Old 03-19-2025, 09:30 PM   #1
JD'S 69
JD'S 69's Avatar
Should I have a sway bar on a bagged truck.
I put my truck on air bags. I had a sway bar already on should it be left on? I don't have any pics but it was just a standard sway bar.
When I stand before god at the at the end of my life, I would hope that I would not have a single bit of talent left, and I could say," I used everything you gave me"
My 69 stepper http://67-72chevytrucks.com/vboard/s...d.php?t=601095
JD'S 69 is offline   Reply With Quote
Old 03-19-2025, 10:00 PM   #2
3drburb
Re: Should I have a sway bar on a bagged truck.
Yes, you will most likely need to trim and round the ends so it doesn't rub and burst the bags, but it will handle a lot better with it.
3drburb is offline   Reply With Quote
Old 03-20-2025, 04:26 AM   #3
lil hoodlum
lil hoodlum's Avatar
If it already has a sway bar on it, I would keep it on.
1968 C10 327, 3 speed manual, LWB stock height daily driver.
1968 C20 327, 4 speed manual, LWB stock height custom camper with heavy duty leaf springs rear, 50th anniversary edition. Hoping to press into daily drive status soon.
lil hoodlum is offline   Reply With Quote
Old 03-20-2025, 09:31 AM   #4
Rich69shortfleet
I'd even go so far as to say you should put a bigger sway bar on it and add a rear sway bar while you are at it.
Rich69shortfleet is offline   Reply With Quote
Old 03-20-2025, 02:53 PM   #5
HO455
HO455's Avatar
Times 2. I put an 1-1/4" bar on my Burban with a 3rd gen F-body rear bar on the rear.
RIP Bob Parks.
Old 03-20-2025, 06:55 PM   #6
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Do you have leaf springs?
~Steven
Simi Valley, CA
Old 03-20-2025, 07:10 PM   #7
HO455
HO455's Avatar
Trailing arms with bags.
RIP Bob Parks.
Old 03-20-2025, 07:24 PM   #8
connorm
connorm's Avatar
The nature of air bags is to be a progressive spring, meaning that as the outer corner compresses the spring rate will go up. Essentially a sway bar does a similar thing. But, s someone else said, if you have a sway bar run it.
Are you running on the low end of the recommended air pressure? Your ride height would dictate your air pressure, and if you are running a low ride height or a lighter vehicle your air pressure should be lower, which might mean a lighter progressive spring. I would think you would need a sway bar more in this instance. I know even with my heavy duty 3/4 ton springs the sway bar made a BIG difference when I added it.
What shocks do you have? I put Ridetech adjustable shocks and that made as much of a difference in my opinion because I could adjust them how I preferred my ride. This might be a better option for the already progressive air bags.
1970 C/2500 Ol' Green https://67-72chevytrucks.com/vboard/...d.php?t=668003
2016 GMC Sierra K1500
1953 Mercury 2 Door Sedan https://67-72chevytrucks.com/vboard/...17#post9381817
connorm is offline   Reply With Quote
Old 03-20-2025, 09:42 PM   #9
Steeveedee
Steeveedee's Avatar
Thanks! I'd like to add a rear stabilizer to my truck without breaking the bank.
~Steven
Simi Valley, CA
Old 03-25-2025, 12:51 PM   #10
SCOTI
SCOTI's Avatar
This is dependent on how the lines are plumbed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-25-2025, 05:50 PM   #11
dagnabbitt
dagnabbitt's Avatar
That rear swaybar idea/source sounds pretty cool!
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
