Old 06-03-2024, 08:14 PM   #101
SeventyOne
Re: Amp Research Powerstep
Originally Posted by Blazerowner View Post
One thing to note the wiring is grounded together for the interior lights. I had to cut the ground from the right side to stop both steps from coming down with one door open.
That's what the diodes are for that HB provides. But I guess you found another way to do it?
SeventyOne is offline   Reply With Quote
Old 06-03-2024, 08:57 PM   #102
Blazerowner
Blazerowner's Avatar
No I used the diodes and still had the issue. I was wondering why that didn’t work. I just eliminated the bridged ground and I think that solved the problem. Edit - I see I installed them wrong now. Oh well not a big deal. I might fix them later.
Kirk
72 Blazer CST 4wd highlander
Blazerowner is offline   Reply With Quote
Old 06-04-2024, 10:16 PM   #103
Blazerowner
Fixed the wiring. Now it works as it should.
I trimmed my inner fenders. Used an air body saw. Came out pretty good. I just need some touch up paint and see if they clear.
Kirk
Old 06-05-2024, 12:28 PM   #104
SeventyOne
Looks good. I dont have access to an air saw so i'll have to finesse it with my grinder/cut off wheel and maybe use a drill bit to radius the corners.
Old 06-05-2024, 03:24 PM   #105
Blazerowner
Highly recommend the air saw if you can buy one but the cut off wheel and grinder will work. Its hidden so it doesn’t have to be pretty.
Kirk
Old 08-04-2024, 01:03 PM   #106
Piratenation
New Member
Piratenation's Avatar
I agree the work is nice. The brackets seem to be either laser or water jet cut. They are nice and I haven’t had fitment issue on the truck. I’m hoping I have the right brackets but FedEx is running late so I may not know until tomorrow which motors I have. Any chance you can grab a picture of where you had to trim the rocker box?
How much did the amp steps cost? Looking at buying the HB brackets but want to know what my all-in parts cost is gonna be. Don't need part number just price. Thanks
Piratenation is offline   Reply With Quote
Old 08-04-2024, 06:48 PM   #107
SeventyOne
like 1600ish
Old 08-05-2024, 11:42 AM   #108
Piratenation
New Member
Originally Posted by SeventyOne View Post
like 1600ish
Thanks, I was thinking it was gonna be 1500ish.
Old 06-04-2025, 07:52 PM   #109
6600DURAMAX
6600DURAMAX's Avatar
Man I'm lost on this wiring .....my worst enemy is wiring ...
I'm not sure I understand what I need to do - my installer just put them on a rocker switch as shown but obviously I need to correct this so they function properly.
I have door ground switches installed in each door
I am using the power window fuse (20 amp) as the main power to the AMP box - I'm not sure what to do with the purple wires and the instructions didn't help this guy ...!!
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio .....
1971 CREWMAX Build.....at body shop for couple more years
6600DURAMAX is offline   Reply With Quote
Old 06-04-2025, 07:55 PM   #110
6600DURAMAX
here are the pics of the switch and wiring
Old 06-04-2025, 07:56 PM   #111
6600DURAMAX
lets try that again
Old 06-04-2025, 07:57 PM   #112
6600DURAMAX
Old 06-04-2025, 08:31 PM   #113
6600DURAMAX
Are these the diodes that are needed ?? If so how do they connect to the door ground wire?
Old 06-04-2025, 08:33 PM   #114
6600DURAMAX
From Chat GPT
Old 06-05-2025, 10:08 AM   #115
6600DURAMAX
I ordered diodes and relays - everything should be here tomorrow - still would like confirmation that the above instructions are correct....
Old 06-06-2025, 12:52 PM   #116
6600DURAMAX
Wired them up without the diodes and relays - everything works as it should .... I even was able to finally wire in the single wall dome lights to function off the driver door switch
Old 06-08-2025, 02:53 AM   #117
Richard
Wanted to ask, do both steps come down if either door is opened? FWIU correct install of diodes should make only the side door is opened on actuate. Was wondering what the relays were for if the controller was used?
Richard
Old 06-09-2025, 12:33 PM   #118
6600DURAMAX
Only the door that is open has the step come down.....
No relays or diodes used in my wiring ( other than I used a relay for the dome switches but not sure if it was necessary ?
Old 06-14-2025, 02:26 AM   #119
Richard
Cool. You just connected the trigger wire on each side near each door switch?
Richard
Old 06-16-2025, 03:38 PM   #120
6600DURAMAX
Yes that is correct
Old 06-20-2025, 03:46 AM   #121
Richard
Yes that is correct
Thank you for the response. I will try connecting my steps without the diodes first.
Richard
