Old 03-21-2025, 07:23 PM   #1
sackracing
sackracing's Avatar
1966 Gasser Build
After years of racing Turbo Buicks, I sold out and bought this farm fresh 66'
Now I've got the itch to do a drag and drive, so I'm gonna convert this and run the gasser class at Sick Week, if I get accepted
It's a base 66' with an L79 327 out of an Impala SS. I've kept everything period correct so far and I'm gonna try to do that thru the build.
66 SWB Fleet Gasser....
sackracing is offline   Reply With Quote
Old 03-23-2025, 08:44 AM   #2
_mg
_mg's Avatar
Re: 1966 Gasser Build
Cool! Check this 1964 C10 gasser out, fun!
https://youtube.com/shorts/SNh2A77vD...c13Rb1RnmYS08v
_mg is offline   Reply With Quote
Old 03-23-2025, 08:51 AM   #3
sackracing
sackracing's Avatar
That's the one that got me motivated. I've watched some of his videos on Youtube
Old 03-23-2025, 08:59 AM   #4
sackracing
sackracing's Avatar
Truck had CPP dropped spindles and 2 inch dropped springs.
Went with stock height spindles and Moog 6454 springs. I don't want to commit to a straight axle yet. And if I do a drag and drive week I'd rather do the 1000 mile drive with stock style front suspension.
Swapped to the CPP 5 lug front rotors and rear axles
Old 03-23-2025, 10:01 AM   #5
Keith Seymore
Keith Seymore's Avatar
That looks like my home track of Lapeer International Dragway.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 03-23-2025, 10:28 AM   #6
_mg
_mg's Avatar
Sounds like a fun goal. Let's see under the hood!
Old 03-23-2025, 10:35 AM   #7
sackracing
sackracing's Avatar
1964 L79 327, Holley 750. It has a pretty nasty roller cam with comp valvetrain. Heads have been ported. MSD billet distributor and ignition box.
Currently has a saginaw 4 speed, but I'll be installing a TH400 this summer with a PTC converter.
I picked up a era correct Edelbrock tunnel ram with two 390s that had been sitting on a shelf for 50ish years.
Old 03-23-2025, 10:37 AM   #8
sackracing
sackracing's Avatar
K
He lives in Michigan I believe. LoudNUgly garage on Youtube
Old 03-23-2025, 04:45 PM   #9
sackracing
sackracing's Avatar
Old 03-23-2025, 05:53 PM   #10
_mg
_mg's Avatar
That looks great! Can't wait to see the video.
Old 03-24-2025, 09:18 AM   #11
rbruno68
Looks like a good build. What rear tire size did you go with? They look like they fit the wheel well just right.
rbruno68 is offline   Reply With Quote
Old 03-25-2025, 10:46 AM   #12
rbruno68
What brackets did you use to sling your alt on the passenger side? I have early double hump heads without the bolt holes. I think I will keep mine on the driver side, but need to mount it low like yours.
Old 03-29-2025, 04:30 PM   #13
karlbenz
you could drill and tap them
2000 c3500 utility bed 7.4l 5sp manual old body style. Cab and chassis
1964 GMC K10 383cu in/sm465/twin stick np205
1965 Chevy C60
1990 Chevy Bus 8.2l fuel pincher 8800 miles
1993 Ford F350 crewcab 7.3idi nonturbo ZF5 Transmission Running on WMO
karlbenz is offline   Reply With Quote
Old 03-30-2025, 11:17 PM   #14
motofly196
Alan Grove will have exactly what you need. I'm using his Driver's side Alternator bracket, and Driver's side Power Steering pump bracket. They fit perfectly out of the box.
https://alangrovecomponents.com/index.htm
motofly196 is offline   Reply With Quote
Old 03-31-2025, 08:30 AM   #15
rbruno68
Thanks. I will see what they have.
Old 03-31-2025, 10:04 AM   #16
SCOTI
SCOTI's Avatar
I'm in to follow your progress. I like what I see so far for sure.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 04-09-2025, 07:13 AM   #17
sackracing
sackracing's Avatar
275/60 Hoosiers
Old 04-09-2025, 07:14 AM   #18
sackracing
sackracing's Avatar
It's a CVF kit, they had the setup for no accessory holes
Old 04-09-2025, 07:20 AM   #19
sackracing
sackracing's Avatar
Pulled the 12 bolt and sold it, and removed the factory trailing arms.
Ordered a Quick Performance 9 inch with the pads already on it for a C10.
Also ordered Moser box tube trailing arms and multi position brackets for the stock xmember.
Installed CPP coilover kit with double adjustable Viking shocks
I'm getting pretty good at getting rivets out...
Old 04-13-2025, 03:42 PM   #20
sackracing
sackracing's Avatar
Old 04-17-2025, 03:48 PM   #21
forestb
forestb's Avatar
Make sure that you qualify for gasser class with the stock style front suspension. I saw that Mike Finnegan almost didn't qualify for gasser class when he took out the straight axle out of his 55 Chevy and built his own upper and lower A Arm setup.
forestb is offline   Reply With Quote
Old 04-18-2025, 07:24 PM   #22
sackracing
sackracing's Avatar
The mustang 2 style conversion is not allowed, I think they were on him because of the rack and pinion and the fact that it's not a stock tri 5 setup. He was still allowed to run though.
This one is all stock and I'm not using coilovers so it would be fine for B/Gas, according to the rules.
Old 04-18-2025, 07:52 PM   #23
forestb
forestb's Avatar
The funny thing about doing a gasser pickup is that the ride height looks stock except for the little front tire up front
Old 04-18-2025, 08:08 PM   #24
sackracing
sackracing's Avatar
I was able to get 2" higher than stock with c20 springs, but i have to add ball joint spacers now
Old 05-06-2025, 09:26 AM   #25
cag
Active Member
Ya need some fiberglass front fenders for that bad boy??
cag is offline   Reply With Quote
