Old 10-03-2025, 07:36 PM   #1
bennylava
bennylava's Avatar
What's the point of an old 3/4 ton truck?
I wanted to ask this cause I'm debating on buying one. A guy down the street from me is selling his 77 so it raised the question. So I wanted to know what you guys use them for, or if it's just kind of an "I ain't sellin' her" thing.
In this day and age, is it better or more useful to own a 3/4 ton truck that is 15 years old or newer? Would a squarebody truck ever hold a candle to those trucks? Or are they just way too outclassed?
And if not, wouldn't it be better to just have a half ton squarebody, so at least it would ride a little nicer?
Any insights here would be greatly appreciated!
bennylava is offline   Reply With Quote
Old 10-03-2025, 08:17 PM   #2
cadillac_al
Re: What's the point of an old 3/4 ton truck?
If you plan on towing a big trailer, the 3/4 ton just has a higher GVW rating. If you don't tow heavy stuff the 1/2 tons do ride slightly better. I have one of each so all bases are covered.
76 Chevy K20
76 GMC K15
77 Chevy C10
77 Chevy K10
cadillac_al is offline   Reply With Quote
Old 10-03-2025, 10:50 PM   #3
outlaw5067
outlaw5067's Avatar
It all depends on what you want to use it for. My BB 79 C20 got up to speed a lot better than my 03 6.0L does, but having overdrive makes running at highway speeds a lot nicer. Both had the same GVWR. If you're only towing on rare occasion, and lighter weight, get a 1/2 ton. Better fuel mileage and pep.
1950 Chevy 3100 Pontiac 350, TH350, Chevelle subframe...
1969 Chevy C/10 350, TH350 family owned since new
1996 Camaro Z28/SS #884 LT4 top end, M6, T-Tops... the project
2012 Camaro ZL1 #608 Stock LSA, M6 the Beast
2008 Chevy 2500HD LTZ Z71 CC/LB, 6.6L, Tuned w/ EFILive...
outlaw5067 is offline   Reply With Quote
Old 10-04-2025, 04:27 PM   #4
Dead Parrot
If it has a long bed, you can fit 4x8 stuff and still close the tailgate. With the newer crew cab short beds, lots of stuff hangs out the back.
As far as capability, if you stay on top of maintenance, the old truck can do as good a job as the newer ones.
For 1/2 vs 3/4, your choice. Fair number of 1/2 are built with a 6200 max weight and will ride close to a 3/4.
Newer seats can improve ride a lot. The standard quality bench seats leave a lot to be desired on ride comfort.
A lot depends on price.
Dead Parrot is offline   Reply With Quote
Old 10-04-2025, 06:52 PM   #5
GSP7
GSP7's Avatar
What? No comprende senior
'81 K20 Silverado , '99 Dodge Cummins 4x4, '05 Dodge Cummins 4x4,
No Snivelers
"No Lowballers, I know what I got"
GSP7 is offline   Reply With Quote
Old 10-04-2025, 10:13 PM   #6
Honest Bob
Honest Bob's Avatar
The rear axle should be a 14 bolt full float which is pretty stout vs the 1/2 ton rear axles.
I think the front and rear brakes might be the next size up (JB7?) from most of the 1/2 tons.
The frame is the same as a 1/2 ton. If its automatic they usually had the same th350 trans as the half tons unless it had a diesel then it was th400.
Honest Bob is offline   Reply With Quote
Old 10-05-2025, 09:12 PM   #7
DPowers
One foot in front of the other
DPowers's Avatar
Love mine and have driven it everywhere. Switched to 3:73 and 700R4. 17 MPG empty on highway.
DPowers is offline   Reply With Quote
Old 10-06-2025, 04:56 PM   #8
THI
THI's Avatar
I prefer the 3/4-ton due to heaver axles, larger brakes and even heaver frame (it has the same dimensions as the 1/2-ton but is thicker steel). Not much difference in gas mileage between the two so why go light duty!?
THI is offline   Reply With Quote
Old 10-07-2025, 04:39 PM   #9
bennylava
bennylava's Avatar
Are 3/4 ton trucks typically more expensive? Or are they so old now that it doesn't really matter?
Also, which seats improve the ride comfort? I noticed that some newer trucks have gone over to harder seating, which I'm not a fan of. I like the 80's and 90's plush seating.
I always heard they ride a good deal rougher. That would be the only reason I would go with a half ton.
Old 10-08-2025, 09:54 AM   #10
SCOTI
SCOTI's Avatar
Front & rear brakes are larger for 3/4-ton trucks. They also def have heavier duty hubs.
I know my R30 has thicker rails & if I recall the 3/4 tons used the heavier rails as well.
TH350 vs TH400 comes down to how it was optioned. There were a bunch of both produced.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 10-08-2025, 10:00 AM   #11
THI
THI's Avatar
The ride quality of a 3/4-ton truck has more to do with the length of the rear spring than the spring rate. I have a 1978 C20 Camper Special (8200 GVW) that has the 1-ton springs (3500#) on it and it rides fine (it is a truck), it has a 56" rear spring. I have owned both a 1977 and 1978 K20 (8400 GVW) and they had the 52" 2775# rear springs and rode ruff compared to the C20 Camper Special with the much heavier but longer rear springs.
Keep in mind if your purchase an old square body 3/4-ton it will most likely need new springs anyway. Go with the 56" rear springs and move the rear mount back 4" (holes should already be in the frame) if it came with the 52" springs and get either the standard 3/4-ton 2600# rear springs or the 1-ton 3500# rear springs if you want to have more load capacity.
Old 10-08-2025, 11:24 AM   #12
bennylava
bennylava's Avatar
I'm a leaf spring newb... I never thought of longer rear springs. Sounds like you can have your cake and eat it too, hypothetically speaking of course.
Cause what if you managed to find and install say, 60" rear springs? Or 64"? Seems like you could just go longer and longer until you finally ran out of room. But still be at a 3/4 ton towing capacity.
Old 10-08-2025, 11:50 AM   #13
SCOTI
SCOTI's Avatar
Or.... Use 1/2-ton springs for a better unloaded ride & have air bag lift/assist springs to compensate for heavier loads.
I KNOW my dually had the longer HD leafs (and a bunch of them) & was a horrid driving experience when unloaded. It now has a 4-bar suspension w/bags in the rear & rides very nice (loaded or not). A 3/4-ton w/light duty leafs & helper bags would be the way I'd go.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-09-2025, 04:53 PM   #14
bennylava
bennylava's Avatar
Does the thicker frame cause a worse ride quality than a half ton, since it can't flex as much? Or is that pretty much a myth?
Old 10-10-2025, 09:20 AM   #15
HO455
HO455's Avatar
For me the biggest reason to get the 3/4 ton is for the trailer pulling aspect. If I need rent a bobcat or backhoe the rental companies require a 3/4 ton or larger truck to tow them.
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 10-10-2025, 09:46 AM   #16
SCOTI
SCOTI's Avatar
I'd say myth based on how my dually rides after mods vs as it came stock and it still utilizes the 16" LT/load rated tires doing it. Spring rates & the ability for shocks to do their job make a difference.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 10-13-2025, 11:55 PM   #17
Dead Parrot
Don't know that 3/4 are much more expensive then 1/2 but most of the squares have gone up in price so 'good deals' are harder to find.
I went with a set of aftermarket bucket seats in the mid 90's. Made a lot of difference in ride quality. Got rid of the bench seat bounce.
Old 10-14-2025, 12:23 PM   #18
MJN
MJN's Avatar
For me the point of a 3/4ton is using it as a truck, benefits of one as many mentioned already are bigger brakes, bearings, axles, etc. Sounds like you are concerned more with ride quality which can be more personal preference. I wouldn't pass up driving mine on a more regular basis and, to me, the ride quality of mine is just fine for 51 years old. Granted a partial load of retaining wall blocks and landscaping stone makes it ride a tad softer.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 10-15-2025, 03:01 PM   #19
bennylava
bennylava's Avatar
Yeah that's really why I would be getting it... using it as a truck. But hey, if it can also be nice, what's the harm in that?
I don't like the way my half ton sagged a couple times when getting some heavier stuff from home depot. Not destructively, but enough to make want a 3/4 ton. I knew I was right at the limit. I imagine 3/4 tons are just better at pulling trailers in general.
Old 10-15-2025, 04:05 PM   #20
MJN
MJN's Avatar
3/4's just have a higher load capacity, it doesn't mean they can pull a trailer any better. They can handle more weight, whether it be fifth wheel or bumper pull trailer but you'd probably happier with a C10 with a 454 than a C20 with a 250 6 cylinder (assuming trailer load and drivetrain is the same) for strictly pulling. If you're loading the 8ft box with concrete block or have a heavy tongue weight trailer you'll appreciate the 3/4 ton more so you're not dragging your rear bumper on the ground and the bigger brakes help stop better too. Hopefully this makes some sense
'17 GMC Yukon XL
VCCA member #58596
Old 11-06-2025, 08:29 PM   #21
factorystock
factorystock's Avatar
I wanted to ask this cause I'm debating on buying one. A guy down the street from me is selling his 77 so it raised the question. !
A '77 3/4 ton ( if you consider a '77 old) has a full floating rear axle standard, IMO, this is superior to a semi floating 3/4 ton rear axle found in most '81 and newer 3/4 tons. It will carry a heavy load more dependably.
factorystock is offline   Reply With Quote
Old 11-20-2025, 09:06 PM   #22
Shugalou
Shugalou's Avatar
That's good info and something I wouldn't have considered as my wife complains that it's too bouncy in the truck and I thought that was solely due to the suspension - I really like the snowden style bench seats - do you think that bench seat bounce would still be an issue with something newer? I'm not really a fan of the buckets but you have me thinking now.
Found my dad's old truck
http://67-72chevytrucks.com/vboard/s...d.php?t=563321
Newspaper Article Publishing the quest find my dad's old truck
http://www.theglobeandmail.com/globe...ticle12494281/
Shugalou is offline   Reply With Quote
Old 11-20-2025, 10:02 PM   #23
PowerdbyChevy79
PowerdbyChevy79's Avatar
If your wanting to use it a s a truck then a 3/4 is the way to go... I bought a longbed 1/2 to use as a truck and its a nice, runs smooth when unloaded. but it needs to be heavier.. if i load it down with some plywood it definitely sags. I definitely cannot pull my 20ft car hauler or i wouldn't want to anyways. So if i had to do it again i would get a 3/4.
1966 C10 "Mary"
1967 C10 Custom "Ole Blue"
1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364
1979 C10 Silverado "The BIG TEN"
C10 Club Texas -HMIC
PowerdbyChevy79 is offline   Reply With Quote
