Old 07-10-2025, 06:55 PM   #1
tregrad
wing window tightening
On my 72 K5 the pass side wing opens and stays open, driver side just flops around. Is there a way/hack/jerry rig, to tighten the driver side up so it will stay open while driving?
tregrad is offline   Reply With Quote
Old 07-10-2025, 08:17 PM   #2
cj847
cj847's Avatar
Re: wing window tightening
Its a pain, but there is a nut on bottom that can be tightened. You have to remove the vent window assy from the door to get to it. I couldn't find a specification or method to know how tight it needed to be. Just went by feel.
If it's flopping around it may be broken and will have to be replaced. The spring can be broken or more likely the stem that is attached to the actual vent window could be rusted through and broken. See the pic:
cj847 is offline   Reply With Quote
Old 07-11-2025, 02:47 AM   #3
'68OrangeSunshine
'68OrangeSunshine's Avatar
It's not elegant, but I slip a bunji cord around the lock knob with the wing all the way out, and pull the hooks to grab the window channel. No pix yet. This was going to be my temporary solution until I priced new Vent Window Assemblies.
Old 07-11-2025, 03:22 AM   #4
Richard
To the OP. As said probably rusted off stud or broken spring.
To 68OS- From what I have seen the replacements kind of suck. Would rebuild or find rebuildable replacements myself. There is someone on the forum that does rebuilds if you cannot do yourself.
Richard
Old 07-11-2025, 07:25 AM   #5
tregrad
Awesome!, thanks for the pic as well
Old 07-11-2025, 07:26 AM   #6
tregrad
Funny, I was thinking of that too. Off to LMC I guess
Old 07-11-2025, 07:34 AM   #7
tregrad
Just had a look at LMC and from what i see, if the stud is ok then i just need the spring and then go to home depot to get a lock-nut so it wont come loose. HOPEFULLY its just a loose nut.
Thanks for all your help!!
Old 07-11-2025, 10:34 AM   #8
cj847
cj847's Avatar
unlikely to be a loose nut as there is a tab bent over when you adjust it so that it can't loosen.
Old 07-11-2025, 04:47 PM   #9
tregrad
ahh i see it in the pic, ok so the spring then? lolol
