#6 | |
Re: dana 44 front hubs
1. A 1963 K10 DANA front drivers side drum backing plate. (number on it is 310299-L) If I cannot find that I need to do the drum to disc conversion, and if that then... 2. Advice on the Master Cylinder, because the original Master Cylinder has one line going to the hydrolic clutch and the other going to all four drum brakes. Since I need to separate out the new front discs from the rear drums, and also the clutch, how do you do that? Any insights on any of that, or anywhere you could point me for either of those? I'm having a tough time finding the first, or info on the second. Thanks! Patrick |
| Bookmarks |
