Old 01-27-2025, 11:46 PM   #1
Extended Power
Extended Power's Avatar
Anyone have before/after results for CPP 1” drop springs?
Looking at the space between the rear tire to fender, and the front tire to fender distance, I’d like to drop the front another inch or two.
I already have 3” dropped A-arms, and don’t want to screw up the wheel alignment too bad, but sitting 1” lower would look better...
Do the 1” springs give 1” drop?
Is it possible that the stock springs are already weak, (factory BB truck) and by installing the 1” drop spring may have no drop at all?
Thanks!
"If it ain't broken, fix it 'till it is!"
Extended Power is offline   Reply With Quote
Old 01-29-2025, 08:18 PM   #2
Casper42
Casper42's Avatar
Re: Anyone have before/after results for CPP 1” drop springs?
perhaps this might help a little - I just installed CPP 2" drop springs in the front of my '72 C10 and it dropped me exactly 1-1/2 inches. It's only been one week so their might be more settling in the future.
'72 C10 Cheyenne SWB North Carolina kept for 50 years, 75k original miles, Medium/Hawaiian Blue paint, 3 owners - one for 40 years & garaged kept. Original: sheetmetal, undercarriage, moldings, glass, immaculate unrestored bed.
New - rebuilt engine at 65k in 2015, one frame-on respray in 2010, front bumper, blue houndstooth seat, carpet, 8 inch rally wheels on 275-60R-15, LED lighting. - Semper Paratus!
Casper42 is offline   Reply With Quote
Old 01-30-2025, 10:51 PM   #3
Extended Power
Well that’s good to know for sure.
I could possibly drop it an inch with a torch I guess...it would be a lot faster than pulling the front end apart just to find that the springs dropped it 1/4” or something.
Old 01-31-2025, 10:24 AM   #4
72c20customcamper
72c20customcamper's Avatar
Your oem springs have most likely dropped all by themselves . My 68 with 3 inch drop springs went down about two and a half inches . It’s not an exact science
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 01-31-2025, 10:44 PM   #5
3drburb
I think most here would suggest trimming the springs instead of putting a torch to them.
Torching the spring could weaken them and they could break while you are driving also you are taking a guess as to what height torching them will give you.
3drburb is offline   Reply With Quote
Old 02-01-2025, 11:40 PM   #6
Extended Power
If I saved up, I’d just do the Wilwood Pro spindles an 14” brakes.
Not sure if I’d like the 2 1/2” extra drop though.
Old 02-03-2025, 05:52 PM   #7
bnorth
I put CPP 1" springs in the front of my 6 cylinder truck last summer. They dropped it 0" so there was at least an inch of sag in the stock springs already.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
Old 02-03-2025, 08:42 PM   #8
weq92f
weq92f's Avatar
This will be my next major upgrade. In fact, I've already purchased a new set of Wilwood Pro Spindles to replace my existing 2 1/2" drop units from a member here a few years ago. Now it's the bigger number bits I need to source...been looking through the SummitRacing 'scratch-n-dent' section as often as I can...
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
Old 02-11-2025, 07:22 PM   #9
Extended Power
-Kevin
Being at the right place at the right time! Nice score!
