Old 09-07-2025, 05:48 PM   #1
desertnick69
desertnick69's Avatar
replacing rearend
I have a 1969 with HO52 rearend, due to how hard it is to find parts, what is a good replacement. I have coil springs.
desertnick69 is offline   Reply With Quote
Old 09-07-2025, 06:29 PM   #2
franken
Re: replacing rearend
If you can live without an E-brake a dimple disk conversion is pretty cheap. Eldorado calipers have a not so good ebrake as well. I happen to have a sett I don't need. I'd also change the gear oil.
There might be a way to convert to 14 bolt brakes as well.
If you want to get into redoing mounts a 14 bolt is probably the cheapest option.
Old 09-08-2025, 10:01 AM   #3
67 twins
Location: Herculaneum MO (20 minutes south of St. Louis
Installing 14 bolt brakes is easy as pie. However that's not what he asked.
67 C10 283 T5 swapped longbed fleetside = wife's daily driver(divorced)
67 C20 292 (originally a 250)4speed longbed fleetside w/original wooden bed=my project truck
67 C10 283+.060 (so a 292 as well)T5 swapped longbed fleetside=my DD(Sold)
72 C1500 Sierra Grande 350 TH350 longbed fleetside=wife's fair weather truck(divorced)
73 El Camino SS 454 4 speed my first big block
Can you tell we are fans of longbed fleetsides & 67s
Chris
67 twins is offline   Reply With Quote
Old 09-08-2025, 07:35 PM   #4
franken
I offered a 14 bolt as a replacement. What did you offer Mr. Snarky?
Old 09-14-2025, 10:54 PM   #5
Kalums
I'm also in the middle of a rear axle swap (getting rid of a Dana 70 dually that needs a new spindle)and after factoring in prices/ parts availability/ durability ...I ended up with a 14 bolt full foat out of a 1993 GMC suburban with the slip on brake drums (you don't have to remove the hub to replace or repair the shoes/drum AND I should be able to continue using my existing proportioning valve) I will have to get the perches(mine are leaf springs) replaced/moved (springs and shocks). Over all I feel that it will benefit me greatly as parts are cheap and plentiful.
And it will/should have a working parking brake.
Kalums is offline   Reply With Quote
