New Member
![]() Join Date: Dec 2022
Irritating electrical problem
Fairly new to me: kinda rough 1970 K-10 197K miles, Older Goodwrench crate sbc w/HEI, sm465, np205, ps, no a/c, wiring and electricals appear in pretty good condition.
The snag: Ignition "ON" and selecting a turn signal: The instrument panel's turn signal indicator lights go wonky when the headlights are also on. The actual outside turn signal lights themselves work just fine regardless if the headlights are on or off. Likewise, the headlights work fine whether the turn signals are on or off. ONLY the instrument panel's indicator lights (including the high beam indicator light) malfunction when the headlights are "ON," AND the turn signal switch is activated to either side (L or R). The malfunction seen is a dimmed pulsing of one or both (if high beams are selected) instrument panel turn signal indicator lights, or blinking of the wrong side (L or R) inst panel turn signal indicator light, and usually accompanied by a pulsing of the high beam indicator (if hi's are selected) in rhythm with the selected turn signal blinking. Also rotating the headlight switch knob to dim the panel lights makes the turn signal indicator lights blink on the wrong (L or R) side... Again, this is an instrument panel indicator light problem only; all the actual outside lights work perfectly all the time. I replaced the high beam selector switch, but no change in the malfunction was seen. I'm thinking this is a grounding problem as opposed to a "short." Sooooo..... if this IS a bad ground, where would a fella go looking for the problem.... Or, would experienced owners like you look for something completely different? Headlight switch? PC board??? I'm hoping someone's seen this before, and can guide me in the right direction, before I totally disassemble the whole truck as I'm prone to do... ![]() Thanks a million in advance for your help friends! -Lee |
#2 | |
![]() Join Date: Jul 2000
Re: Irritating electrical problem
Turns out the ground side of the turn signal and high beam indicator lamps were all tied together, but weren't grounded to the panel itself, the body, or the frame. I never did figure out how they lit at all, but grounding the bulbs to the dash fixed the problem. So, check those grounds! On my 69, I think there is a single ground trace that runs around the printed circuit. Make sure that trace is grounded well. There should be very little resistance (0.5 ohms or less) between that point and the battery negative terminal.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
#3 | |
New Member
Thanks again, -Lee |
I had the exact same issue .My turn signals indicators were wonky on my 68 but only with the high beams on . Sometimes they just glowed other times if I turned the right blinker on the left indicator would blink and the right one would stay dark and it was reversed if I put the left blinker. Outside the lights worked normally . I tried grounding the dash instrument pod that did nothing . I then checked all the grounds on the truck . It ended up being the ground at the radiator support on the drivers side . Cleaned up the contact put some electrical grease on it a retightened the bolt with a new washer. Works perfectly now
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. Last edited by 72c20customcamper; Yesterday at 08:18 PM. |
New Member
#6 | |
I edited my post
Mark 72 c20 custom camper Husky edition, 66 SS396 Chevelle 1964 Hawk, 63 Avanti,62 lark 1969 AMX , 1968 c20 stepside ,85 K20 1977 Suburban sold 68 anniversary. |
New Member
Awesome! I bet that's my culprit too! Thanks, Mark!
1970 K-10 1972 K-5 (disassembled) 1953 3100 and a few old vettes Most everything ^^^^ needs to be rebuilt... |
The Older Generation
Here is a pretty good thread on ground strap locations. http://67-72chevytrucks.com/vboard/s...d.php?t=422234 .
#9 | |
New Member
#10 | |
Keep us posted on how it works out for you.
New Member
Will do! Just ordered a 5 strap set from Amazon for under 10 bucks.... will be here tomorrow!
Thanks, again! I appreciate all you guys helping me!!!
Who Changed This?
![]() Join Date: Jan 2013
It's quite pleasing how people rally around a problem a member has and helps them fix it! It's what makes this place so great.
