Old 08-20-2025, 06:30 AM   #1
cag
Active Member
steering column what is it???
what is this part with the bolt thru it?? and can I replace it??
cag is offline   Reply With Quote
Old 08-20-2025, 07:15 AM   #2
Getter-Done
Getter-Done's Avatar
Re: steering column what is it???
That acts as a U-joint between the steering column and the shaft to the gearbox.
It can be replaced with something like this in the link below.
Just be sure to measure both ends to get the correct one.
Link: https://www.summitracing.com/search/...20%28Search%29
The early bird gets the worm,
85 Chevy K-20
Old 08-20-2025, 07:27 AM   #3
cag
Active Member
Does that part wear out? the bolt was a lil loose, the steering wheel wanders when driving.
Old 08-20-2025, 07:33 AM   #4
Getter-Done
It has 2 Square pieces that sometimes will wear.
You can move the steering wheel back and forth while the truck is sitting still and see how much slack it has in it.
85 Chevy K-20
Old 08-20-2025, 08:31 AM   #5
cag
Active Member
thank you sir!
Old 08-20-2025, 10:02 PM   #6
DPowers
One foot in front of the other
DPowers's Avatar
Upgrade to a jeep one.
https://67-72chevytrucks.com/vboard/...d.php?t=783946
DPowers is offline   Reply With Quote
Old 08-21-2025, 07:39 AM   #7
cag
Active Member
Originally Posted by DPowers View Post
looks interesting, will look into this!! thanks!!!
Old 08-22-2025, 09:22 AM   #8
raggedjim
raggedjim's Avatar
I don't think the bolt being loose would make steering loose as I believe the coupling is splined. I'd check the steering box and front steering components, they usually wear before that coupling does. If it is the coupling you can buy them, jeep sites usually are cheaper than other sites.
http://www.quadratec.com/products/918018_02.htm
or complete coupling
http://www.quadratec.com/products/918018_06.htm
You'll need to double check the spline sizes, I think jeep has one size for manual steering and another for power. Not sure about the Chevy trucks.
Good luck, Rg
raggedjim is offline   Reply With Quote
Old 08-22-2025, 10:04 AM   #9
cag
Active Member
Thanks!!!
Old 08-22-2025, 01:04 PM   #10
Bandit130
Bandit130's Avatar
Also check frame where steering box is mounted. My frame cracked and made noise and some slack. Had to have it welded. Was not a cheap weld either.
1974 Cheyenne 10 LWB Stock 350 W/HEI /TH350/AC/4 BBL Quadrajet
Mopar by Birth
Chevy by Choice
Bandit130 is online now   Reply With Quote
Old 08-23-2025, 08:03 AM   #11
cag
Active Member
anyone know what size sockets for that jeep shaft?
