refund.
Mike
Old 02-10-2025, 01:37 PM   #47
MikeB
MikeB's Avatar
Re: Comp Cams
Over the years, I've used a Comp roller cam (in 2004) and a GM HT383/RamJet cam (in 2015) in SBC builds using 86-up roller cam blocks. Both installations used new GM LS6 roller lifters.
You can buy this kit or the parts individually. It's a good way to go, but not inexpensive.
Complete kit minus cam retainer plate: https://www.gmperformancemotor.com/parts/12371056.html
On another note, you will not beat a GM cam for reliability. There are several available, from stock L31 Vortec truck engine to cams used in SP350 and SP383 crate engines.
https://www.gmperformancemotor.com/category/SB169.html
Mike
Old 02-11-2025, 01:49 PM   #48
realsteelGM
Re: Comp Cams
Great service.
Old 02-11-2025, 01:52 PM   #49
realsteelGM
Re: Comp Cams
Crane went out of business apparently in 2009.
Old 02-11-2025, 07:49 PM   #50
Getter-Done
Getter-Done's Avatar
Re: Comp Cams
Seems like I remember this.
I just forgot.
I will remember this now.
Well at least for a few more months.
The early bird gets the worm,
85 Chevy K-20
