Old 02-20-2025, 10:31 PM   #1
bigd65
bigd65's Avatar
Electric fans
2004 Silverado
I'm going to buy swap my clutch fan for Electric fans. I'm going to get the harness as well. Is it just hook up and go or does something need to be turned on in the computer
2024 Silverado Z71 PPV
1972 Chevy Monte Carlo
2018 Buick Enclave (Wifes)
bigd65 is offline   Reply With Quote
Old 02-21-2025, 11:33 PM   #2
franken
Re: Electric fans
Trading simplicity and reliability for complexity and unreliability is a not great way to go.
Old 02-22-2025, 08:28 AM   #3
bigd65
bigd65's Avatar
Re: Electric fans
Unreliability...? All vehicles today have them
Old 02-23-2025, 05:08 AM   #4
EVRLET
EVRLET's Avatar
Re: Electric fans
If you add fans by adding wire to pcm, you need to turn it on with hp tuners.
If you use a thermostatic switch like a painless wiring kit, no pcm editing required.
Best to use the pcm pinout because you can also change the temp in which the fan low and high turn on. You can source the factory Efan relay box at your junkyard. Get the whole harness and relay box to make it plug and play, with hp tuners of course.
Also I’d suggest going with the 7 & 9 blade fan assembly over the 5 & 7 blade the NBS trucks came with stock. Search rockauto under a 2011 Silverado 1500. Will fit the the NBS radiators perfectly.
Customization is what you want it to look like -- not what other people think it should look like
EVRLET is offline   Reply With Quote
Old 02-23-2025, 08:22 PM   #5
bigd65
bigd65's Avatar
Re: Electric fans
Thank you
Old 03-03-2025, 12:04 PM   #6
v30crewcab
v30crewcab's Avatar
Re: Electric fans
I got the wiring harness from bp harness to do my 04 tahoe. I had to send them my hp tuners file for them to modify to make it work correctly. I was getting better mileage on my first road trip, but since then its been about the same as it was before the mod.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
