Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 07+ Chevy and GMC Message Board
Old 08-04-2025, 02:54 PM   #1
dennislbrooks
dennislbrooks's Avatar
2015 Chevy 2500HD Duramax Starter Replacement Starter Noise
My 2015 Chevy 2500HD Duramax began a starter noise after starting and when the Bendix gear was backing out. I bought a new replacement GM Genuine 12721722 replacement -- I figured solenoid release problem.
I found info on the web that helped but few details. Was a struggle but successful.
The nine pics are supposedly in order. With my 2 post lift it took me 3.5 hours to remove the old starter.
Disconnect both batteries ground. Use a short 15mm 12 point wrench for the cable on the solenoid and a 5/16" quarter inch socket/rachet on the small lug.
Remove 3 motor mount bolts with a 15mm socket using a long extension with impact wrench or rachet.
I used a screw jack stand to raise the engine as much as I could get --- maybe an inch off the mount tower. Another 1/2 inch would have been nice.
Remove the bottom starter bolt first with a long and short extension thru the front -- pic. Then the top bolt with a 15mm short socket or a long 15mm wrench. Once you break the 2 inch long bolts they unscrew easy.
Remove all three 15mm nuts on the exhaust pipe so collar is loose.
Now cuss, spit, sow some grass seed and drink a PBR.
You will most likely still need a pry bar to get old starter out (raising engine with exhaust manifold) and install new on see pics closely. The solenoid does not have to be removed.
Took me 3 1/2 hours to the point of the old starter removed. I did not know which end came out first. But pics show how it ended up working.
Another 1/2 hour to put new starter in.
With another 2 hours to put everything back together and tools put away.
This solved my starter noise. I am 72 and will be sore tomorrow. 8-)
1942 Chevy 1/2-ton Rod, 1959 GMC 1/2 ton Fleet Step side, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T, 2018 Bolt
dennislbrooks is offline   Reply With Quote
Old 08-04-2025, 02:56 PM   #2
dennislbrooks
Re: 2015 Chevy 2500HD Duramax Starter Replacement Starter Noise
more pics
