Old 04-13-2025, 11:35 AM   #26
RustyPile
RustyPile's Avatar
Re: No spark
Originally Posted by Steeveedee View Post
When the breaker plate pivots with vacuum advance, that is going to pull on that wire. There should be some slack for the wire from the coil to flex when the breaker plate moves.
I guess I misunderstood the point of your comment.. I thought you were saying the vacuum mechanism could move the plate.. I totally agree, that replacement wire is too rigid for this application.. The original wire was a braided design using numerous very fine gauge wires.. A 7 strand wire will soon fail from the constant flexing..
In the distant past, that wire could be obtained from STANDARD IGNITION PRODUCTS. I don't know about now.
RustyPile is offline   Reply With Quote
Old 04-13-2025, 12:50 PM   #27
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: No spark
When I worked in a parts store we sold Standard Ignition Products. I remember that wire. I went and looked, and indeed that wire is still available.
~Steven
Simi Valley, CA
Old 04-13-2025, 06:34 PM   #28
Dude68
Re: No spark
I am having a good time with my father trying to figure this out. Thanks for all of the posts. We will be working on it next week.
Joey
Dude68 is offline   Reply With Quote
Old 04-15-2025, 02:05 AM   #29
Dude68
Re: No spark
We got it going, thanks for the help.
We changed the condenser in distributor, put the old one in and started getting fire from coil. I am assuming we had grounded out somewhere with the wire, but it worked. Then realized the distributor was 180 degrees off.
It started and runs. Lifters tapping so I need to go through the tightening procedure for those again. Small leak in lifter cover.
After looking at pics and other posts in this thread, we figured something was up with the negative wire from the coil and little wire on condenser. I say we, but my Dad figured all of this out after I forwarded some pics and posts from the thread. A few of the posts referred to the distributor, so we checked it and confirmed it was bassackwards.
Joey
Old 04-15-2025, 02:57 AM   #30
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: No spark
Are you getting oil pressure?
1970 C10 Custom longbed 350/350
“Carburetors are forgiving, timing is not” — Thunderhead289
Rust_never_sleeps is online now   Reply With Quote
Old 04-15-2025, 09:02 AM   #31
raggedjim
raggedjim's Avatar
Re: No spark
Glad you got it and learned something in the process!
raggedjim is offline   Reply With Quote
Old 04-15-2025, 09:07 PM   #32
Dude68
Re: No spark
Yes, we have oil pressure, one small oil leak on lifter cover, was able to tighten that and stopped it. Need to adjust lifters.
Joey
Old 04-18-2025, 10:13 AM   #33
70STOVEBOLT
70STOVEBOLT's Avatar
Re: No spark
Originally Posted by franken View Post
Stop replacing parts and research what the problem might be. Asking other people to vote on what the problem is won't help.
Really helpful comment.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 04-18-2025, 10:15 AM   #34
70STOVEBOLT
Re: No spark
He said the engine was rebuilt, that is why the parts are new. I don't think he was just replacing parts to try to find the problem.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 04-18-2025, 08:52 PM   #35
Dude68
Re: No spark
I appreciate all of the posts. I should have posted a pic, then we could have figured it out sooner. RichardJ said he suspected the distributor was installed incorrectly. That's where the problem was.
Thanks again for all of the posts. I have had a few on here and have had all of my questions answered.
Joey
