Old 01-28-2025, 03:55 PM   #1
11Werner11
1954 3100 ignition/key bezel question
Feel free to skip the long story and go to my bolded question below.
Per my intro in the welcome area, I've become the mechanic for my mother-in-law's 1954 Chevy Truck. We live in Los Angeles and she recently had to evacuate from her home and lost her house to the fire. She chose to drive her 3100 out of the fire rather than her 2020 Mini. She's my hero! Thankfully, the Mini got out with only a little melting to the side of the car.
She parked the truck at our house the first night and, the very next day, we had to evacuate here as well (our house did not burn). She had parked in the driveway and I moved the truck forward a little after she got out. I stupidly left the key on and burned up the coil. The next day, when we had to evacuate, the truck wouldn't start and we had to push it onto the street in order to get our car and truck out of our single lane driveway. I didn't know at the time that it was the coil. I came back home at 3AM when the evacuation was lifted and the truck was still parked on the street. Phew!
The next morning, I went out to investigate why the truck wouldn't start and found the ignition switch dangling from its wires under the dash and a mostly dead battery. The tumbler was missing and so was the bezel which holds the ignition into the dash. So some jerk tried to steal it but couldn't get it started. I then tested the coil and igniter, replaced the coil and got it into the driveway, however, I now need to replace the ignition tumbler (and other locks) and also the bezel. Hence my question below:
I don't recall whether the bezel had three or four indents on it. I've looked online in various places for stock photos, but I haven't been successful. Some sellers have the version with 3-indents every 120 degrees and list it for 1947-1954 while others have a 4-indent bezel every 90 degrees and list it for 1953-1956. Should a 1954 C3100 have 3 or 4 indents on the ignition bezel on the dash?
I apologize for being so long-winded, but I figured someone might say, "Just look at the old bezel", which I can't do. Thanks for any help.
11Werner11 is offline   Reply With Quote
Old 01-28-2025, 06:39 PM   #2
leegreen
Re: 1954 3100 ignition/key bezel question
Sorry to hear you MIL lost her house, but on behalf of the forum she gets a big attagirl from us for saving the '54 !
The little indents on the bezel are just for turning it to tighten, so unless you are looking for points at concurs the main thing is that it fits the ignition switch threads. If I had a choice I'd go for 4 indents as it would be easier to cut a piece of sheetmetal to fit across two to tighten it.
leegreen is offline   Reply With Quote
Old 01-28-2025, 09:34 PM   #3
nvrdone
So you need the switch bezel. Unless you are looking for a 100 pt restoration, I dont think it makes a difference.
Having said that, How is the wiring? Can you stick a screwdriver in the switch and turn it on / start the truck?
All the parts you need should be available from Brothers Truck, CPP and others. All are in the LA area.
You will probably get many posts from people on this forum with lots of info.
Glad you guys survived.
49 chevy 3100 3 window. 327 / m21 4 spd, 12 bolt w/ 3:55's
Bought in 1973 for $235.00. Had it longer than my wife & Kids!!
nvrdone is offline   Reply With Quote
Old 01-29-2025, 12:02 AM   #4
11Werner11
She sure does get a big attagirl! Thanks for sharing your practical thought about 4 indents. That makes sense to me. I'm not worried about concours presentation of the truck, but I usually do like keep things true to stock form. My MIL will never notice that detail.
Old 01-29-2025, 12:10 AM   #5
11Werner11
Having said that,
Thanks for the feedback and also the info on Brothers Truck and CPP. I'll check them out.
Nope, because they stole the tumbler out of the switch. I think that means that the thieves were unable to use a screw driver to turn the truck on and had to remove the ignition to hotwire it. They must have actually been a little sophisticated. I believe you can't remove the bezel until you've removed the tumbler. I'm not sure how they got them both out and I'm annoyed that they took them both. They did create a small bend in the dash sheet metal where the hole for the key tumbler sits. I haven't noticed any other damage, thankfully.
Old 01-29-2025, 01:26 AM   #6
nvrdone
all you need to remove the key cylinder is a key that fits. put the key in, stick the paper clip end into the little hole, turn left & out pops the cylinder. then stick a flat blade screw driver in the slot that the key cylinder fits into and turn right and the ignition turns on. But wait - does the truck have a foot stomp starter?
Old 01-29-2025, 01:42 AM   #7
11Werner11
It sure does have the stomp pedal starter. But I wonder if I could still use the screwdriver to turn the key to the run position. I'll have to try that.
I just used the wiring diagram to figure out which connections were made when the key was turned to run. Then I used a pair of wires with alligator clips to make those connections and hit the starter pedal. It's a bit fiddly and, if I can do it with a screwdriver instead, I will do that until the new keys/locks show up.
Old 01-29-2025, 03:26 AM   #8
mr48chev
mr48chev's Avatar
That is a bummer.
I'd just connect in a hiden toggle switch for on and off until you get the parts to fix it right.
Dumb potential thieves as that truck can be hot wired with a piece of wire from the battery cable at the starter to the coil. Twist a piece of wire to the terminal at the battery and at the coil and go inside and hit the stomp pedal.
The filing station shows to have the correct parts to put it back together if they actually have them in stock.
7 The filling station has the correct Bezel and switch althogh you should be able to find them elsewhere and the filling station shows the correct lock cylinder and agan you should be able to find it in other places. The pages also tell you what else those pieces fit.
My ongoing truck projects:
Old 01-29-2025, 03:43 AM   #9
mr48chev
mr48chev's Avatar
I did some more searching and am not finding what I see as the correct pieces on other sites.
You can use a univesal parts house switch with keys but my experience says those will tear up the hole and the dash in a while and always are coming loose in a stock Chevy ignition switch hole. Fine in a flat dash that you drill an exact size hole in but not good for stock holes. If I used one of those as a 10 buck temporary fix so it can be driven and somewhat secure i'd make a bracket for the switch and hang it under the dash.
Old 01-29-2025, 04:51 AM   #10
11Werner11
You could probably tell from my earlier reply that I completely misunderstood your question... I thought you were asking whether a thief could stick in a screwdriver and turn the switch, before the attempted theft. But I now understand that you were asking if it was possible for me to use a screwdriver to turn the ignition switch. Not sure where my mind was at that moment. Like I said, I'll give it a try tomorrow.
Old 01-29-2025, 05:05 AM   #11
11Werner11
Thanks for the posts and info. I was going to try Chevs of the 40s for some of the parts because they had really good prices. But it looks like The Filling Station has an even better price for the bezel.
Old 01-30-2025, 12:54 AM   #12
mr48chev
mr48chev's Avatar
I like Chevs of the 40's because they actually say if it is in stock or not. I use the Filling station to see if something exists in the aftermarket quite often but have ordered from them. My experince with them that I have to believe that on slow moving items they may order them in on a stock order from the supplier and it does take some time for the parts to show up.
I use Classic parts a lot https://classicparts.com/ because they will put what ever you order (small stuff) in the size of priority mail box that it fits in, charge you the exact cost of the priiority mail box and you get it in short order. They didn't show switch or Bezel though.
For me Chevs of the 40's is a three hour road trip in each direction and my wife calls it going for a ride and getting to eat out. Even taking the HHR I probably don't save money over shipping costs .
Old 02-05-2025, 07:53 AM   #13
1project2many
This... is just insane. In the middle of fire evacuations someone decided stealing a truck was a good idea??? I have left my trucks unlocked for years. Change is in the console. If you're desperate enough to open a truck that's not yours then you likely need money for food or coffee.
It sounds like folks have gotten you on track with repairs. If I were in your area I would stop by to help just to try and offset the crazy bad karma out there.
1project2many is offline   Reply With Quote
Old 02-05-2025, 04:19 PM   #14
mr48chev
mr48chev's Avatar
If you need to drive that truck now and don't have a switch a jumper wire between the stud that the battery cable attaches to and the plus post of the coil will get power to the coil and allow the truck to run and drive aka hot wired and a thief was pretty stupid if they didn't know that. A couple feet of wire and a pair of alligator clips makes a fancy one. If it is stomp pedal start you just connect that wire and get inside and start the truck.
If you want to get a bit fancier you can take the hot wire and the ign wire off the switch and connect them with a toggle switch so you can switch the ignition off and on inside the cab. Hide that toggle switch within easy reach under the dash and a passenger might not know that you don't have a key in the switch to be able to have it run. I ran my 48 for a year with a toggle switch and push button under the dash and my buddy rode in it a number of times before he noticed that I didn't have a key in the switch. It had a later six with key start though. I would just stick my fingers under the dash next to the ignition switch flip the toggle switch and hit the pushbutton and most riding with me never noticed what I was doing.
Old 03-06-2025, 02:35 PM   #15
11Werner11
I'm sure we could totally use your kind of influence around here! Thanks for tuning in.
Old 03-06-2025, 02:36 PM   #16
11Werner11
Thanks for the extra info. I've been off doing other things for the past month and am back on it again. I'll post more below.
Old 03-06-2025, 02:44 PM   #17
11Werner11
Yesterday, I replaced the locks in the glove compartment and door with matching locks and I have a matching tumbler for the ignition as well. But, when I went to install it in the ignition switch, I figured out that the switch might be broken, unless I'm missing something. I inserted the key and then pushed the tumbler in all the way, turned it, but it would not latch into place. I feel like part of the switch might be missing from when the thieves removed the tumbler.
I pulled the switch and took it to my work bench to investigate. I *finally* understand what you guys meant by turning it with a screwdriver. I have never taken an ignition switch apart before. I see the black plastic piece in the very back of the hole that can be turned by a screwdriver. Upon further inspection, I still don't see how the tumbler should latch in. When I press the release button, without the tumbler in it, should I be able to see something happen, because nothing seems to move.
Thank you guys for all the help so far. I've never gotten so much response from other forums (for other unrelated things) in the past. This is a great place!
Old 03-06-2025, 06:14 PM   #18
mr48chev
mr48chev's Avatar
To remove the cylinder You have to turn the key to I am thinking accessory and using a paper clip or thin pin push in on the brass pin that holds the cylinder in place and then turn the cylinder counterclockwise and it will pull out.
It may take a but of trial and error but you can feel that brass pin push in against it's spring when you do push it in.
Old 03-06-2025, 07:37 PM   #19
11Werner11
Yessir - I'm familiar with the removal part, but my problem is that the tumbler won't stay in the switch when inserted. I think I'm supposed to put the key in the tumbler and then insert it into the switch and turn it either CW or CCW (I forget at the moment). However, the tumbler won't stay in the switch. It just falls back out.
Old 03-07-2025, 12:10 AM   #20
leegreen
I think you need key in the switch and a pin in that hole. Pin locks the cylinder to the key so you can turn it backwards against the indent to lock it in position.
Also possible that the scum that broke the cylinder broke the housing as well, so give it a close look
Old 03-07-2025, 06:31 AM   #21
mr48chev
mr48chev's Avatar
The key does have to be in the cylinder when you insert it. then turn to on and back and the pin should hold the cylinder in place.
I'm betting that Leegreen nailed it in that they damaged the pin or the part of the switch that holds the cylinder in. I'd have to take a switch apart to figure out what actually holds the cylinder in place while the pin acts a stop on how far it can turn.
