Old 02-14-2025, 04:37 PM   #301
Chaparralman1974
Chaparralman1974's Avatar
Re: "BUILD: 1970 C10 LWB--->SWB “Jumping Cholla”
Looking great Scott! You are making a ton of progress. Are you going to run the wire bundle up on top the firewall like the factory? I am thinking about doing that, but I don't like how the ignition wire comes down the center of the firewall to get to the distributor if that makes sense.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 02-14-2025, 05:37 PM   #302
loudchevy
loudchevy's Avatar
Clay
The picture of the engine bay in my last post has everything for the engine wired in it. I sealed up the channel on the top of the firewall so there was no place to route wires in. In this pic you can see where I ran my wire loom for the coil, tach, and electric choke behind the engine/top of the transmission to right under the distributor. Then in another loom I ran the oil pressure and water temp sender wires to those sensors and routed it adjacent to the frame rails. The black split sleeve loom helped blend all the wires into the black frame and wheel wells.
I went a little crazy on zip ties, but they make everything look clean and organized. I still want to wrap the wires showing coming out of the fuse block a little better at some point as well.
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 02-15-2025, 09:46 AM   #303
Chaparralman1974
That looks clean Scott! I may try that rather than go over the top of the firewall. What did you use to seal up the edges of the fuseblock? Is that seam sealer?
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 02-15-2025, 10:07 AM   #304
raggedjim
raggedjim's Avatar
Nice work on the wiring in the engine bay. It looks really clean.
raggedjim is offline   Reply With Quote
Old 02-17-2025, 09:50 AM   #305
loudchevy
loudchevy's Avatar
Clay
This is what I used around the fuse block. I have plenty left if you want a couple of strands.
https://www.eastwood.com/ew-flexible...-bk-2-lbs.html
Thank you! I'm pretty happy with how it turned out.
Scott
2003 Tahoe Stock
Old 02-17-2025, 09:58 AM   #306
KevinK7
KevinK7's Avatar
Indeed, that firewall/engine bay looks VERY clean
Looks like Eastwood is relabelling "3M Strip Caulk", ...great stuff for sure
'68 C20 Utility 396 4sp (BuildThread: http://67-72chevytrucks.com/vboard/s...d.php?t=806904 )
'68 C10 50th
KevinK7 is offline   Reply With Quote
Old 02-17-2025, 10:07 AM   #307
loudchevy
loudchevy's Avatar
Just a few things got wrapped up this weekend. I dropped the starter and got the power and solenoid wired, finished routing the rear light wires to the back cross member, and I finally got the parking brake installed.
I had to modify the cable on the parking brake a little bit as I tucked the exhaust up and that interfered with the stock routing. I ended up making a new passenger side bracket from some 1" flat stock and welded a threaded rod on the end to replace the long rod that way hitting the exhaust. Or course I couldn't find the clamp that holds cable to the parking brake assembly, so I had to order a new one. I'm sure I'll find mine after it gets here. I had found the bolt for it, but the clamp wasn't with it. I'm sure I put it somewhere safe I get a picture one night this week.
Hopefully some lighting parts will show up this week so I can get the grille bolted on the front and see some bright lights and blinking
Scott
2003 Tahoe Stock
Old 02-17-2025, 10:10 AM   #308
loudchevy
loudchevy's Avatar
Thanks! Ya it's pretty much the same as the 3M stuff.
Scott
2003 Tahoe Stock
Old 02-17-2025, 12:00 PM   #309
pjmoreland
pjmoreland's Avatar
Great progress. Hooking up the battery will be a big milestone, and it looks like you're getting close.
pjmoreland is online now   Reply With Quote
Old 02-20-2025, 03:37 PM   #310
loudchevy
loudchevy's Avatar
Just got the front windshield and rear glass installed. They look great! I paid an auto glass company to do the job. It was cheaper for them to install and provided the glass and rubber seals than it was for me to buy the glass and rubber alone, so it made sense to pull the trigger and have some pros do it. 2 dudes showed and it took no more than 20 mins to do both front and rear installs.
Lights and bezels get here tomorrow
Scott
2003 Tahoe Stock
Old 02-20-2025, 03:43 PM   #311
loudchevy
loudchevy's Avatar
Getting there piece by piece!
Scott
2003 Tahoe Stock
Old 02-20-2025, 04:56 PM   #312
Chaparralman1974
I am going to call the same guys for mine! Thanks for the referral Scott!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 02-20-2025, 05:11 PM   #313
loudchevy
loudchevy's Avatar
Clay
You bet man!
Scott
2003 Tahoe Stock
Old Yesterday, 09:52 AM   #314
loudchevy
loudchevy's Avatar
Progress weekend! Baby stepping to the finish line.
I got all my front lights installed and the wiring harness connectors crimped and plugged in yesterday.... and they actually all work! Low/High beam, parking lights, fender lights, turn signals. Pretty satisfying to turn them on.
Got the dash pad bolted on so the whole dash is starting to come to life. Tested the lights on the gauges and they're good as well. I installed some door switches for the courtesy lights. I think I need to check the ground on them as they stay on even when the switch is pressed (maybe need to scrap some paint off where they thread into the jamb?). Also tossed on the dome light but still need to splice that connection into the courtesy light wiring on the drivers side.
The AAW kit is fantastic, all the connectors are super easy to crimp (with the correct tool) and slide into the end connections for a super clean finish. The wiring project has been very enjoyable to me, almost therapeutic. It was great to start with a clean canvas for the install.
The inner grille shipped with all my lights/bezels so I got to work bolting it to the outer piece. I saw in IronCanine's build thread a post talking about the (7) sections on the inner grille https://67-72chevytrucks.com/vboard/...&postcount=362 being black so I grabbed a black paint marker and colored mine to match. I think it looks great with the black separating the silver sections.
Scott
2003 Tahoe Stock
Old Yesterday, 09:54 AM   #315
loudchevy
loudchevy's Avatar
Couple pics of the completed front minus a bumper.
Next up will be getting the doors/windows finished up. I have some new regulators from AMD and new glass/weather stripping coming from Precision coming this week. I still need to buy some new vents as mine old ones are trashed and broken.
Scott
2003 Tahoe Stock
Old Yesterday, 10:45 AM   #316
Chaparralman1974
Man, she is looking great Scott!! I am still waiting on my crimper to ship....once it does I can start on my harness as well. Great job man!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old Yesterday, 09:49 PM   #317
zicc1835
zicc1835's Avatar
great progress.... the grill is outstanding....has really a nice touch to it .. Im going to be a copy cat hope you don't mind.... I bought some of the chrome paint to see if I can do the outside edges of the grate ....will be a long time till I get to that your build and progress is captivating to say the least
zicc1835 is offline   Reply With Quote
