Old 11-20-2025, 08:06 PM   #1
geunther
geunther's Avatar
Distance front to rear cab mounts
I am building a cab dolly to transport my cab and I don't have access to the cab or frame right now. I am hoping someone has an accurate distance from the center of the rear to the center of the front cab mounts for an 82. Any help appreciated.
The lid is stuck on my jar of anti seize
geunther is offline   Reply With Quote
Old 11-21-2025, 12:32 PM   #2
mongocanfly
mongocanfly's Avatar
Re: Distance front to rear cab mounts
My 81 is 43-1/2" as best as I can measure.
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 11-22-2025, 10:17 AM   #3
geunther
geunther's Avatar
Much appreciated. Its actually not the easiest thing to measure, so thank you.
Old 11-22-2025, 03:31 PM   #4
Getter-Done
Getter-Done's Avatar
I measured an 86 frame I have in the back.
I put all-thread rod in the front cab mount hole and centered it.
Then I had a piece of c-channel with holes that I drilled in the center on a mill at work (for my cultivator project).
I centered the channel on both rear mounts.
I came up with 43".
Still not a precision measurement.
If you get it between 43 and 43.5 you should be good.
The early bird gets the worm,
85 Chevy K-20
Old 11-22-2025, 03:52 PM   #5
Getter-Done
Also I will add that I measured the drop from the back mount to the front mounts.
I put a piece of one inch angle on top of the 2" c-channel.
I leveled the angle iron the best I could.
It measures 9.5 inches so 9.5 inches- the 2 " c-channel.
I came up with a 7.5 inch drop.
85 Chevy K-20
Old 11-22-2025, 10:09 PM   #6
geunther
geunther's Avatar
Originally Posted by Getter-Done View Post
I came up with 43".
You went above and beyond Getter-Done. Thank you much. 43.25 it is .
Between both of your guys' help, Im confident enough to weld on the mounts.
Old 11-22-2025, 10:14 PM   #7
Getter-Done
Glad we could help you out.
If you need any more measurements let me know.
85 Chevy K-20
Old 11-22-2025, 10:56 PM   #8
mongocanfly
("43.25 it is")... good.. now when it don't fit he can't blame either one of us..!!!...hahahahaha..
Me, I would have had to made it adjustable...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 11-23-2025, 12:11 AM   #9
Getter-Done
geunther you can blame either one of us Southern boys.
Slotted holes and slotted brackets.
I have learned a lot over the years.
I can get the width dimensions also if you need them.
Looks like you got a pretty good dolly frame going on there.
85 Chevy K-20
Old 11-24-2025, 07:14 PM   #10
geunther
geunther's Avatar
I had the rear width distance, but thank you for the offer. I will drill the front mounts when I load the cab. I also took your advice and made the rear mounts adjustable with 3.5" of adjustment fore and aft.
It is a bit overbuilt but that's better than the alternative. Almost ready to start the build thread.
Old 11-24-2025, 11:10 PM   #11
Getter-Done
That Cart Looks Great.
Tony the Tiger Great.
I just had to go measure the front mounts.
It put some all-thread thru the front cab mounts.
Guess what.
I came up with 43.25"
I know you said you would drill them when you load the cab.
I just had to add this info.
This may give you another idea.
Just trying to help.
Passengers side front mount.
Center to Center from (Precision Ground All-Thread rod)
Drivers side front mount.
85 Chevy K-20
