Old 11-01-2025, 10:11 PM   #1
chrismoore701
chrismoore701's Avatar
Blower motor screws stripped out.
Dumb question. 79 c10 blower motor screws stripped out. Can i just dab some epoxy in the holes drill out and go? Should i remover the motor? Should i use fiber glass resin?
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 11-02-2025, 10:01 AM   #2
Dead Parrot
Re: Blower motor screws stripped out.
Depending on how much stripping happened, might be as simple as going one size larger on the screws.
Dead Parrot is offline   Reply With Quote
Old 11-11-2025, 02:47 PM   #3
straight6chevyguy
straight6chevyguy's Avatar
I agree with dead parrot.
I definitely would first off try going to the next size screw. I believe I have had to do that on one of my trucks.
1965 Chevy c20 292 4speed http://67-72chevytrucks.com/vboard/s...d.php?t=777601
1976 Chevy c10 250 4speed http://www.67-72chevytrucks.com/vboa...d.php?t=787037
1978 Chevy c20 350 4speed
1998 Chevy c1500 4.3L 5speed
1999 Chevy k1500 Suburban 5.7L auto 4x4
2002 Chevy s10 4.3L auto 4x4
1971 Mercury Monterey wagon 400 auto
Plus other misc. ... To many projects!
straight6chevyguy is offline   Reply With Quote
Old 11-13-2025, 01:20 AM   #4
kennyw
N9PHW
kennyw's Avatar
Is it a plastic AC box or steel heat only box? Heat only is typically sheetmetal and could be welded shut, redrilled and be good as new. The plastic AC box, I would probably just try to use the next size up.
"I got it one piece at a time and it didn't cost me a dime..."
kennyw is offline   Reply With Quote
