Old 10-20-2025, 11:23 PM   #1
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Anybody using Cold Case Raditor
I’m looking at Aluminum Radiators with Shroud and Fans for my LS. Came across Cold Case. Anybody have any input on these Or Recommendations
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 10-21-2025, 12:26 AM   #2
Steeveedee
Ram-A-Lam-A-Ding-Dong
Steeveedee's Avatar
Re: Anybody using Cold Case Raditor
I have one, that replaced my 4-row brass radiator. Dropped right into the stock mounts and fits fine. It's been in there for many years, and I have no complaint.
~Steven
Simi Valley, CA
Old 10-21-2025, 12:40 AM   #3
1970 CST Short Wide
Senior Moment
Thanks for the input. I’m replacing my 4 row brass also.
Pittsburg Ca
94565
Old 10-21-2025, 01:30 AM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Look on YouTube.
Lots of complains with Cold Case Radiators.
Then read the replies in the comments section for the videos.
Some people are on their second or third radiator.
Keith
Convert to disc brakes.
Old 10-21-2025, 07:46 AM   #5
Joyridin
I had 2 of them in my truck. When the 2nd one went bad, I got it warrantied and sold it brand new in the box.
All of them leaked where the header is attached to the tank. The one I put in to replace the CC was about double the price, but have had zero issues.
My brother had the same issue. He just keeps warrantying his though.
Joyridin is offline   Reply With Quote
Old 10-21-2025, 08:36 AM   #6
HO455
HO455's Avatar
I bought and installed one, but I was dissatisfied with how it fit and returned it. I posted the issue in my repair thread in link below. Scroll to post 333.
http://67-72chevytrucks.com/vboard/s...698377&page=14
RIP Bob Parks.
Old 10-21-2025, 09:20 AM   #7
72c20customcamper
72c20customcamper's Avatar
I have two . One in my 72 for about 2 years and the other in my 68 . Both fit well and cool well I tow with the 72 and the 68 has a 383 . No problems as of yet . Neither have electric fans just the stock clutch fans
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
Old 10-21-2025, 05:25 PM   #8
LS short box
I used a Afco generic LS swap radiator on my 68 C10. Biggest I could fit. Worked very well. Some fab to make it fit but not horrible.
Ran super cool. Right on the thermostat.
Old 10-22-2025, 10:42 AM   #9
BROWN 70
BROWN 70's Avatar
x 2 post 2. no problems
BROWN 70 is offline   Reply With Quote
Old 10-22-2025, 03:29 PM   #10
1970 CST Short Wide
Senior Moment
Can I ask what Hoses you used. Both top and bottom
Pittsburg Ca
94565
Old 10-22-2025, 05:28 PM   #11
LS short box
I have since sold the truck to fund a new project.
But my go to for LS hoses is Oreilly's back room hose rack. I make a wire pattern to help select. Typically I have to trim whatever I select to fit.
Old 10-23-2025, 09:53 PM   #12
Rich69shortfleet
I don't have one in my truck, but I have Cold Case radiators in both my GTOs (04 and 06) and have been very pleased with both. Fit was drop in easy and they really do a great job keeping things cool. Both run right around 200 degrees at all times. 06 is blown and the 04 has aftermarket heads and cam.
In the truck I have a large Champion all aluminum radiator which was also drop in easy. It looks very similar to the CC radiators and was the final piece of the puzzle to keep my 400 SB cool, especially when towing. It works a whole lot better than the large 4-core brass radiator I had before.
Rich69shortfleet is offline   Reply With Quote
Old 10-24-2025, 02:36 PM   #13
biketopia
So what did you put that was twice as much? Currently shopping radiators for my project as well.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
Old 10-24-2025, 05:05 PM   #14
Joyridin
I used these guys. They have their cores made in the USA and they make the tanks. It wasn't real cheap ($800), but I had my inlet/outlet put on the drivers side instead of the passenger side due to where the L83 hose inlet/outlet is located. The radiator is a work of art.
Summit sells them also. They may have a standard that will work with an original engine or an LS.
https://powercoolmfg.com/street-and-...nce-radiators/
Old 10-25-2025, 12:40 PM   #15
1970 CST Short Wide
Senior Moment
Arrived Yesterday. If this goes Bad I will be Very Surprised. Looks Very Well Built. I know looks can be deceiving, But it really does look Well Done
Pittsburg Ca
94565
Old 10-25-2025, 02:41 PM   #16
Steeveedee
Steeveedee's Avatar
I went and checked my records. My Cold Case radiator has been in my truck 7 years, as of last September.
~Steven
Simi Valley, CA
