Fuel Lines, 5/16 or 3/8s?
Which size fuel line did out turcks come with?
Just sitting here contemplating contemplation. |
Member since 2000
3/8
Young Gun wth Fast Inline
5/16ths for the inlines, 3/8 for v8
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!! |
Back in the sticks
my 71 had both. 3/8 for fuel supply line from tank and 5/16 going back to the tank for vent. had to change both to 3/8 for the TPI. Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Stelth is right. It depends on which engine it had originally.
Resident Curmudgeon
![]() Join Date: Dec 1999
I've found it depends on the carb. All 4bbl carbed V8's had 3/8, whereas the 307 2bbl had 5/16th. All inlines had 5/16th as well.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
Try spinnin 4 rear tars
My 2bbl V8 has 5/16...
SWEET7T 1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB |
New KISS Band
I put 5/16 on mine and I run a 350
67 chevy 350 HP 4bolt main turbo 350 3.73 gears |
Re: Fuel Lines, 5/16 or 3/8s?
I’m swapping to a new tank in my i6
It will eventually get a 350 so I’m wondering if I should do the 3/8 sending unit, 3/8 lines now. However the i6 fuel pump and carb is 5/16” Am I introducing any pressure issues for now if I do the 3/8” lines up to the fuel pump and 5/16” beyond that to the carb?
1969 C10 Shortbed |
Ram-A-Lam-A-Ding-Dong
![]() Join Date: Jan 2013
^ Nope.
#11 | |
It's early and I'm not fully caffeinated yet. If a fuel pump has a return line, will that make it so that the pressure at the carburetor will not increase after the engine shuts off and gets heat soaked? I don't know how that recirc works- is it just a return line, or is there some relief valve?
#13 | |
#14 | |
| Bookmarks |
