Old 04-02-2025, 02:13 PM   #9
aglinks
Re: Hydraulic Clutch Installation
Originally Posted by bhap View Post
That looks like the same master cylinder I have on my 62 - Willwood. I was able to turn the plug / grommet onto an angle where I could get the plugs to fit into the connector with the master in place. I had done some wiring and replaced the grommet - if yours is hard and crusty, you might try a little heat to get it to move. You can also loosen the master, plug in the connectors and then tighten up the master.
This worked! Thank you!
aglinks is offline   Reply With Quote
