Old 03-03-2025, 02:00 PM   #1
Chaparralman1974
Chaparralman1974's Avatar
Unhappy Drum Brake Pressure Switch
Good morning everyone!
Does anybody know where I can get the pressure switch for a drum brake distribution block? The one in my 67 K20 is rusted and trashed. I contacted Inline Tube and they don't sell the switch seperately from the block itself. I ordered one for a disc brake setup, but it is too big.
Here is what I am talking about? Does anyone know where I can order just the swtich?
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Build Thread: https://67-72chevytrucks.com/vboard/...d.php?t=841272
Chaparralman1974 is offline   Reply With Quote
Old 03-03-2025, 10:34 PM   #2
RichardJ
Re: Drum Brake Pressure Switch
Have you checked to see which switch you have?
There are two that I am aware of for that distribution block.
One switch is in the lower part of the photo. It is self contained with a spring loaded nipple at the bottom. When the nipple is pushed IN, the ground connection for the terminal post is made through the body of the switch.
The other switch is a long steel pin, insulated from the switch body by that nylon sleeve. When the brass piston is pushed to either side, it makes electrical contact with the steel pin. The ground path is actually through the springs, because the two "O" rings isolate the piston.
This last switch can be easily cleaned up. The other switch could probably be saved be spaying cleaner past the nipple and continually operating it till it frees up.
'67 GMC 2500, 292, 4spd, AC
RichardJ is online now   Reply With Quote
Old 03-04-2025, 10:57 AM   #3
loudchevy
loudchevy's Avatar
If this works, it's yours. I just pulled it off of my old drum/drum MC. I still have the block too if you want that
Scott
1970 C10 LWB-->SWB Under Construction https://67-72chevytrucks.com/vboard/...d.php?t=847605
2014 2500HD DirtyMax|Daily Driver|Stock
2003 Tahoe Stock
1985 K5 5.3LS/4L60E|8Lug 4:56|3/4 Ton Front|14BFF Rear|Roll Cage|Dove-tailed & Bobbed
loudchevy is offline   Reply With Quote
Old 03-04-2025, 11:00 AM   #4
Chaparralman1974
Hey Scott! That is it!! Yeah man I will grab it from you! Thanks man!
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-04-2025, 11:03 AM   #5
Chaparralman1974
Hi Richard, that block looks a little different than mine....I just have the switch that screws into the bottom for the warning light. I don't believe that I have the other components....I will have to double check.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-04-2025, 11:11 AM   #6
loudchevy
loudchevy's Avatar
Clay
Scott
2003 Tahoe Stock
Old 03-04-2025, 12:47 PM   #7
RichardJ
The brass piston shown has square shoulders and makes contact with the steel pin. The switch at the bottom of the photo would be mated to a piston that has tapered shoulders. The taper pushed the nipple on that switch, back into the body of the self contained switch.
I've not seen the one Loudchevy has pictured. It appears to be just a slight variation of the one I have shown with the long thin steel pin. The protrusion with the slot appears to be electrically insulated.
If yours needs cleaned internally, it isn't that difficult to disassemble. If you are careful, the sheet metal screw will do little damage to the brass inserts and can be reused. There is nothing in there, but two springs and the piston.
In this picture, there is a residual pressure valve below the seat, but you won't have that. They're showing seat removal for a MC, which may or may not have a residual valve.
Push the piston out with drift pin and clean with solvent and flush with brake fluid.
Old 03-04-2025, 02:15 PM   #8
Chaparralman1974
Hey Richard, thanks for the information....I didn't realize that there was a plunger inside. I didn't event realize that you could pull out the little brass inserts. I went ahead and did that, and the inside of mine is a complete mess....it is rusted solid. I think that I am just going to order a new block from inline tube.
The one from inline tube specifies that it is for 1/2 ton trucks. I can't see there being a difference, but I could be wrong. Do you know if the distribution blocks differ between 1/2 ton and 3/4 ton trucks? They look identical.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-04-2025, 09:02 PM   #9
70STOVEBOLT
70STOVEBOLT's Avatar
I have one from my ‘70 you can have if you pay the shipping. It was working when removed and it’s still connected to my Yeungling master cylinder, which is full of fluid.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-04-2025, 11:34 PM   #10
BanjoDude
I’ve been wondering how these come apart. Do you just force the whole assembly out one side, or are there clips of some sort that hold the brass caps in place? I’ve been afraid to force anything.
Found Grandpa's old '69 Chevy C-20 - It'll never leave the family again.
"For just a little more, you can do it yourself!"
BanjoDude is offline   Reply With Quote
Old 03-05-2025, 07:40 AM   #11
Chaparralman1974
Thank you for the offer....I went ahead and ordered a new one.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-05-2025, 02:54 PM   #12
70STOVEBOLT
Clay
Ok.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-06-2025, 08:40 AM   #13
Jason Banks
Jason Banks's Avatar
Not sure what makes it Unique, but the 1967 valve is different than the 1970 anyway...
Jason Banks is offline   Reply With Quote
Old 03-06-2025, 09:04 AM   #14
Jason Banks
Clay
I bought the PR111 for my 1967 K20 and it works fine. Need to dig into the GM parts manual and see if there are different part numbers for 3/4 ton....
Old 03-06-2025, 09:13 AM   #15
Jason Banks
Looks like all models use the same PN 3904303 for 1967 and then 68-70 use 3923719
Old 03-06-2025, 10:54 AM   #16
Chaparralman1974
Thanks for confirming Jason! I ordered the PR111 from inline tube.
I have another question though, while I am thinking of it....
I have always done a bench bleed of new master cylinders, but that has always been using existing lines and components where fluid is still in there. Seeing as how my entire system from master cylinder all the way to wheel cylinders are new and have no fluid in them yet, do I still need to bench bleed the master cylinder? Or do I just fill it all up with fluid and then bleed the entire system? I plan on getting a self bleeding kit to do it all.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-06-2025, 11:12 AM   #17
Jason Banks
I had hell getting a good bleed on my K20 and also had hell getting a master cylinder that would work.
I would go ahead and bench bleed the master cylinder.
For totally new systems I have historically bench bled the master, used the harbor freight vacuum bleeder(https://www.harborfreight.com/brake-...der-92924.html) to suck fluid through to all wheels, starting at drivers rear, moving to pass rear, pass front and finally driver front.
Then, nothing I have found beats having a helper pump and hold, while I crack bleeders at every wheel....
I even bought the Motive Products power bleeder - https://www.summitracing.com/parts/MVP-0115 - It ends up being a PITA to remove from the master cylinder to add fluid, so I have just defaulted back to pump and hold with a helper.
Old 03-06-2025, 11:14 AM   #18
Jason Banks
BTW, what are you using for master cylinder?
Old 03-06-2025, 02:10 PM   #19
Rust_never_sleeps
Rust_never_sleeps's Avatar
I've had an easier time syringe bleeding the MC than bench bleeding with a screwdriver.
Working alone sucks, so much faster and easier to bleed with a friend. Borrow or rent one if you can
Vacuum bleeding the back drums was a beast with two different methods, but I didn't use the Hobo Freight type
Motive works fine, but it's messy and awkward as mentioned
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
Old 03-07-2025, 08:04 AM   #20
Chaparralman1974
Thanks Jason!
I just ordered a master cylinder from Rock Auto for it. I will go ahead and bench bleed it. I am still waiting for the distribution block to show up and then I can put it all together. I have the lines run and just need to finish snugging up some fittings.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-07-2025, 08:05 AM   #21
Chaparralman1974
Syringe bleeding sounds interesting.....I will have to research that one.
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-07-2025, 08:16 AM   #22
Jason Banks
I guess I'll tell you my saga. When I got the truck it had a master cylinder on it that had a GM part number cast into it. So I took it apart and got a rebuild kit for it. Discovered it was a 1 inch bore not a 1 1/8 bore. But proceeded anyway, cerakoted the outside in a cast iron color. Put it back together and it leaked internally. Got another (I think raybestos brand 1 inch bore). Brakes didn't work worth a darn. So... I had a Wilwood 1 1/8 bore and threw it on. Still didn't like the brake feel and it may have been a bleeding problem because there are numerous stories of the wilwood being hard to bleed. Ended up getting this - https://www.amazon.com/dp/B0BJZ4LY1K - basically the cheapest stock looking one I could find and it works amazing. I didn't take it apart to confirm but I believe it has the built in residual valves that a stock one would have had.
Old 03-07-2025, 08:24 AM   #23
Chaparralman1974
I don't remember off the top of my head which one I got from Rock Auto, but I know it was a cheaper one. I am watching some videos right now on YouTube on the pneumatic power bleeders as well.....I have always bled brakes using the buddy method....I have never tried one of the new self bleeding setups, but it looks promising.
I am still in the middle of trying to get the bends in the front lines that go across the front cross member bent correctly. I should have done it before putting the truck back together. Working underneath on my back is a PITA to get the lines to route where they were originally. It isn't a huge deal, but my OCD is kicking in and I want it to look completely factory underneath. LOL!
I am very close to being able to move the truck out of the garage under its own power and that will be a huge milestone.
I did notice an oil leak in the driver side rear wheel the other day though....I am not sure if the oil seal went bad or not, but there is a small amount of gear oil that is dripping out of the drum so I will likely have to take that apart and fix it before driving anything so that the shoes don't get wasted....oh well, it is always something with these trucks. :-)
Clay
Clayton Sikes
Peoria, Arizona
1967 Chevy K20
Old 03-07-2025, 09:03 AM   #24
Jason Banks
Man there is always something. Not sure if I learned it from your build thread, but there are 2 types of seals for the rear. The stock kind and another that rides on a slightly different/fresher surface to seal.
Your so close, has to be a great feeling.
I tried to look up the different seal, but I'm out of time. It might be listed on Torque King...
Old 03-08-2025, 05:14 PM   #25
Rust_never_sleeps
Clay
It's actually recommended by some MC mfrs
I use "dental irrigators" with the skinny bent tip. They're cheap and versatile
Code:
            __
     ______|__]\____
