Door gaps Help
Afternoon Guys I started gaping my C-10 doors I loosed the cab side of the hinges then jacked up the door in front near the hinges I can get it to look halfway OK for now if I tighten the hinges and let the door down it drops in the back of the door about a quarter of an inch how do I get it to stay put the door hinge bolts are tight also you guys have any advice would be greatly appreciated Thanks
Re: Door gaps Help
To start with are your hinges tight? When the door is nearly closed grab the back of the door at the bottom and lift. How much does the door raise up?
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
Roadtrip!
Re: Door gaps Help
I would guess you will need pins and Buschings. Start there.
67 gmc custom lwb dakota truck. Sold...And bought back... And sold again... 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: Door gaps Help
Hey Guys my hinges are brand new hinges bolts are tight
![]() ![]() Join Date: Feb 2009
Re: Door gaps Help
Well if the hinges are good and everything is tight, heck I don't know, but you might try placing the floor jack at the door's center, perhaps throw a 2x4 in between to spread the support, with rags to your heart's content. If it's a stable situation, seems you should loosen all 24 bolts, at least enough to get things where they want to go, then tighten in sequences.
Tony 1971 C10 Custom Deluxe SWB 402/400TH A/C I developed an assembly information kit for restoring my truck from nuts and bolts. It's written in Assy. order, short & simple, packed with all OEM hardware ID; castings; part ID; 100s of part numbers; wiring simple - Resource, and trivial too. Much info. applies to all 67-72 GM, A/C vehicles, esp. trucks W/O saying. Full search ability, including to 700+ images of illus., parts, charts, Assy., points of interest, cab, bed, & front clip cart plans- Specials and cores were serviced out and R excluded e.g. front/rear glass, body/paint, engine core, rebuilt hinges, steering box, trans, etc. The project was in-line with long former professions developing process, policy, specs, demo, written for novices, admin., policy, engineers, development, systems & test - Public & govt 2, gross. Sell soft copy cheaply, PM if interested.Build thread:https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Door gaps Help
Have you inspected the door for cracks around the hinge mounting area?
Is it possible the latch is forcing the door down? Try marking then removing the B pillar latch piece then closet the door.
Re: Door gaps Help
Thank you Guys appreciate the help I'm ready for round 2 on my door gaps
Re: Door gaps Help
First off, without the glass and other weight bearing objects your never gonna win, so figure that weight and toss some weight in there. Second, I would remove the latch and adjust the door gap as desired. Once happy, modify the latch to hold the door, while in that position. Wild and crazy thought is are you fighting something that is just bad from the factory. Meaning, remove the hinges, place the door in the opening and latch it. Adjust the latch so you get the gap how you want when closed. Now install the hinges or try to and see how far they will need to be modified to work.
#9 | |
Re: Door gaps Help
![]() Join Date: Mar 2023
Re: Door gaps Help
Are the Honda civic clip on or glue? What year civic?
Re: Door gaps Help
| Bookmarks |
