Heater control panel light has gray wire that go to instrument cluster connection.
The wiring diagram for 1968 Chevy C10 says the gray wire for the heater control panel light goes to the instrument cluster connection.
Where is that located at? |
![]() Join Date: Jun 2022
Re: Heater control panel light has gray wire that go to instrument cluster connection
In the dash, plugged into the back of the instrument cluster
1970 C10 Custom longbed 350/350 “Carburetors are forgiving, timing is not” — Thunderhead289 |
![]() Join Date: Dec 1999
There is a location on the fuse panel. Used to have my tilt column light plugged into there. Things are a bit different now with the new AAW harness.
Had my old fuse panel in a box and took a pic for you.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
Hey thanks! But I was looking for the instrument cluster connection. According to the above post it is located right on the back of the dash panel.
Still plays with trucks
Mine has the secondary gauges so the wiring isn't the same as a speedo and fuel gauge only truck but the heater bulb socket is connected into pin 8 on my gauge cluster.
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been https://67-72chevytrucks.com/vboard/...d.php?t=484426 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E |
The connector is #13. It's in the pdf manual, which you can download off this site
Junior Member
![]() Join Date: Mar 2025
Here are a couple of photos of my ‘68 C10 heater control light pigtail and the instrument cluster connector as it appears when still plugged in. The single gray wire pigtail connector from the heater control light plugs into a connector with two gray wires.
The instrument cluster connector has one gray wire on the top row of the connector. The top row is colored as follows: black, gray, dark blue, light blue, light green and possibly black on the passenger side top end. The bottom row: dark green, blank, brown, red/pink?, brown and black (?) on the passenger side bottom row. I have highlighted the gray wire with an arrow on the instrument cluster connector. I know it looks like a black wire in the photo because of how it’s shadowed, but it’s gray. The photo that 68 TT provided looks to be the same way that mine is wired. These are looking up, so try to get your orientation correct. Last edited by mojavetrucker; 04-03-2025 at 03:46 PM. |
Thanks! I located what I think is the black female connector that the heater light plugs into and it looks like it leads back to the instrument cluster connection. Thanks guys!
#9 | |
There is a single bulb if the heater is standard and two bulbs if you have air conditioning.
| Bookmarks |
