Old 01-28-2025, 10:44 PM   #26
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: Sway bar thickness handling differences...
I don't know what the stock bar for my truck is, but it used to be fine, even after putting the taller cabover camper shell on. Handling went south when I had to put Firestone Trans-Force tires on it, because Michelin doesn't make the 16.5" wheel size tires my truck takes. It has an uncomfortable amount of oversteer with the Firestone tires, even with 10 psi more in the rear tires. I guess I could experiment more with tire pressures. That would cost less than a stabilizer from Hellwig.
~Steven
Simi Valley, CA
Old 01-30-2025, 06:53 AM   #27
Ellensbrother
Ellensbrother's Avatar
HO455, You bring up a good point about the Suburban (and maybe the G-Van) potentially as another junkyard source for the stabilizer bar. When I get my parts book I will see what it indicates about interchange with the C10 and post that info. What is the outside diameter of your Suburban stabilizer bar, by the way?
Ellensbrother
Making the World Better One Truck at a Time
1970 C10 — Blue Lou
1977 C10 — Copper Kid; 1986 GMC Sierra 1500 — Brown Pearl; 1999 Chevy Suburban 1500 — Silver Lining;
2011 GMC Yukon XLX 1500 — Black Max
Ellensbrother's Albums
Ellensbrother is offline   Reply With Quote
Old 01-30-2025, 09:09 AM   #28
HO455
HO455's Avatar
It's 1-1/4".
RIP Bob Parks.
Old 02-09-2025, 06:39 AM   #29
Ellensbrother
As promised, here is more information on the heavier factory OEM stabilizer bar that should bolt on to a 1967-1972 C10 using all four original mounts. Using the parts manual for 1973-1978 Trucks, the GM part number 334583 is listed as the heavy duty stabilizer shaft for 1973-1978 C20 and C30. For completeness, a few more notes: The stabilizer bar for 4WD has a different shape than 2WD to clear the front differential. Also, I plan to replace the bushings using new ones (1.25") from Energy Suspension, Prothane, or Moog. Am seeing all of these bushing options available on Amazon. Am hoping this reference helps others.
Ellensbrother
1970 C10 — Blue Lou
Old 02-09-2025, 10:19 AM   #30
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
I've used the Energy Suspension ones on my trucks and used the included lube and have never have had a squeak..
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 02-09-2025, 11:14 AM   #31
KQQL IT
At the body shop.
KQQL IT's Avatar
Red urethane- racecar...
AhhaHa
KQQL IT is online now   Reply With Quote
Old 02-09-2025, 04:00 PM   #32
RichardJ
When I added a 1 1/16" bar to my 2500 back in the '90s, it did reduce the body roll, but by how much is difficult to recall. In the 2000's, I swapped it for a 1 1/4" bar and it does take corners and off-ramps much flatter than the smaller bar.
I'm reluctant to use the word "handling", when talking about a truck. I guess if you have a short-half lowered to car height with wide, low profile, sticky tires and have the weight under 3000# you could.
Oh well, people do what they like to do with their cars
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 02-09-2025, 04:20 PM   #33
RichardJ
>>Firestone Trans-Force tires...................16.5" wheel size tires my truck takes. It has an uncomfortable amount of oversteer with the Firestone tires, even with 10 psi more in the rear tires.<<
Unless you were starting with under inflated tires, the extra pressure WOULD increase oversteer.
I know several that use the Trans-Force truck tire and I have them on my class-C motorhome. It's a high mileage highway truck tire.
If you noticed oversteer with the new tire, you should have dropped the pressure. I never go even close to the 80#, unless I expect to be hauling something really heavy.
Old 02-09-2025, 04:54 PM   #34
Steeveedee
Who Changed This?
Steeveedee's Avatar
Started out new with 70 in the rear and 60 in the front.
~Steven
Simi Valley, CA
Old 02-11-2025, 09:43 AM   #35
Ellensbrother
Attached is a reference diagram being used to find the sought-after part, whether it be Aftermarket, OEM-new/NOS, or junkyard. The earlier diagram was updated to specify 'stock height'.
Ellensbrother
1970 C10 — Blue Lou
Old 02-13-2025, 08:51 AM   #36
Ellensbrother
Here is more on the search for this part in case it helps others: The systematic search for an aftermarket part has not borne fruit. Specific steps taken include a) web searches using both 1967-1972 and 1973-1978 Chevrolet/GMC model series; b) consulting this forum, of course c) consulting technical contacts at these sellers: CPP, Summit, CJ Pony Parts; Brothers/Holley. Have made an inquiry at GM Service Parts and awaiting a response. Checked eBay for used parts, which of course could prove fruitful, but has not yet. Next step is to reach out to the Salvage/Used Market. Will provide further updates when we have more results/conclusions to share.
Ellensbrother
1970 C10 — Blue Lou
Old 02-13-2025, 12:08 PM   #37
binford
Active Member
Originally Posted by SCOTI View Post
Just look for a 73-87 1.25" OE front bar. They're very common under 3/4 & 1-ton trucks.
Awesome info thanks
I can set a search with pickNpull and it will notify me when it is set in the yard.
Don't ever see suburban's of that vintage anymore.
Now if the weather would cooperate!!
binford is online now   Reply With Quote
Old 02-13-2025, 12:28 PM   #38
70STOVEBOLT
70STOVEBOLT's Avatar
Originally Posted by Steeveedee View Post
I don't know why the heck I couldn't get it at Hellwig's site, but could find it by the link to sdtrucksprings. Same part number! I got into a chat with someone but they were taking so long to respond to my question about fitment on my truck, since it has a 1T frame, I cancelled out- had to go give the dogs their lunch. I'm betting that the frame widths and so forth are the same, but I'm going to verify that before I order a bar. I was sort of hoping that there might be some variation in sizes, but it appears that there is only one part number.
This is off-topic, but I see in your signature, your gear ratio is 3.56? Is that correct or is it a typo?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 02-13-2025, 05:05 PM   #39
Steeveedee
Who Changed This?
Steeveedee's Avatar
Yes. That's the standard ratio when a 400 engine and 400 trans are ordered.
~Steven
Simi Valley, CA
Old Yesterday, 07:14 PM   #40
connorm
I have a 1970 GMC C/2500 that I added an 1-1/4" sway bar too and it made it handle much better. Southcity mentioned that the bench seat could be make it hard to stay in place if you get the suspension dialed in. To me the body roll made it hard to stay in place on the bench seat but after the sway bar it made it easier to stay planted in the seat. I also want to put the disclaimer that I treat my truck like a 3/4 ton and don't expect half ton handling out of it. If you are wanting to really get it to handle them my advice might not directly apply.
On a related not I put Ridetech adjustable shocks on it was able to adjust the rebound which made a noticeable difference. It felt much more stable when I got it where I wanted and I did feel a difference in the corners. I went from newer stock replacements to these and I think the neutral feel of the adjustable shocks was comparable to the factory shocks but the stiffer setting helped keep it level in the corners with no ill affects on straight road bumps.
connorm is offline   Reply With Quote
Old Today, 01:45 AM   #41
58 Special
Active Member
Maybe need to use the seat belt. No judgement intended.
58 Special is offline   Reply With Quote
Old Today, 05:29 PM   #42
Stanco
Stanco's Avatar
I picked up this sway bar from the Modesto Pick-N-Pull last Sunday for $43.99 plus $1.99 core charge. There was a 1978 and a 1979 C20 almost next to each other and both had the 1-1/4 inch sway bar.
The square body trucks have become very popular so now is the time to get these sway bars before these trucks disappear from the yards.
After sandblasting and paint.
Stanco is offline   Reply With Quote
