Old 05-06-2025, 08:30 PM   #26
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Move brake pedal closer to floor
Nice pics! Did you add to the pedal return stop, or are you using the SLS as the stop now?
~Steven
Simi Valley, CA
Old 05-07-2025, 11:01 AM   #27
MikeB
MikeB's Avatar
SLS meaning?
I glued a rubber "foot" to the existing stop, which added about 1/4". That turned out to be another 1.5" at the pedal. But with the shortened pushrod, the brake pedal arm barely hits the rubber bumper.
There's also just a tint bit of free play, which is what I wanted.
It's a real balancing act. Can't tell you how many times I took things apart, made adjustments, and put thing back together. I feel like I'll need to slightly adjust the switch someday.
Mike
1969 Custom/10 LWB -- owned for 37 years. 350/TH350, 3.08 posi, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. Hedman stainless headers. Old Air installation in progress.
1982 Custom Deluxe 10 SWB -- converted from 250-six to roller cam 350 w/ Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) which I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 26 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 05-07-2025, 11:08 AM   #28
MikeB
MikeB's Avatar
Use some strong adhesive if you use a rubber "foot" to extend the pedal stop. This Loctite stuff is awesome if you following the instructions. Be sure to clean off the adhesive that comes on the foot using carb cleaner or adhesive remover. Also the existing rubber stop's surface.
Mike
Old 05-07-2025, 12:52 PM   #29
Steeveedee
Steeveedee's Avatar
Originally Posted by MikeB View Post
SLS meaning?
Stop Light Switch
~Steven
Simi Valley, CA
