Old 06-22-2025, 10:34 PM   #1
weq92f
weq92f's Avatar
drop spindles 2.5" and springs 2". Align spec
I've got the 2.5" spindles and 2" springs on otherwise stock suspension.
I've read through most of the threads here that were returned on a Title search for "camber" as there was only 1 page of results.
What I'm reading is that on these trucks with these lowering specs, the camber adjustment available/possible by adding shims is within acceptable specifications ( around -0.5 or so ). After my recent offroad adventure, I've got roughly -0.8 and -1.0 camber at max shims installed on the -1 side and maybe a small bit of more-toward-positive on the -0.8 side still available.
If my frame rails are factory straight and suspension components hanging from the frame are all not compromised/bent/warped, do the above numbers make any sense?
I'm trying to find proof positive based on experience here that I've got either frame problems or other components mucked up.
Thoughts?
EDIT: The side with -1.0 camber has 4 thick shims in the front and rear (equal) positions. The other side has the same number.
Thank you,
-Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi
07 335 sport turbo 6sp
94 Trans Am GT LT1 6sp posi -- sold after 22yrs
99 540 sport V8 6sp -- sold
73 240z L24 4sp -- given to friend
68 C10 step 350/350 3.73 open -- sold
weq92f is offline   Reply With Quote
