Old 08-07-2025, 02:52 PM   #2
bnorth
Re: Wiring a Heated Seat
I would find a pinout of the fuse box and check with multimeter to confirm but I believe that the spade terminal in "IGN." is switched by the ignition. The black wire is ground so that can hook to the chassis anywhere convenient. The red to IGN. Cut the pigtail on the inline fuse and use that inline with your red wire to IGN terminal.
1970 C10 l/b 292/4spd
Build: http://67-72chevytrucks.com/vboard/s...d.php?t=811062
bnorth is offline   Reply With Quote
