Old 01-29-2025, 11:09 AM   #76
Kalums
Re: 71 GMC engine swap-arino
Originally Posted by MARKDTN View Post
Guy on Ebay has a set of bolts for $29
https://www.ebay.com/itm/26570646780...EaAvkJEALw_wcB
Looks like mostly 3/8-16 stuff that you can get at the hardware store. The lower pulley to balancer is 3/8-24 x 1" I believe. I would just use what you have on your truck or order new in a kit.
My truck currently only has these dampener pulley bolts (3), 2 for the Alternator and 4 for the WP/Fan pulley anything that mounts the brackets to the block/heads... I don't have. If you know where I can get the "sets" left and right that would be awesome, otherwise I'm going to be hanging out at ACE for a few hours😅
The one you listed is I believe only for the driver's side which is definitely a start, thank you. Only major issue I for see is... I have no idea where any of the bolts go *facepalm*
Kalums is offline   Reply With Quote
Old 01-29-2025, 12:17 PM   #77
MARKDTN
I used '95 5.7 Suburban as a reference, but not seeing a diagram online. There is probably a way online to see a parts diagram but I am not finding it. You may have to sweet-talk your local GM dealer part guy to show it to you on the screen to see where all the bolts go and how long they were.
Did you get the water pump pulley? Any braces? It's all the little things that make these serpentine setups cost more if bought incomplete. You may be better off going to a junkyard or pick-a-part where you can get all the bolts and braces. You will need another p/s pump or at least a pulley anyway (and it requires a proper tool to remove the pulley, a jaw puller just destroys it as you see).
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 01-29-2025, 02:32 PM   #78
Kalums
Is the P/S pulley press fit then? I take it it is... Good for longevity... Bad for replacement... Found a rebuild kit for the pump I got yesterday, found a pulley too just haven't gotten it yet. You are right about those braces... What a pain to locate, the guy I bought the brackets off says he doesn't see them in his "pile" either...
Old 01-29-2025, 04:33 PM   #79
MARKDTN
If I was in your shoes, I would go to your local pick-a-part (you do show having one in Phoenix) and buy a matched power steering pump with the bracket, A/C bracket, water pump pulley, and crank pulley. 4.3 Blazers/S10 and 4.3/5.0/5.7 Pickups/Suburbans in the 90s are good sources. Camaros and Firebirds too. Corvette is also nice but less likely to find and uses a shortish aluminum water pump that can't add a fan to it (forces you into electric fans). Van ones are not as good I don't think, could be wrong. Take it off yourself so you get all the bolts and braces. You have an alternator core I think and an a/c compressor core so you don't need those. You will need a new water pump from whatever vehicle you use. You probably want to avoid Vortec V8 engines 96 and up. I think you can resell what you have and still come out ahead on trying to piece it together. Good luck.
Yes, the p/s pulley is press fit. You need a special tool to take it off. I have seen people disassemble the pump and leave the shaft and pulley together to rebuild a pump, but if I bought a used pump and it wasn't covered in oil I would just run it. There is likely a difference in the threads on the high pressure hose from your existing pump to that one but maybe the fitting interchanges?
EDIT-A Serpentine setup is nice, but not really necessary. You really only need a crank pulley to use your original pulleys and add a/c. IMHO the CS130 alternator and R4 compressor are not as good as a 12SI alternator that will fit on your existing alternator bracket and add a Sanden a/c compressor with brackets when you go to Vintage Air. R4 compressor brackets won't support a Sanden Compressor but the later 4.3 S10 Blazer ones do have a pad mounted a/c compressor. Not sure it's as good as a Sanden but the Nippendenso version is pretty good. The offshore version is junk.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 01-29-2025, 05:24 PM   #80
Kalums
Copy that. "wait and get the right/good/complete setup". *thumbs up* will do.
Old 01-31-2025, 07:54 PM   #81
Kalums
No real progress today, went to the salvage yard for some other tinkery stuff like a spring shackle... Waiting on the ARP exhaust manifold bolts and Amazon hasn't sent me a replacement 2604 intake yet... Don't get an intake manifold from Amazon... What a pain.
Old 01-31-2025, 10:30 PM   #82
Steeveedee
Who Changed This?
Steeveedee's Avatar
I've always bought stuff like manifolds from local speed shops. Online stores are all about moving product, but if you're standing at the counter looking a person in the eye, things are different. For instance, I bought sport wood steering wheel from LMC It went to caca and cracked right out of warranty. If one can take the part back to the seller and hold up the offending product, especially with potential customers in the room, things get handled much more to one's satisfaction...without, I'll say, going all Karen about it.
~Steven
Simi Valley, CA
Old 01-31-2025, 10:52 PM   #83
Kalums
I actually really like the speed shop I have locally(I know of 3 but 1 is way closer to me than the others) ... My ONLY issues is his prices are 15-20% higher than anywhere else, don't get me wrong I am all about supporting local, the guy who runs it is super knowledgeable and nice/cool guy... I just can't justify the extreme price difference if it is not an immediate need. And no he is not too keen on price matching... Or he just doesn't like me enough *laughs*
Old 02-01-2025, 12:05 AM   #84
Kalums
Does anyone know what part number this alternator mounting bracket is or what I would even call it to search for it?
Old 02-01-2025, 07:52 PM   #85
Kalums
Cleaned up the serpentine brackets, got all the bolts + other needed assorted stuff for the brackets from the salvage yard (no alternator in the bracket or I would have taken pictures) changed out the blinker switch. Kids were helping, so I had fun. Not a lot of progress but fun for sure.
On a side note, can someone explain the conversion to a "CS" alternator like I'm 5 years old? Please... I've been reading alot the threads on how to do it... I'm either super confused about what is needed or go they into the reasons why the newer tech is better. I know the newer tech is better. I just need a simple explanation as to how to get it done. Also there so many conflicting opinions about what size wire(s) and I'm not 100% sure what all I need to change. I was planning on putting the 12si in the truck as it is now and redid the wires from the 10dn to the external regulator and the battery (mainly the ones going across the radiator) to 12 & 10 ga respectively... But I've seen things saying I'll need 8 ga wire... Should I just upgrade all the wires to 8 ga? Etc... Like I said please explain it/give me a step-by-step like I'm 5 yo... All the information is making my brain atrophy. And does anyone know what alternator fits these brackets? Or is there a kit to mount a 12si (for later)
Update: Ok after re-reading for the 10th time, I think I finally understand what I need to do for the "upgrade" however when I do rewire do I need to use 10,8,or 6ga wire from the Alternator to the battery and what about from the "T" junction to the fuse box? Also I'm still a little confused as to what resistor(rating) I will need as my truck doesn't have the dummy light. Is there anything I need to do about the current amp meter?
Old 02-03-2025, 05:41 PM   #86
MARKDTN
If you must have a CS130 alternator-and once again I don't consider them to be a good paperweight-make sure it has the improved cooling fan. There are wiring instructions out there for it. You will basically use the 2 wires from the old voltage regulator. You will want to bypass your ammeter gauge as it will not handle the higher current and wiring could get hot and do bad things. I think painless has a kit that has a CS alternator pigtail and some wire to go to the battery. I would use an 8ga wire from the back of the alternator to the battery in addition to the existing wire (and get rid of the ammeter and either add a voltmeter or change to an "idiot light" for charge). Any additional high-amperage accessories like electric fans or big stereo should pull power from the battery and the new wire not the existing truck wiring. That way you don't overtax the truck wiring.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 02-03-2025, 05:58 PM   #87
Kalums
That, Sir sounds like a great idea. I did like you said and got the whole matching set off one serpentine system, my local salvage yard was nice to me and let me just swap my clean brackets (from the other picture, I'm pretty sure he is going to sell them online) for a matching set with all the pulleys and matching power steering pump(needs rebuilt but has a good pulley). Got a good GM dip stick and tube for $15 while I was there too. Not especially keen on using the CS130... but for the life I can't find a "conversion" bracket for the serpentine Cs130 bracket to cs144 or the 12si. So far this has been really fun, my kiddos probably think I'm crazy but when I say I'm headed to the salvage yard, I've never seen 2 teenagers put on their shoes faster... *laughs*
Old 02-06-2025, 12:43 AM   #88
Kalums
No real progress today. What are the pros and cons of a Fel-pro 1205 S-3 vs the standard 90314-2 intake gasket? I guess I mean what are the issues/pros of blocking off the exhaust crossover? I live in Phoenix... I doubt I need "added heat" to warm up my fuel/carb... *shrugs* but idk... You guys tell me. Also do I need to plumb water lines from the rear of the cylinder head back up front? My intake doesn't have a rear coolant crossover but it does have a place to drill & tap for the circulation lines to back up front...
Old 02-08-2025, 01:54 AM   #89
Kalums
Well... It begins... I got most of the periferals/accessories off. Lossened the engine mounts. More tomorrow, hopefully.
Old Yesterday, 08:54 AM   #90
MARKDTN
My computer would not let me in the last few days, thought the site was compromised. Anyway, what setup did you get? I am assuming earlier 5.7 with the CS130 alternator and an R4 A/C compressor? I didn't even think about that the late Blazers have a different alternator and the pad mount A/C compressor.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old Yesterday, 10:38 AM   #91
Kalums
So... He did have the "other" style with the alternator swapped and the larger compressor on the drivers side. Only issue was that truck was in a front end collision and when I got the driver's side bracket almost off... It was cracked. So I went with another set of what I already had that matched. Funny thing though the bracket I had originally ( V6-S10) only had one bolt at the bottom of the driver's side near the harmonic balancer the one off the Suburban has 2 and a 3rd bolt in the driver's side head, so 5 bolts on the driver's side bracket all together, instead of the 3 in my old bracket. I still consider it a win. I also figured out what you meant by the "upgraded" CS130... What idiot thought it was a good idea to build an alternator with out a fan on the front... Whose "nifty" thought was that? They deserve a swift kick in the nards... Twice. Salvage yard wanted $75 for a "core" on the Alternator and I can get a new( not reman) from a local guy for about $120 with a 3 year warranty, it think they are still China made but... The has been around for the last 20 years I know of *shrugs* I haven't had a chance to look up the delco alternators WITH a fan yet but that is on the list.
On a side note, do you know if our power steering pumps will mount on this bracket? I know I need to swap the pulley, but mine is not leaking in anyway... And appears to have the needed bolt holes on the front of pump...I honestly wasn't keen on trying decipher correct hose/ends just yet.
Old Yesterday, 10:43 PM   #92
Kalums
Which intake manifold gasket? All Fel-pro #s 1205 s-3, 1206, 1255, 1256, 1266? Or "standard" MS93317?
