![]() Join Date: Mar 2000
Van/RV Tilt column floor shift conversion sleeve
Van tilt column floor shift conversion bowl/sleeve. Use a regular non key van/RV tilt column by trimming the shift arm at the bottom of the tube and swap on this sleeve. You could use a real 67-72 column shift tilt as well if you are brave. You will also need to fill the oval light bulb hole and screw holes in the upper sleeve where the PRNDL indicator was. This is something that took me a long time to come up with. It involved 3D scanning, 3D cad modelling and many many versions of the print in different materials to refine the part and its dimensions. They are 3D printed in carbon fiber filled nylon like the parts you see on car customizers TV programs. Very strong and very stiff. The pictures show it in as printed and primed versions ready to sand and paint. It fits the stock shift tube nicely and the stock snap ring retains it. I'll sell them in the as printed state for $100.00 Canadian / $70.00 US which will get you into a genuine GM quality floor shift tilt at a fraction of the price of an inferior aftermarket unit. Please see updated US tariff pricing below. Please note the picture with the tube is just to demonstrate that it fits onto the top of the tube just like the original.
You will have to fully disassemble your van column to put truck rubbers on it. This just replaces the stock bowl/sleeve when it goes back together. To the US due to newly imposed tariffs I will sand up any that are sold there on my lathe for free and offer a 10% discount as well to bring your cost to $ US 63.00 Plus shipping. Hopefully taking some of the sting out. If you buy quantity I will consider further discounts. *******Tariff's on hold but I'll hold my discounted price.****** If you refurbish and sell columns and want to buy a quantity please PM me.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 03-06-2025 at 09:33 PM. |
![]() Join Date: Jun 2005
Re: Van/RV Tilt column floor shift conversion sleeve
Are you saying this is all it takes to convert a column shift tilt to a color shift tilt?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast" 200,000 Mile Club Disc Brake Club Owner installed options: Front Sway Bar Power Steering Power Brakes Cigar Lighter Courtesy Lights Deluxe Side Markers Wiper Delay Sliding Rear Window Power Windows Power Locks Sniper EFI 2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear |
You have to take a van column apart to put the truck rubber parts on it. When apart trim the shift arm off of the engine bay end of the silver inner shift tube if you want it gone. Install my sleeve sanded, prepped and painted as you please and then fill the light bulb and screw holes on the top sleeve where the PRNDL was. Just carefully weld or solder in a small patch, fill and paint. Done. My sleeve replaces the part where the lever and pointer lumps were. Nice smooth floor shift van tilt column on the cheap. Be in the first 2 buyers and I’ll give you deal. Do consider that there’s a bit of effort taking one apart and putting back together if it’s your first time.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 01-20-2025 at 08:57 PM. |
![]() Join Date: Apr 2010
Does this include the shift tube also?
Are all measurements the exact same size as the original part? If so I will take one
No that is just for display so that you can see the part installed properly. Just the sleeve.
Saskatoon, Saskatchewan Canada |
The picture of the beige piece, is that a 3D bowl? Do you have a picture of a column using the 3d bowl completely assembled?
That is the steering wheel end fully assembled without a wheel or tilt/signal levers. The top sleeve on this one still needs to have the light bulb hole filled. I'll get a pic of this complete column posted up tonight.
#9 | |
(correction) An original floor shift non tilt column has just a cast sleeve that works exactly like this printed one. Please PM me your shipping details so I can figure out shipping. You are the first buyer so I'll let you have it for a discounted US 40$ price. One more left at this price for buyer number two. Also as the first buyer I can chuck one up in the lathe and sand the bulk of the print lines out of it if you are going to prep, prime and paint it. I'll get you a pic of the stock one and a printed one side by side.
Saskatoon, Saskatchewan Canada Last edited by StingRay; 01-26-2025 at 07:15 PM. |
![]() Join Date: Aug 2018
I'll take one
Carl 1971 GMC short bed, (Henry) Options I've added, tilt, ac, 8k tach, Electric speedometer conversion for LS swap, 6.0 with 823 heads and BTR stage 4 truck cam, 4L80e, posi with 3.73 rear end, Power steering and power brakes Lowered 5/7. Frame up build. |
Payment sent, thank you.
Carl
#13 | |
Always on the hunt...
![]() Join Date: Sep 2006
***For any return/past customers & friends*** Before sending of any funds, please wait for a confirmed total and instructions for sending as our payment account info has been changed as of Jan. 2023. Thanks... |
#14 | |
I just took another look at the non tilt in my one ton. I thought it was plastic but you are correct . Sorry about that yes the non tilt is indeed a metal bowl/sleeeve. It doesn't change that my part is printed nylon carbon/fiber and can't be made 100% identical to a cast stock part that a factory tilt column would have had. It'll provide a cost effective way to get into a quality floor shift tilt with an appropriate appearance. Thanks for the input. I have corrected that mistake.
#15 |
Received part and looks great, I will post pics when I get the column finished. Thank you,
Carl
#16 |
I got one of the 3D shift bowls from Ray and built a floor shift column using the 3D bowl. Once it was painted it assembled just like an original. It fit the shift tube perfectly. I welded up the hole for the light on the upper housing from an automatic tilt column and painted all pieces in gloss black. If anyone is thinking about buying one of the 3D shift bowls to build their own floor shift tilt column I would recommend buying this.
#17 |
Thanks for the kind words. Your work on those columns is just beautiful.
#18 |
US price discounted to help offset tariffs.
