Old 07-09-2025, 08:49 PM   #1
aotte1
83 Interior SPID 76D LEE1…….
1983 K10, Spid interior color code “76D LEE1 MAHOGANY CUS CL”.
Redoing interior on 1983 K10 Silverado, exterior code 63/59 two tone (know colors); mahogany is part of SPID interior color. When ordering parts, what is the Chevrolet color name to use, mahogany seem obvious, however, parts ordered under color mahogany seem different then originals.
Looking for SPID code 76D…. description.
aotte1 is offline   Reply With Quote
Old 07-09-2025, 09:11 PM   #2
aotte1
Re: 83 Interior SPID 76D LEE1…….
Photos of original door panel and under dash kick panel area cover. AZ truck whole life, one owner, small town, likely out side whole life. Sun fade is obvious, under dash cover is more likely closest to original color. Aftermarket parts so far are much more brown, to very brown.
Does anyone have photo of door panel much less sun faded for this SPID interior color?
Thanks in advance.
Old 07-10-2025, 08:56 AM   #3
MJN
MJN's Avatar
This is the paint/trim color page from the 1983 Info Kit https://www.gm.com/content/dam/compa...olet-Truck.pdf
Looks like Mahogany was the color name according to this chart.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 07-10-2025, 08:13 PM   #4
aotte1
MJM,
Thanks, big help.
So mahogany interior on this truck was not recommended in 83 for the two tone exterior paint bronze met/almond.
What interior color to use for renovation? Testing out USA1 mahogany dye on old door panel for review, and back of new panel. Using Holley replacement Silverado door panels, comparison to original shows them to be correct on initial review (map pocket attachment holes need to be drilled- identifier location provided).
Note; looks like SEMS finisher product is needed to get the correct look ( not flatish)
Old 07-11-2025, 06:47 AM   #5
TKCR
TKCR's Avatar
USA1 Industries Mahogany. It’s a perfect match. I have done quite a few parts using the Mahogany from USA1
Old 07-12-2025, 11:29 AM   #6
aotte1
TKCR do you top coat with “SEM Tac Free” 39643 after the dye coat?
Any thoughts on what color ACC carpet is good to use with mahogany interior. Reviewed Rock Auto ACC colors available.
Anyone, photos of Mahogany interior in like new condition.
Photos of exterior for reference, two tone codes 63/59.
Old 07-12-2025, 12:16 PM   #7
TKCR
TKCR's Avatar
No. And just to clarify that is only used on the vinyl parts.
What I used after prep & dye is the SEM Low Luster Clear.
So a thorough cleaning with Dawn dish soap. The the plastics, the SEM Plastic prep. I do this twice. Once using a green scotch pad, wipe or rinse. Then again but wipe with a tac free cloth. The SEM Sand Free Adhesive Promoter followed with the light coats of dye. Then the SEM Low Luster Clear.
Now the vinyl parts, same cleaning but the prep you use SEM vinyl prep
Old 07-12-2025, 01:21 PM   #8
aotte1
TKCR, Thank for the information.
Below are a few photos of interior in areas not effect by sun light. Apple phone and led light, will repeat not time in sun light.
Old 07-12-2025, 01:23 PM   #9
aotte1
First photo out of sun light.
Second and third photo color variation in hard plastic in this truck. Door panel same color on back.
Know camera and light effects how color looks in photo.
Also the variation in hard plastic color in this truck, may be the result of assemble line out of need color in that part and they used the closest color ?
Old 07-12-2025, 04:44 PM   #10
TKCR
TKCR's Avatar
Yeah that kick panel round cover looks like it’s Burgundy versus Mahogany. Unless someone swapped it at some point. That happens, especially with Mahogany. When someone starts changing parts, it’s usually with burgundy.
Your seatbelts are definitely Mahogany. And I can restore those for you, that’s what I do is restore seatbelts.
Old 07-14-2025, 11:35 AM   #11
MJN
MJN's Avatar
MJM,
Thanks, big help.
I don't see where it says that Mahogany was not recommended- it just shows that with that color combo that Mahogany was one of the available interior color options. The boxes that do not have the 'X' in them were not available as a color combo.
'17 GMC Yukon XL
VCCA member #58596
Old 09-17-2025, 02:30 PM   #12
usa1industries
usa1industries's Avatar
USA1 Industries. Just wanted to drop by on here to let you know that we do have the original Mahogany paint dye that is color matched 100%
We have Dash pads, door panels, kick panels, headliner moldings and many more parts in the original Mahogany.
I am going to drop some links below of the paint cans and sample kits we sell if interested.
https://www.usa1industries.com/1981-...iginal-colors/
https://www.usa1industries.com/1982-...-kit-mahogany/
Feel free to contact us at customerservice@usa1industries.com as well.
Innovating the Future of Industry
🚀 Engineering Solutions That Power the Future
🔩 Built on Quality, Driven by Performance
🌍 Proudly Serving Industries Across the World
usa1industries is offline   Reply With Quote
