Old 02-12-2025, 04:53 PM   #451
Richard
Re: 1971 K10 Stepside - Getting a Roller Roadworthy
Originally Posted by pjmoreland View Post
I noticed that the front output has what I would consider excessive in-out (axial) play. The yoke is clamping the bearing to the shaft adequately. The bearing is sliding in and out in the housing by almost 1/8". I pulled the bearing out, and I can still see machining marks on the housing bore, so it doesn't appear that the bore is worn. It seems that the seal housing is the only thing that constrains the bearing from moving, and it has a decent size gap between its inner surface and the bearing. Is this slop normal??
Great job on the work here. I enjoy following along. The front seal housing does hold the bearing in place with the snap ring on bearing. Think you will notice the small bit of movement going away once the yoke is installed and tightened up.
Richard
Old 02-12-2025, 05:45 PM   #452
pjmoreland
pjmoreland's Avatar
Thank you, and I hope so, although I noticed the play before I removed the yoke. The nut was very tight. Just as a test, I reinstalled the seal housing without a gasket, and I reinstalled the yoke and nut, and the play was reduced significantly.
pjmoreland is offline   Reply With Quote
Old 02-15-2025, 12:54 PM   #453
pjmoreland
pjmoreland's Avatar
I believe I found a large contributor to the end play on the NP205 front output. The snap ring on the bearing is worn significantly on both sides. It has an angle worn on the back of it in the shape of the bevel that is in the hole in the case. It also has a step worn on the front where it contacts the seal retainer. I got a new snap ring, and it has a larger O.D, as well, so that should give more contact area.
Old 02-16-2025, 01:33 AM   #454
pjmoreland
pjmoreland's Avatar
Spent some time today assembling components on the dash:
Speaker
Radio
Heater wiring
Ignition switch
Old 02-16-2025, 01:36 AM   #455
pjmoreland
pjmoreland's Avatar
Glovebox
Ashtray
Wiper motor screw
Old 02-16-2025, 01:43 AM   #456
pjmoreland
pjmoreland's Avatar
Also, today I took the NV4500 tail housing over to a friend's house to borrow his mill to make the needed modifications to make it work with the NP205:
Rear shift rail clearance notch
Idler gear shaft nut clearance notch
Input shaft seal housing screw clearance
Extended seal housing bore by 1/8"
Old 02-17-2025, 01:24 AM   #457
pjmoreland
pjmoreland's Avatar
Today was a long day of working on the truck. Started off with a litte work on the NP205 while I wait for a new front output bearing to arrive:
Replaced rear output seal
Installed new rear yoke (1310)
Replaced front output seal
Painted new front yoke (1310)
Old 02-17-2025, 01:27 AM   #458
pjmoreland
pjmoreland's Avatar
Next I spent a little time wire wheeling some parts that I will be painting with leftover epoxy paint that I will have from a batch of dummy filler necks I'll be making this week.
Old 02-17-2025, 01:33 AM   #459
pjmoreland
pjmoreland's Avatar
The next project of the day was to start the process of replacing the 2wd main shaft in the NV4500 with a 4WD version. Several components are a press-fit onto the factory shaft but a slip-fit on the replacement, so there was a lot of puller usage. Started by removing the tail housing and the top cover. Then removed the 5th gear and shift fork.
Old 02-17-2025, 01:38 AM   #460
pjmoreland
pjmoreland's Avatar
Here's the driving fifth gear removed.
Then the speedometer tone ring had to be pulled off. It was on there super tight, and it had to be pulled a long way before it loosened up.
Old 02-17-2025, 01:40 AM   #461
pjmoreland
pjmoreland's Avatar
The driven fifth gear also had to be pulled off. Confirmed that it is indeed a slip fit onto the new main shaft.
***EDIT*** The driven fifth gear ended up being a press fit onto the new main shaft. ***
Old 02-17-2025, 01:42 AM   #462
pjmoreland
pjmoreland's Avatar
Removed the input shaft next. Four bolts and a little tapping with a rubber mallet, and it was out.
Old 02-17-2025, 01:47 AM   #463
pjmoreland
pjmoreland's Avatar
The main shaft assembly could then be lifted out of the case. It was heavy and awkward.
The gears down in the bottom of the case look good, and they spin smoothly.
The rear main shaft bearing was pressed on, so time for more pulling. Had to run to a hardware store in the next town over that closes an hour later than the local one to get some couplers to allow the puller to reach all the way to the bearing.
Old 02-17-2025, 01:51 AM   #464
pjmoreland
pjmoreland's Avatar
Disassembled the main shaft assembly next. There were a few stubborn snap rings, and one synchro plate on the front of the shaft that had to be pulled off. Had to grind down the tips of the puller jaws to fit in the narrow gap.
Old 02-17-2025, 01:53 AM   #465
pjmoreland
pjmoreland's Avatar
Here are the old and new shafts side-by-side.
I reinstalled the main shaft components onto the new shaft, but had to stop there because I had to order a new rear bearing. It should be here on Tuesday.
I'm tired!
Old 02-17-2025, 10:12 AM   #466
loudchevy
loudchevy's Avatar
Awesome work, I love the large helical gears in these boxes. Just pure beef
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 02-17-2025, 11:34 AM   #467
pjmoreland
pjmoreland's Avatar
Thank you. Apparently these transmissions aren't very sporty to shift, but that's just fine on a vehicle like this.
Old 02-17-2025, 03:38 PM   #468
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
You make it look easy
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 02-17-2025, 03:39 PM   #469
pjmoreland
pjmoreland's Avatar
My knees would say differently. That's what I get for doing this work on the floor.
Old 02-19-2025, 12:39 AM   #470
pjmoreland
pjmoreland's Avatar
Spent the last two evenings making dummy filler necks, but I did have enough epoxy paint left over to paint these parts.
Old 02-19-2025, 10:30 PM   #471
pjmoreland
pjmoreland's Avatar
Installed a new bearing and snap ring on the NP205 front output, and the excessive end play is gone. Now there is only about .005" of end play. The transfer case is now ready to go in the truck.
Old 02-20-2025, 12:59 AM   #472
pjmoreland
pjmoreland's Avatar
Did some reassembly of the transmission. Replaced the input shaft seal. Installed a new rear bearing on the main shaft. Reinstalled the main shaft and the input shaft. Checked the main shaft end play, and it was too tight, so I had to order a shim kit.
Old 02-20-2025, 03:32 PM   #473
Ol Blue K20
Progress is happening!
Dale
Old 02-20-2025, 03:34 PM   #474
pjmoreland
pjmoreland's Avatar
It will be nice to have a drivetrain sitting in this truck after who knows how long without one
Old 02-20-2025, 11:32 PM   #475
Ol Blue K20
Yes, it will be. I've been driving Blue for a week, it feels great.
Dale
